BIMMERPOST Universal Forums Site Related Announcements - Suggestions - Feedback - Questions Bimmerpost App 5.x WIP for Android
      01-29-2022, 07:24 PM   #221
apptest
all I do is test!
4616
Drives: I lost count of how many
For now it will follow the phone settings, but we will add it as an option down the road 👍
Test 23456rt
snowbimmer6640.00
siegester378.50
      01-29-2022, 10:30 PM   #222
SpeedBuggy
Comfortably Numb
SpeedBuggy's Avatar
Drives: '18 x1/'13 X3/'06 330i
2006 BMW 330i   [0.00]
Moto X3 Android 9
Was at Rev 5.1.18, downloaded 5.1.20, checking settings indicates version 5.1.1?? Not sure where I'm at now.
I'll watch for additional updates and download and check revision again.
Also, cannot change font size when composing a message, am I missing a setting or I'm I missing something altogether?
Thanks
06 e90 330i/Alpine White/Terra Dakota
13 F25 X3 xDrive 35i/Black Sapphire Metallic/Oyster Nevada
18 F48 X1 xDrive 28i/Black Sapphire Metallic/Black SensaTec
      01-30-2022, 12:03 AM   #223
apptest
all I do is test!
4616
Originally Posted by SpeedBuggy View Post
Moto X3 Android 9
Thanks
We were on the 5.0.x series but now in 5.1.x
Test 23456rt
      01-30-2022, 01:18 AM   #224
apptest
all I do is test!
4616
Initial classifieds support just released. More functionality to come
Test 23456rt
siegester378.50
      01-30-2022, 09:18 AM   #225
SpeedBuggy
Comfortably Numb
SpeedBuggy's Avatar
Thanks for the heads up, missed that.
      01-30-2022, 10:15 AM   #226
Kas63
Kas63's Avatar
Drives: 2020 X5 M50d
I'm sure it's right in front of me but I can't see where I can switch back to the light version. This current dark version is to dark for me, hard to read some of the text in bright light. Earlier versions were better, IMHO.
Any ideas how to revert back?
2020 M50d - Arctic Gray with Ivory White/Black Vernasca
      01-30-2022, 10:26 AM   #227
zcp312
///M
zcp312's Avatar
Drives: 2011 E90 M3 ZCP
Wow hello dark mode! That was quick, looks great!
      01-30-2022, 11:32 AM   #228
apptest
all I do is test!
4616
You can't turn it off, it will follow your system colors. But make sure you close the app completly and restart it to make sure you have tge correct color setup.
I've also just released a new version a few minutes ago (5.1.4) with some tweaked dark mode colors in the news and forums sections. Let me know if it's any better?
We are still learning dark mode
Test 23456rt
DrFerry7144.50
      01-30-2022, 11:37 AM   #229
DrFerry
Field Marshal
DrFerry's Avatar
Drives: '08 E92 M3
2008 BMW M3  [5.25]
2015 BMW X5  [4.50]
Thank you.
'08 E92 M3 DCT Melbourne Red/Bamboo Beige Leather/EDC/SSP Spec-R DCT clutch discs/SSP Pro-Gold DCT Fluid/Quaife LSD/3:45 Final Drive by Diffs Online/BE Bearings & ARP Bolts/Vibra Technics Engine Mounts/LUX H8 180/DCT Tune by BPM Sport/PFC Z-Rated Pads/ECS Brass Brake Caliper Bushings/Alex Shop Solid Sub-frame Bushings/Motul 600/Tint
      01-30-2022, 12:43 PM   #230
titomi
titomi's Avatar
Drives: X3 G01 30i xDrive
2018 X3 G01  [0.00]
Better I can trade settings easily. It's still a bit hard dor the timestamp of the pots and reputation count.
Maybe the appreciation icon could be a bit different (and still blue instead of the grayscale now).
'18 G01 X3 xDrive 30i xLine, Sophisto grey, Vernasca Mocha, Adaptive
      01-30-2022, 12:50 PM   #231
apptest
all I do is test!
4616
Ok I’m working on that now lets see if I can make it better
Side question: if you go to classifieds posts, does the location show up for you?
For example in this one does it say New York for the location?
https://f87.bimmerpost.com/forums/sh....php?t=1877289
Test 23456rt
      01-30-2022, 02:02 PM   #232
titomi
titomi's Avatar
2018 X3 G01  [0.00]
Yes,it does.
Side note ( ): the "network connection lost" screen is also hard to read in dark mode. I'm getting it almost every morning (CET time).
apptest4615.50
      01-30-2022, 02:05 PM   #233
titomi
titomi's Avatar
2018 X3 G01  [0.00]
Just so you know how the post you mentioned look like on my phone.
apptest4615.50
      01-30-2022, 02:59 PM   #234
apptest
all I do is test!
