05-21-2018, 12:21 PM | #222 |
Rep 9,134
Wow.
The C is for Chunky ! |
M3 Adjuster7909.00 norMcal284.50 |
05-21-2018, 12:30 PM | #223 | ||
Rep 552
I'm no Sebastian Vettel, but I definitely noticed when I removed the sunroof on my track car. Granted the weight is in an unfavorable location, but it is also only 40 lbs, and was noticeable. Quote:
It's looking more and more like that for me as well. |
M3 Adjuster7909.00 M-Pilot4861.50 |
05-21-2018, 12:38 PM | #224 |
this is the way
18455
Rep 8,588
05-21-2018, 12:44 PM | #225 | ||
Rep 3,622
If the 2NH brakes are standard that is also a large portion of the weight, about 28 lbs over the standard blue brakes. Also I don't believe early reporting the 788M wheels are lighter. Personally believe they will end up being .5-1 lbs more weight per corner. |
05-21-2018, 12:45 PM | #226 | |
Rep 11,785
A stock BMW M4 is specified by BMW USA to be 3565 lbs... https://www.bmwusa.com/vehicles/m-mo...fications.html M3 CS is specified by BMW USA to be 3494 what we do know is.. a manual M2 competition weighs 35 lbs more than the manual M4 .. must be the lack of a CF roof.. Last edited by M3 Adjuster; 05-21-2018 at 12:53 PM.. |
1M Tex240.00 |
05-21-2018, 12:46 PM | #227 |
Rep 3,622
05-21-2018, 12:48 PM | #228 | |
this is the way
18455
Rep 8,588
05-21-2018, 12:50 PM | #229 |
Rep 11,785
well if It will only come with a heavy DCT.... I am not waiting for it..
the M4 GTS weight (DCT) is 3616 lb...... while a stock M4 DCT is 3620 lbs. . and the stock M2 competition is 3600 lbs already.... 3655 comparably equipped with a DCT not including water injection, or a roll cage. if the weight delta is the same... then if BMW begins wiith a 3655 lbs DCT M2 and in the process of making a CSL it only loses a similar 4 lbs... then BMW apparently will attempt to announce a 3650 lb + M2 CS (L) it seems.. at which point I would rather have an X3M. Even if they just make an M2 CS... and assuming it were to lose a similar 3620 to 3494 lbs (126 lbs) that still leaves a DCT equipped M2 CS at 3529 lbs.. bmw would be smart if they made an M2 CS with a 6MT and at least they might be able to get it under 3500 lbs... and yes.. I finf it very hard pressed for them to get close to the weight of the OG M2 N55. This is *exactly* why I have said the OG M2 Performance edition is probably the best version. if one wants a light weight M2 .. the M2 PE is the best place to start. Last edited by M3 Adjuster; 05-21-2018 at 01:28 PM.. |
05-21-2018, 12:53 PM | #230 |
Rep 3,622
It is actually more. I was using ETK listed weights for rotors/calipers.
http://f87.bimmerpost.com/forums/sho...3&postcount=39 |
05-21-2018, 01:01 PM | #231 |
#savethemanuals
2463
Rep 1,988
Options add weight. No options is the best route. If you want a light F8X find a low option F8X 6MT.
This DCT F80 weighs under 3600lbs http://f80.bimmerpost.com/forums/sho....php?t=1000776 Other weigh-ins. F80 vs E90 http://f80.bimmerpost.com/forums/sho...d.php?t=974479 Options matter http://f80.bimmerpost.com/forums/sho....php?t=1077612 |
M3 Adjuster7909.00 |
05-21-2018, 01:05 PM | #232 |
Rep 25,148
Curb weight 1658kg, did I miss something? No chance that is correct, but it can't be a type-o for lbs...what's going on?
My car made front page of Bimmerpost
05-21-2018, 01:10 PM | #233 | |
this is the way
18455
Rep 8,588
Only thing that could potentially throw the numbers off is if the rotors are thicker. I didn't see anything indicating they were. |
05-21-2018, 01:11 PM | #234 |
Rep 38
If you're concerned about the weight.
A. Buy something lighter. B. Wait for the lighter harder core model that will drop towards the end of production. C. Realize that you'd never be able to tell the extra weight behind the wheel if you weren't told before hand. D. Buy all the Carbon M. Performance bits so you can tell strangers on the internet and the 18 year olds at Cars and Coffee how much lighter the nose feels... Because they're the only ones who will believe you and believe that you spent that money well lol.. |
05-21-2018, 01:13 PM | #235 | |
Rep 11,785
1633 is the MT weight. which converts to 3600 lbs the DCT is 25kg more which is 55 lbs... and this corresponds to the prior US weight of the OG M2 of 3450 for manual (1564 kg) and 3505 for DCT (1589kg) BMW began with a 1M at 3295 lbs.. then brought out an M2 at 3450... now the M2 Competition has increased another 150 lbs... of which we already knew 55 kg (121 lbs) is the change in dry weight of the S55 and it's associated equipment alone.. Last edited by M3 Adjuster; 05-21-2018 at 01:22 PM.. |
05-21-2018, 01:15 PM | #236 |
#savethemanuals
2463
Rep 1,988
05-21-2018, 01:24 PM | #237 | |
Rep 11,785
JustChris17605.50 |
05-21-2018, 01:32 PM | #238 |
Rep 2,856
Drives: BMW M2 CSL Turbomeister
LOL ready this topic after five days of Mille Miglia....
What a discussion about a few kilos. MR |
05-21-2018, 01:39 PM | #239 | |
Rep 3,622
http://f87.bimmerpost.com/forums/sho....php?t=1497066 |
05-21-2018, 01:51 PM | #240 | |
this is the way
18455
Rep 8,588
Edit: The OP edited the thread a little while ago. Looks like the numbers changed, although don't know what his source is. : |
05-21-2018, 01:55 PM | #241 |
Rep 897
I considered an M2C but bought an M3 Comp pack instead. I didn't realise that the M2C would prove to be so controversial!!
2017 M3 Comp Pack 450PS
2017 C63S T 510PS |
05-21-2018, 01:56 PM | #242 |
Rep 429
I'm worried about the lower payload of the M2c. I cant fill the cabin up with a yard of bulk triple shredded anymore. It's not a man's car anymore.
HammerDahn28.00 |
