BMW X1 and X2 forums (U11/U10) General BMW X1 and X2 Discussion (U11 / U10) (2023+) X1 Aftermarket wheels
      08-09-2024, 01:49 PM   #89
FZI89
FZI89's Avatar
Austria
707
Drives: BMW iX1, U11
Originally Posted by chriscross View Post
Haha yes, it's the BMW Wien Donaustad in the 22nd district.
We go to the same dealer! 🤝
      08-09-2024, 01:56 PM   #90
chriscross
Drives: BMW X6M 2024, Mustang MACH 1
Here's two more photos of the 21"s for those interested...
      08-10-2024, 12:16 PM   #91
J-RO
Drives: 2024 M240ix BMW X1 28i
Originally Posted by Luff9 View Post
These are 245/45/19 on 19x8.5 +35mm rims.
The dog seems to like them.
      08-10-2024, 04:53 PM   #92
X1-CT
Drives: X1
I swear ever new post I read on wheels makes me more confused. Haha
      08-22-2024, 12:54 PM   #93
chriscross
The 21" wheels fit perfectly, we put multi-season tires on them. The ride is soft, pot holes absorbed with ease. Nothing more to add.
Yes, ride stiffness is personal preference and very subjective to assess. I'm 40, no back problems and daily drive an X6M...someone else might probably feel different about it.
      10-04-2024, 09:38 AM   #94
X1-CT
Drives: X1
I’m getting closer to getting new wheels. It seems like I’m probably going to go with 19x8.5 +35 offset.
I am still having a hard time fully understanding tire sizes. It seems to me that I can possibly use my current tires that came stock on my x1 even though the rim size is .5” wider.
Is that correct?
      10-04-2024, 09:53 AM   #95
schnell325
Bored at work....
schnell325's Avatar
Drives: 2016 F82 M4 GTS//2022 M235iGC
Is that correct?
Absolutely you can fit your current tires on a 1/2” wider rim
Grey Matter:2008 E92 M3:608/425. SG/PS SOLD!
Dark Matter:2015 F80 M3:495/505. SOLD!
Anti Matter :2016 F82 M4 GTS
2024 U11 X1 2.8i
      10-04-2024, 11:08 AM   #96
SnowCover
Drives: '23 330i, '23 X1, '25 X3
and according to Tire Rack testing, the wider wheels will make the car go faster...
      10-04-2024, 02:21 PM   #97
X1-CT
Drives: X1
Is there another tire size that would also be appropriate for an 8.5” wide wheel?
Wouldn’t increasing the width of the wheel reduce the diameter of the tire? If so I read that can effect the xdrive system and also obviously the speedometer
      10-04-2024, 02:34 PM   #98
SnowCover
Wouldn’t increasing the width of the wheel reduce the diameter of the tire? If so I read that can effect the drove system and also obviously the speedometer
wider wheels are almost always heavier. The additional unsprung weight is not desirable. (unless the wider wheels are forged, which are lighter, of course)
      10-04-2024, 03:54 PM   #99
X1-CT
Drives: X1
Yea I’m sure they will be heavier. I don’t personally like the look of most forged wheels on the X1. But also I’m not sure I’m willing to pay what they cost.
Still curious about the stretching my tires to 19x8.5. Seems like it would change the diameter
      10-04-2024, 06:25 PM   #100
schnell325
Bored at work....
schnell325's Avatar
Putting those tires on 10-11” wide wheels would be what I consider stretching them.
2024 U11 X1 2.8i
      10-04-2024, 07:46 PM   #101
FlashMonkey929
I Shoot People For Money
FlashMonkey929's Avatar
1236
Drives: 2023 Portimao MSport X1
2003 BMW 330i ZHP  [0.00]
2023 BMW X1  [10.00]
1/2” wider on the OEM tires and you should be fine. Most tires have a range of widths they are designed to fit. Going wider on all 4 wheels will not affect xDrive, it’s only when you go different tire diameters between front to back where you might have issues because the front and back wheels are rotating at a different rate relative to speed/distance covered.
Forged wheels for the same size are lighter for the same relative strength. You would benefit from reduced unsprung weight, which can positively affect steering response, handling, braking effectiveness, and fuel economy. Otherwise cast wheels are fine, you’ll likely not notice the difference from your OEM wheels with a decent aftermarket cast wheel, for the most part.
2008 335i Alpine White Coupe -sold-
2011 335i Alpine White Sedan PPK -sold-
2020 430i Estoril Coupe MSport -returned-
2023 X1 Portimao, Msport, Premium
2003 330i Imola Red ZHP 6 Speed
      10-22-2024, 03:47 PM   #102
grumpywoodchucker
Drives: 2023 X1
Originally Posted by Fast35i View Post
U11 on 22 x 9.5 37 offset
      10-22-2024, 07:50 PM   #103
SnowCover
are those approved by the Bundesbahn for use on rails?
      10-23-2024, 02:12 PM   #104
airkat32
airkat32's Avatar
Greece
49
Drives: 2024 X1 Frozen Grey MSport Pro
i have the 20s on the X1 with the 245. i was thinking to increase to a 265. i dont want bigger wheels but i want some more meat. i did this on my f30 with 19s and put on 265 rear and 245 front. worked amazing and handling was increased. plus it looked dope.
      10-23-2024, 05:54 PM   #105
X1-CT
Drives: X1
What changes when you put a wider tire on the same size rims?
      10-24-2024, 03:06 AM   #106
airkat32
airkat32's Avatar
Greece
49
same rims. the 20s seem to be enough on the x1. i just think it handles a little better. maybe a little more sidewall. its more asthetic for me.
      10-25-2024, 11:19 PM   #107
X1-CT
Drives: X1
Gotcha. I’ve been trying to learn all I can about rims and tires before I decide what to do about aftermarket wheels.
      10-25-2024, 11:43 PM   #108
Readimag
Drives: X1
I have 20s for summer old cause being told I was limited in speed made me say no haha. Right now I have 19s for winter on, kind of wish I went for bronze but love the black also.
      10-26-2024, 11:30 AM   #109
8BMWSsofar///M
Drives: F85
I mounted new wheels and tires on the wifes X1M35i last weekend. The plan is to run these for a few more weeks then mount winters on the factory 20's. Heres a few pictures . I think it turned out alright.
      10-27-2024, 11:46 PM   #110
X1-CT
Drives: X1
Attachment 3585600
Would you mind sharing a link to the wheels and tires? Still trying to get a handle on the best width, offset and tire size.
Search this Thread:
Advanced Search
