BIMMERPOST Universal Forums Site Related Announcements - Suggestions - Feedback - Questions BIMMERPOST App 5.x Thread (iPhone/iPad/Android)
      01-21-2023, 08:55 PM   #221
snareman
Leave the gun. Take the Canoli.
snareman's Avatar
10368
Drives: ///M8 & X5 ///M60
Originally Posted by apptest View Post
Hmm, that is not good
No change on the algorithm. Let me look into this now,
Can you remind me, are you on iOS or android?
Android. Thanks
Current: 2023 ///M8 ||| 2025 X5 ///M60
Retired: 2023 X3 M40 ||| 2021 M4 ||| 2018 M4 ||| 2017 M4 ||| 2014 435 ||| 2009 335 ||| 2007 335
apptest4615.50
      01-21-2023, 09:03 PM   #222
apptest
all I do is test!
4616
Drives: I lost count of how many
Originally Posted by snareman View Post
Android. Thanks
Any info you can give me about the original image on your phone? Like the format (JPG, HEIC) or size?
Test 23456rt
      01-21-2023, 09:05 PM   #223
snareman
snareman's Avatar
10368
Here you go
apptest4615.50
      01-21-2023, 10:21 PM   #224
apptest
all I do is test!
4616
Here you go
Ok I just put a new release in the Play Store. It’s still called 5.5.4, but it is available now, try checking the play store to see if it lets you do an update. If not, it might take another hour to get to your local store, see if that version gives you as better image quality?
For sure the image quality was not great on the latest version, so I tweaked it and I saw an improvement on my test images
Test 23456rt
snareman10368.00
      01-21-2023, 10:30 PM   #225
snareman
snareman's Avatar
10368
Updated app...
(Edit: seems improved)
apptest4615.50
      01-23-2023, 09:12 AM   #226
Draper
Draper's Avatar
3505
Drives: M4 Comp / Macan Turbo
Good call, I propagated the fixes almost everywhere *except* new posts by accident. I have the fix for new posts done as well now, and will be in the next update 👍
5.5.4 working great! 🙏
Current: G82 M4 Comp xDrive // Frozen Deep Grey
Current: 95B.1 Macan Turbo // Dark Blue Metallic
apptest4615.50
DrFerry7143.00
      02-03-2023, 11:22 AM   #227
DrFerry
Field Marshal
DrFerry's Avatar
Drives: '08 E92 M3
2008 BMW M3  [5.25]
2015 BMW X5  [4.50]
I found an issue (glitch) while using the App on my iPhone 8 (yeah I know it's old).. I'm including some screen shots to try and explain what happens.
Issue:
When trying to type a post the screen area dedicated to text is limited by the App text formatting header and the iPhone keyboard. If one tries to write more text than can fit into the text write field then one gets locked into the writing field because one can not scroll down 'below or behind the keyboard. The scrolling function needs more than the space available or the cursor simply bounces back up above the keyboard. In other words, the scrolling feature only works above the keyboard and below the text header i.e. it isn't possible to see any text that has been written 'behind or below' the iPhone keyboard field. See images below.
'08 E92 M3 DCT Melbourne Red/Bamboo Beige Leather/EDC/SSP Spec-R DCT clutch discs/SSP Pro-Gold DCT Fluid/Quaife LSD/3:45 Final Drive by Diffs Online/BE Bearings & ARP Bolts/Vibra Technics Engine Mounts/LUX H8 180/DCT Tune by BPM Sport/PFC Z-Rated Pads/ECS Brass Brake Caliper Bushings/Alex Shop Solid Sub-frame Bushings/Motul 600/Tint
      02-03-2023, 10:09 PM   #228
apptest
all I do is test!
4616
Issue:
Interesting, let me test on an iPhone 8 tommroow and see what I come up with …
Test 23456rt
DrFerry7143.00
      02-04-2023, 11:39 AM   #229
jefe2000
jefe2000's Avatar
Drives: 2018 M2 6MT
2018 BMW M2  [10.00]
apptest Here’s a strange one for ya. The iOS BIMMERPOST app shows a very long gray area below the post linked below. I’ve scrolled for a very looooong time and never found the end of the gray region. I think it was scrolling the whole time though, because it took just as long to scroll back up out of the gray region to the post.
https://www.bimmerpost.com/forums/sh...php?p=28903473
apptest4615.50
      02-04-2023, 11:48 AM   #230
apptest
all I do is test!
4616
Good bug catch, I’ll fix that one today 👍
Test 23456rt
jefe2000859.00
      02-04-2023, 05:25 PM   #231
apptest
all I do is test!
