06-10-2023, 09:39 AM | #1 |
Rep 1
320i 2009 fault headlamp high beam (type halogen)
hello everyone!!
i have a trouble with headlamp high beam module FRM (damaged) not operate with high beam , low beam and the rest of the lights are still working normally when I replace the new FRM I copy the program from VVDI to a new FRM but still have the above situation.. the problem on the car is not solved,, I think the problem is related to the software in the FRM module.. the module is still recognized signal is normal but headlight still not working.. If I use E SYS coding again, will it solve the problem??? and how to read on E Sys which program shows that the car is equipped with a halogen headlight lamp !! I am afraid that the FRM box has been affected by someone before in the program! Thank you so much everyone!!! |
