BIMMERPOST Universal Forums Off-Topic Discussions Board Smart Garage Door Opener - Recommendation
      09-01-2020, 03:55 PM   #1
TXSTYLE
"Salud"
TXSTYLE's Avatar
15338
Question Smart Garage Door Opener - Recommendation
Okay... For those of you who have "shopped, reviewed, and installed" one of these, which do you recommend?
I mainly want it for:
Phone and Voice opening and closing.
Alert/push notification if left open.
Google compatible.
https://flic.kr/p/2qwbTyk
      09-01-2020, 07:57 PM   #2
mecheng77
mecheng77's Avatar
Drives: 2007 328i / 2014 M235i
  [0.00]
  [0.00]
I have chamberlain Q and I'm happy with it and they are quite popular. I've had it a few years and no hiccups
TXSTYLE15338.00
GenXer1401.00
      09-01-2020, 09:01 PM   #3
TXSTYLE
"Salud"
TXSTYLE's Avatar
15338
Thanks! Does it provide voice commands with Google? Phone app pretty fluid and reliable?
      09-01-2020, 09:39 PM   #4
zx10guy
Drives: 2013 135i
I have the Chamberlain MyQ also. I don't recall if it has voice command capability. The app works great though. You can send notifications to your email and phone when the door opens or closes. The newer model has the ability to monitor the battery life of the door sensor. It also has scheduling capabilities with closing the door. So you can set the time for the system to automatically close the door if it's left open by accident. Prevents you from having the garage door open all night.
I have the newer system at my primary home and moved the older one to my vacation home. The single app controls both. I've been running the older system for about 3 to 4 years now. No issues. I just got the newer one a bout a year ago. The newer one is paired with a Genie garage door opener and the older one is paired to a Liftmaster opener.
The only thing you might find annoying is when you close the door through the system, it would sound an annoying beep beep for a few seconds as the strobe light in the unit flashes. It's a safety thing to ensure anyone around knows the door is about to close.
I seem to recall there is some integration with I think Nest or Ring security cameras.
Originally Posted by Lups View Post
We might not be in an agreement on Trump, but I'll be the first penis chaser here to say I'll rather take it up in the ass than to argue with you on this.
      09-01-2020, 09:57 PM   #5
mecheng77
mecheng77's Avatar
  [0.00]
  [0.00]
Not sure about voice commands. I use Apple iPhone and I can open and close it and it sends an alert when it opens and closes. Not much more you can ask for.
For whatever reason they do t have many competitors: Genie and not sure who else
      09-01-2020, 10:09 PM   #6
Noneya
Drives: '21 X5MC, '14 X1 35i M sport
2021 X5MC  [0.00]
I use OpenGarage. I also have Home Assistant which allows for arbitrary rules and customizations around this including all of your asks.
      09-01-2020, 10:14 PM   #7
21F90M5C
Drives: 2021-M5C LCI
Some folks also attach cameras on their garage openers to check who’s coming and going
I have the MyQ and love it. Doesn’t have voice control that I know off but you can use your smartphone to control it.
      09-01-2020, 10:39 PM   #8
Mason Hatcher
Drives: BMW X3
Another happy MyQ operator here. I have integrated it into my home alarm app as well.
      09-01-2020, 11:06 PM   #9
TXSTYLE
"Salud"
TXSTYLE's Avatar
15338
Thanks guys! This is one of those things I've wanted but keep forgetting. I'm going to order one this week.
How is the "installation process"?
      09-01-2020, 11:10 PM   #10
WingZeroX5
WingZeroX5's Avatar
Drives: F80 / F30
i'm using the liftmaster 8500W. Love it and easy install.
      09-01-2020, 11:30 PM   #11
zx10guy
Drives: 2013 135i
Extremely easy. You load the app on your phone. It'll walk you through the installation process. It'll all be done via the app and at some point it'll tell you to hit the Learn button on the garage door opener to pair up the MyQ to it.
      09-02-2020, 12:22 AM   #12
QM
Drives: 2020 M2CS 6MT
I've had the MyQ system for the past 7 years, however I don't recommend it. At least not if you are using a retrofit setup for older openers that don't have it built in. The MyQ retrofit wall switches go bad after 4-7 years. When they do, they cause the garage door to randomly open. It happened to me twice when each of the two wall switches went bad. The second wall switch went bad just last week in the middle of the night. I thought someone broke into my garage until I realized the issue.
I believe there is a capacitor that stops charging after a while and when it does it activates the opener switch. Terrible design fault and a huge security issue.
I'm not sure if this issue exists with newer openers that have MyQ built in.
I have a Zwave automation system at home and was looking at a zwave garage controller but those seem to have issues as well.
      09-02-2020, 12:49 AM   #13
SakhirM4
SakhirM4's Avatar
Drives: '15 SO M4/'20 Z4 M40i
2020 BMW Z4 M40i  [10.00]
2015 BMW M4  [8.76]
Agree. I have a Liftmaster 5365W and it is great. I also use MyQ on my phone with it.
https://www.liftmaster.com/garage-do...E&gclsrc=aw.ds
Tejas Chapter, BMW CCA, mem #23915, President 27 years, www.tejaschapter.org
      09-02-2020, 12:55 AM   #14
zx10guy
Drives: 2013 135i
What switch are you talking about? Neither of my openers have MyQ built in and there is no switch. Just the base unit and the door sensor to tell the base unit if the garage door is down or up. If the door sensor goes bad, it won't trigger the base unit to open the garage door.
