01-26-2023, 10:51 AM | #23 | |
Rep 786
what's the purpose for the 45 PSI. I have left at 33. I/m sure it's no where near that now.
2022 M3 Xdrive Frozen Dark Grey - 4/27.
2016 Charger Hellcat - 908 RWHP & 988 WTQ 9.9@ 140 - 2012 - Charger SRT 392 - Sold 2009 - Charger SRT 6.1 - Sold |
01-26-2023, 12:28 PM | #24 |
Rep 328
The service tech said it helps to prevent flat spots and cracking.
2023 M4 Comp
Dravit Grey Metallic |
ChargerHellcat991.50 |
01-29-2023, 04:25 PM | #25 |
Save the Manuals
1778
Rep 3,013
Yes - a good idea
Note: the car reads a little high. What I actually measured in the front tires was 39 psi, and in the back tires 44 psi FYI. Garage is 50* F
2023 G80 6MT, CCBs
2002 330i Dinan, 5MT 2000 Z3 Conforti, 5MT |
05-09-2023, 01:58 PM | #26 |
Rep 647
Storage update.
So it is May and the snow is mostly gone now. Just 18”+ up over the hill from me in the woods. Here is what I know about 6 months of storage. My storage preparation may have been a bit excessive, but it worked I haven’t any issues from the car sitting.
I took the cover off and was a bit surprised by finding a little dust, it was very minor. After removing the battery tender the car started instantly as if I just shut it off moments earlier. I drove it out of the garage then lowered the tire pressure to the recommended spec. Next step, took the car for a 30 minute drive to get it all the way to full operating temperature and everything seems good. Once back home I opened the hood, wouldn’t you know I smell coolant…again. I had coolant leaking from the bank one turbo when the car was brand new (from the factory) which as repaired last summer. I can see coolant leaking out near the bottle, hmm. My car has just over 3,600 miles so off to the dealer it goes. They told me the car is actually leaking in two places and of course there are no parts available, I’m not really sure where the other coolant leak is at the moment. So I get a loaner and head back home. Three days since I dropped off the car I get a text letting me know the car is ready. Can’t help but wonder if the coolant leaks are front eh previous repair? I have owned more than 40 new cars and have never had one leaking coolant like this before. I go back to the dealer on the 15th to retrieve my car. |
07-26-2023, 08:40 AM | #27 |
Rep 230
Storing 6 months
2018 M240
Do I need a fancy battery tender for this car technology? Can car be put on jack stands and not inflate tires to #45lbs I am worried about rodent damage. Will do all you suggested for that issue. Not heated detached garage. Not possible to check on car for 6 months. Looking for experienced storing people advice. Hap |
07-26-2023, 10:31 AM | #28 |
Rep 648
Drives: 2014 M6 Grand Coupe CP
Try peppermint oil soaked cotton balls scattered around exposed wiring and rubber parts. Disconnect the battery and use a good quality battery charger/maintainer. Once disconnected (negative pole), all that is required is a battery maintainer since there is no external drain on the battery.
the Battery Tender Jr on amazon is only $39 and should do fine If up on jackstands, the tire pressure is not critical. Without jackstands inflate the tires to their max rating during the storage. Make sure all fluids are "winter/freezing safe"
F06 M6 Grand Coupe CP
Sapphire Black Metallic The drive is the destination |
07-26-2023, 11:22 AM | #29 |
Rep 2,377
Drives: 2020 BMW M4 CS
Curious, what is the rational for over inflating tires? Reducing flat spotting? I was intending to put my M4 up on jack stands as I have winter upgrades planned.
07-26-2023, 08:53 PM | #30 |
Rep 648
The only reason for inflating the tires is IF you DO NOT use jack stands during long storage. The high pressure keeps the tires closer to round (less flat spot) during the extended standstill if the car is NOT on jack stands. There is no special inflation required if stored on jackstands, since there is no load on the tires and they thus remain "round" during the storage period.
The flat spotting will manifest itself as a thumping noise and a sence of being out of balance when you take the car out of storage
Car-Addicted8228.50 |
07-27-2023, 01:04 AM | #31 |
Rep 2
I live in Alaska and I store mine ina heated garage (45F) with the battery disconnected and Sta-bil added to the fuel. I have never had a problem other than resetting the clock.
07-27-2023, 10:48 AM | #32 | |
Rep 15
08-08-2023, 06:39 PM | #33 |
Rep 647
///MPhatic15634.50 |
08-13-2023, 08:40 PM | #35 |
Rep 2,377
08-29-2023, 07:14 AM | #37 |
Rep 230
How do I know
How do I know if I have a Lithium battery ?
2018 M240 Planned on a tender I already have for storage ? 6 Months with no ability to monitor Tender JR |
08-29-2023, 08:24 AM | #38 | |
The Seeker
15635
Rep 3,966
Jack stands are always the best option, but if you don't want to do that you can put 42/40 psi of cold pressure in them and roll the car forward or backwards off of the contact patch every few weeks. However, don't take this option if the temps in your storage area are below 42° as you'll cause micro-sipes and the tires will never perform as good as they did before. It pretty much always comes back to jack stands as a solution for the tire issue. |
08-29-2023, 11:19 AM | #39 |
Rep 2,377
08-29-2023, 11:36 AM | #40 | |
The Seeker
15635
Rep 3,966
My space is so tight that this past year I just jacked the car up one side at a time every 2 weeks and rotated the tires. No flat spots after 3 months, so no more mods bought! lol |
08-29-2023, 11:43 AM | #41 | |
Rep 2,377
It will say what the chemistry is on the battery.
NEVER manually charge a Lipo battery unattended unless using a LiPo charger with a maintenance program! |
12-18-2024, 05:29 PM | #42 |
Save the Manuals
1778
Rep 3,013
Well, it’s winter time again and so the tire pressure goes up and the occasional top off of the battery. Fresh oil in, and she’ll be ready for Spring!
Other than that, I leave her alone. However, I added a bunch of glue boards in the garage this year for extra prevention. No varmits !!!
2023 G80 6MT, CCBs
2002 330i Dinan, 5MT 2000 Z3 Conforti, 5MT Last edited by G80indy; 12-20-2024 at 10:10 AM.. |
slilley97.50 |
12-20-2024, 10:14 AM | #43 | |
Save the Manuals
1778
Rep 3,013
2023 G80 6MT, CCBs
2002 330i Dinan, 5MT 2000 Z3 Conforti, 5MT Last edited by G80indy; 12-20-2024 at 10:16 AM.. |
12-29-2024, 10:04 PM | #44 |
Licensed Professional Slacker
1817
Rep 1,037
Drives: 2024 M2 and 2025 i4 M50
I store the car for four months (Dec 1st until April 1st) in a heated garage.
Change oil/filter. Fill gas tank, add STA-BIL, let it run for a bit to circulate it through. Touch up interior and exterior as needed. Check tire inflation. Use CTEK MXS 5.0 battery tender. Put storage insurance on it ( many lenders have insurance requirements when you put a lien on your car and need to approve if you want to drop collision/liability coverage while it's in storage so be sure to check with your lender. BMW Financial emailed me a letter approving it so I could give it to my insurance company incase they needed it.) Car gets moved a couple times during the four months as I'll take the wheels off to recoat them, etc. Dream about spring time....
2024 M2 and 2023 Mazda CX-30