4616
This is now fixed and will be in the next version 5.5.5. THnaks again
Test 23456rt
jefe2000859.00
      02-04-2023, 05:28 PM   #232
apptest
all I do is test!
4616
Issue:
Just to confirm, are you on the latest version of the app? 5.5.4?
I’m using it on an iPhone 8 right now and I can scroll this editor screen freely, meaning when the keyboard is covering my reply text, I can just scroll/swipe it up so that I can see the bottom of what I typed. Are you able to swipe it the text up so you can see the part of the text that is covered by a keyboard?
ANd also want to confirm you are using 5.5.4, there was a much earlier version where scrolling was a problem, I think 5.2 or 5.3
Test 23456rt
      02-04-2023, 05:37 PM   #233
'Cane
'Cane's Avatar
Drives: 2022 Aventurin/SS G82 xDrive
I’m on 5.5.4 (iPhone 14 Pro Max, iOS 16.3) and I clicked on the thread to check what he was talking about and had the same issue.
      02-04-2023, 05:47 PM   #234
apptest
all I do is test!
4616
You mean the endless grey area or not being able to scroll the post editor? (Endless grey area issue is confirmed bug and fixed)
Test 23456rt
'Cane10125.50
      02-04-2023, 05:51 PM   #235
'Cane
'Cane's Avatar
Yeah, that’s the one I was referring to. Sorry.
apptest4615.50
      02-04-2023, 08:43 PM   #236
DrFerry
Field Marshal
DrFerry's Avatar
Drives: '08 E92 M3
2008 BMW M3  [5.25]
2015 BMW X5  [4.50]
apptest Ironically I tried replying to your post with your questions above being quoted, but the amount of text was too large a paragraph and I got trapped in the reply field and unable to scroll below the last few lines of your and mine quoted text. The text field header and text field reply block bump into the top of the screen if trying to scroll up and the field bumps into the keyboard when trying to scroll down. Like now I’m wwriting blind and can’t see what I’m typing.
M5Rick70958.00
      02-04-2023, 08:45 PM   #237
apptest
all I do is test!
4616
Ok that’s an old version, can you try upgrading to 5.5.4 and see if it’s still happening?
Test 23456rt
DrFerry7143.00
      02-04-2023, 08:46 PM   #238
DrFerry
Field Marshal
DrFerry's Avatar
Drives: '08 E92 M3
2008 BMW M3  [5.25]
2015 BMW X5  [4.50]
apptest Okay 👍🏻
M5Rick70958.00
      02-04-2023, 08:57 PM   #239
DrFerry
Field Marshal
DrFerry's Avatar
Drives: '08 E92 M3
2008 BMW M3  [5.25]
2015 BMW X5  [4.50]
Okay, I just updated to the latest version and am quoting your and my text above. The cursor now appears in the correct spot. I’ll copy and paste this text and see if I get locked into the field and unable to scroll.
Oh look 👀 it’s working now. Nice and fast easy scrolling now. Well done. I still think the text formatting header is too large though. Do we really need the large “post a reply” label font and blue circle button? Those two alone take up 20% of the screen space not including the keyboard.
apptest4615.50
M5Rick70958.00
      02-04-2023, 09:08 PM   #240
DrFerry
Field Marshal
DrFerry's Avatar
Drives: '08 E92 M3
2008 BMW M3  [5.25]
2015 BMW X5  [4.50]
apptest On the post I just made with quoted text, I just noticed the little arrow allowing users to unroll hidden text quoted went missing on my post and a couple of others close by. What causes the little unroll text feature to sometimes work and sometimes not? See image.
M5Rick70958.00
      02-04-2023, 11:33 PM   #241
apptest
all I do is test!
4616
That post is just on the cusp of the size limit, a couple pixels on one side or another of the limit. Probably a miscalculation by the app
Test 23456rt
DrFerry7143.00
      02-05-2023, 08:59 AM   #242
DrFerry
Field Marshal
DrFerry's Avatar
Drives: '08 E92 M3
2008 BMW M3  [5.25]
2015 BMW X5  [4.50]
Thank you for taking the time to explain. I got to thinkin’ (which is always a little dangerous at my age), in the “old” App when replying to a post a box poped up without a formatting header taking up real estate. When posting using a browser only using “advanced mode” do text formatting options appear. I agree it’s an improvement and enhancement but perhaps improvement is subjective in the case of a phone app. By this I mean simplicity and elegance are also improvements. Just something to think 💭 about. Perhaps posting with the app could emulate the browser experience with a default simple plain text mode and also offer a “use advanced mode” button if users want to use the comprehensive text formatting header options? This would save space on smaller phone screens and perhaps simplify the default “post a reply” look 👀 and feel. Just my two cents..
apptest4615.50
M5Rick70958.00