      09-02-2020, 01:21 AM   #15
TXSTYLE
"Salud"
TXSTYLE's Avatar
15338
I also have a Liftmaster that the Builder installed on the home we built 2.5yrs ago. Don't know the exact model. But it's fast and durable.
      09-02-2020, 03:27 AM   #16
jsf721
Drives: 2019 540i X M Sport
I have the genie belt drive with the battery back up and smart WiFi control. Ordered at Costco for price and warranty. The whole
Operation is now silent. Bedroom over garage cannot hear it open any longer. At the same time I changed the rollers, safety cables and springs. Huge upgrade.
It’s a 2 person job Or a pita one person. You will need a little giant to prop the track on if working alone. Truth I hired a garage Co to do it after underestimating the ease of install. Best $ 150 (per door install )I ever spent. He installed all of the above and an external key pad.
      09-02-2020, 08:47 AM   #17
Mason Hatcher
Drives: BMW X3
Same here. No external switches. My GD opener is Genie. The MyQ works by acting as another remote.
      09-02-2020, 08:54 AM   #18
1MOREMOD
1MOREMOD's Avatar
Drives: Race car->
Mine has a button your push and it opens that seems smart?
upstatedoc7542.50
      09-02-2020, 08:58 AM   #19
smyles
Drives: '21 X5 M50i
My butler operates the doors. He's alright.
Kilabyte3994.00
upstatedoc7542.50
      09-02-2020, 09:42 AM   #20
QM
Perhaps a poor choice of words on my part. I'm taking about a wall button that opens the garage door from inside. Part number Liftmaster 888LM. https://www.liftmaster.com/888lm-myq...ntrol/p/G888LM
There is a wire from this wall button to the opener. The MyQ wall button communicates with the liftmaster gateway that connects to the router. That's how the retrofit MyQ system operates.
Anyway, just read the reviews in the above link and you'll see that this is a common problem. Yes the system works very well for a number of years until the wall switch/button goes bad. Then you'll find your garage door open by itself at random times. The first one went bad after 4 years in the winter and left the door open. Luckily we were home and no pipes burst since I just used a car remote to close the door. The second went bad last week (7 years) during the night. I get alerts when the door is opened. Was not a fun thing to investigate in the middle of the night. Don't know if this issue is limited to retrofit MyQ systems only. Just be warned if you have an older opener and want to go that route.
      09-02-2020, 10:45 AM   #21
zx10guy
Drives: 2013 135i
Perhaps a poor choice of words on my part. I'm taking about a walk button that opens the garage door from inside. Part number Liftmaster 888LM. https://www.liftmaster.com/888lm-myq...ntrol/p/G888LM
I guess it's a different implementation of MyQ. When you say retrofit, I think my situation would qualify as a retrofit as neither of my openers have Smart capability and neither can have a direct upgrade installed. This is the kit I installed for both of my garage door openers:
And it's been working flawlessly for years in the case of the older version of it.
GenXer1401.00
      09-02-2020, 11:03 AM   #22
omasou
omasou's Avatar
Drives: BMWs
2023 BMW S1000RR  [0.50]
2022 BMW F900XR  [3.00]
2022 BMW X6 40i  [0.50]
2020 BMW M2C  [9.50]
I have Craftsman GDOs, essentially rebranded LiftMasters. I can use Siri to open and close the garage door either through the iPhone or Apple CarPlay.
My GDOs do not have MyQ built-in so I had to retrofit a solution. Be careful they offer various ways to retrofit and it's not always clear, why.
I chose the 819LMB myQ Home Bridge vs. the G821LMB myQ Smart Garage Hub and the 828LM Internet Gateway. The latter two provide connectivity to the myQ app but do NOT support Apple HomeKit integration.
I didn't choose this option b/c it attaches to the garage door and it only supports two garage door sensors. I have three garage doors.
https://www.liftmaster.com/smart-garage-hub/p/G821LMB
https://www.liftmaster.com/myqpck-sm...pener/p/MYQPCK
This doesn't list all products, e.g. hub but does provide a nice overview.
https://embed.widencdn.net/pdf/plus/...7.pdf?u=mcyivk
I have this solution working for 1 door. To support the other two doors, I will need to add additional 889LM control panels.
I used...
This bridge is plugged into the ceiling and zip tied to the operator bracket...
https://www.liftmaster.com/myq-home-bridge/p/G819LMB
889LM Control Panel
in combination with this control panel which is hardwired to the operator and attached to the wall. I wish the control panel wasn't hardwired. The control panel does have a motion sensor that can be configured to turn on the operator light when you enter the garage.
https://www.liftmaster.com/myq-control-panel/p/889LM
The older 888 control panel had issues...
Scroll down the 889LM page and you will see a link to request a replacement...
https://cloud.info.liftmaster.com/88...845.1599058305
Search this Thread:
Advanced Search
