BIMMERPOST Universal Forums General BMW News and Cars Discussion N54 Engine Clank *Not rod bearing related*
      12-21-2022, 01:07 PM   #1
jeddo45
Apprentice
Drives: 2007 BMW 335i
I got an issue that I, nor my mechanic can't put our fingers on. I'll explain this as detailed as possible hoping that someone else has had a similar issue.
At about 2k RPMs, there is a noticeable slapping/ clank coming from the engine. It also happens on neutral so it's not anything driveline related.
The issue is mainly from 2k to 4k RPMs only when I'm hitting the gas. From idle to about 2k, no clanks or slapping noise. But from 2k to 4k RPMs, its a very loud definitive clanking/ slapping. The noise coincides with the speed of RPMs. When I let go of the gas and the engine comes to an idle, the noise doesn't happen at all no matter where I'm revving the engine.
My timing chain and guides have been replaced but the noise is still there. Since the noise happens only within that RPM range, we don't think it's rod bearing or piston related.
I'm going to try and upload a video and see if you all could hear it. In the meantime, any thoughts? The car runs great still. No noticeable performance drop or limp mode. I'm baffled.
Any suggestions?
https://photos.app.goo.gl/dJeo7zEerPUxM5hR8
      12-21-2022, 10:53 PM   #2
Tejas1836
Tejas1836's Avatar
1224
Drives: 2023 X5MC Workmaster 75
Did you own a cat?
      12-21-2022, 11:22 PM   #3
GuidoK
#buildnotbought
GuidoK's Avatar
14861
Drives: Z4 3.0i ESS TS2+
My first guess would be the vibration damper. Or maybe some weird resonance from a belt tensioner or such.
But a clacking sound like that (non intermittent on a stationairy car) shouldn't be too difficult to locate?
If it comes from within the engine (or within a stationairy part), use an engine stethoscope. A cheap and really handy tool.
Z4 3.0i | ESS TS2+ supercharger | Quaife ATB LSD | Brembo/BMW performance BBK front/rear | Schrick FI cams | Schmiedmann headers+cats | Powerflex/strongflex PU bushings | Vibra-technics engine mounts | H&R anti rollbars | KW V3 coilovers/KW camber plates | Sachs race engineering clutch | tons of custom sh#t
      12-29-2022, 11:40 PM   #4
10"
10"'s Avatar
Drives: orange BMW 1M.
I mean at that range from about 2000-2500 is when the N54 twin turbos really start going up to about 4000+ is their peak range—so without knowing much more I’d wonder about the turbos. It’s nothing like the famous wastegate rattle?
don't read this. too late...
      12-30-2022, 11:30 AM   #5
XutvJet
XutvJet's Avatar
6283
Drives: 2011 Cayman Base, 2018 M2
That is absolutely rod knock and the rpm range you're noting is the common rpm range that it tends to be most audible. I'd find another mechanic if they couldn't tell that was rod knock within one engine rev.
chris7197655.50
      12-30-2022, 01:42 PM   #6
chris719
Drives: '08 M Roadster
I have to agree with XutvJet that it does sound like rod knock.
      12-30-2022, 02:33 PM   #7
tracer bullet
tracer bullet's Avatar
Drives: '25 Z4, '15 X3 35i (135i sold)
I've heard sticky (open) injectors sound like rod knock.
      12-30-2022, 02:58 PM   #8
meadowsdb
Drives: '23 M3 Comp X-Drive
Rod Knock. Keep your foot off it before you have a hole in the block.
      12-30-2022, 03:14 PM   #9
TheMidnightNarwhal
TheMidnightNarwhal's Avatar
Drives: 11' 335is DCT
Unfortunately does sound like rod knock. That said, I would try to run the car with the serpentine belt removed just to rule out any accessories. I've read in the past someone who thought he had rod knock on his N54 but it ended up being the AC compressor. Good thing to try and rule out (unless your mechanic already did it).
Search this Thread:
Advanced Search