4616
Thanks much. Going to start working on making that dark mode.
As mentioned I'm not a usual dark mode haer myself, though I have to admit I'm starting to really like it.
But if you guys want to see dark mode darker or lighter or anything different I'm all ears ðŸ˜
Test 23456rt
      01-30-2022, 06:39 PM   #235
snowbimmer
snowbimmer's Avatar
2025 M850 GC  [9.50]
Lighter print. More white, less grey.
apptest4615.50
      01-30-2022, 06:59 PM   #236
apptest
all I do is test!
4616
Any screen in particular? Many areas are almost full blast white text. Do you mean for reading posts where it's an off blue color?
Test 23456rt
      01-30-2022, 08:09 PM   #237
siegester
siegester's Avatar
379
Drives: '20 M340i
2020 BMW M340i  [0.00]
Yeah, the contrast there is a little low. I personally find it fine, but would run it through an a11y tester to see if it passes.
A couple things I noticed. The "/THREAD" title shows up sometimes when scrolled to the top of a page. Start scrolling and the thread title appears.
In the latest version the thread title text is sometimes black.
When doing a select all & delete on quoted text (while making a post), an overlay seems to appear amd wash out the screen. I had to go back and start my post over again.
apptest4615.50
      01-30-2022, 09:08 PM   #238
apptest
all I do is test!
4616
When doing the delete, you did a select all and then pressed the backspace button?
Test 23456rt
      01-30-2022, 10:37 PM   #239
siegester
siegester's Avatar
379
Drives: '20 M340i
I had quoted a post on a previous page in addition to the post on the current page. I didn't want the previous quote in my post, so I manually selected a large block of quoted text ( I think it overlapped inside and outside the quote, but not sure) then hit delete. Thats when the overlay came up (I could see my text selector below the overlay). I couldn't take any actions, thus I used my phones back button to start over
apptest4615.50
      01-31-2022, 01:23 AM   #240
snowbimmer
snowbimmer's Avatar
2025 M850 GC  [9.50]
Regular thread pages seem better. You can change the font. I guess the lettering is a bit bluish - maybe a little more contrast needed? That's the first screen. The problem I have is in the Forum listings (2nd screen). The un-read post really stands out (love the white). The read post titles are ok (dimmed). The tiny print with the 3rd color is what's hard to see. Maybe I'm just being too picky. Thx.
apptest4615.50
      01-31-2022, 07:07 AM   #241
zcp312
///M
zcp312's Avatar
The thumbnail preview shows up on all forums, even though I have that setting disabled in settings. Pixel 6, Android 12 on 5.1.7
apptest4615.50
      01-31-2022, 11:56 AM   #242
Formermercowner
Drives: Bmw m4 2015
[QUOTE="Mark;28490743"]https://www.bimmerpost.com/forums/at...mentid=2792866
We are proud to release the first iteration in the 5.0 series of the Bimmerpost App available for all newer Android devices!
From the ground up
The 5.0 series represents a total ground up refresh of the app. Not a single line of code from the old app is here. As you might imagine, that has taken a really long time and we continue to work day and night on getting the 5.0 series up to snuff. Our goal is to make this the single best version of Bimmerpost you can use.
WIP = Work in Progress
Because we've started from scratch for this release we had to rebuild all the of what works back into the app. At the same time, we have been working to build in new functionality to take the app to the next level. In a sense, this App is on three parallel tracks:
Mirror existing features into the new app
Fix bugs
Add new features
At this point we've passed our internal threshold for >85% for mirroring of existing features and <1% for bugs. Of course the goal is 100% for mirroring existing features, 0% for bugs and the addition of new features is totally open ended.
We believe we will hit those end targets within 3 months.
We love to hear from you
Good or bad, let it fly... Let us know what you think of the app.
Love it? Awesome we need hugs too.
Found a bug? Post it up.
Hate the way something works? Post about it here
Missing a feature you used to use in the old app? Yup, post about it here.
This will only help us get to those issues faster and fix them.
Whats the most glaring issue right now?
Notifications tab. This is our area of current intense work right now. You might notice that your notifications counter isn't exactly accurate. Thats because on the back-end we've prepared the system for a new way of thinking and handling notifications. We will slowly roll this into the app over the next month, and will become more obvious in upcoming updates
*** Please note, when planning to upgrade to the new version, its highly encouraged you first delete the old app and re-install from scratch. Since this is a total rewrite of the app, we think its better if install with a fresh start for the best experience
Can you please add support for 120hz screens? Would help alot since scrolling is a big part of my usage in the app and a smoother experience would be nice. Other than that i appreciate the new modern and intuitive design! 👍
apptest4615.50
