12-15-2011, 07:32 AM | #243 | ||
Rep 1,247
Drives: fat cars are still boats
Location: compensating a fat car with horsepower is like giving an alcoholic cocaine to sober him up.
It's not for chance that Porsche will only allow the fitment of the LSD from factory with 18 and 19" wheels. Yes. One thing called economy of scale. That's the reason why this car is a joint-venture project between Toyota and Subaru. |
12-15-2011, 07:51 AM | #244 |
Rep 3,888
GoingTooFast: Good work at promoting the GT86/BRZ on a BMW forum. It is a long time that BMW enthusiast have been waiting for such a car. The most hard thing will be going from a BMW badge to some japanese badge without premium. But true car enthusiasts as I, don't care about badges (anymore, since even a 2,5 ton SUV gets an M badge slapped to it).
PS: If the BRZ were a BMW it would cost twice. |
12-15-2011, 10:46 AM | #245 | |
Rep 1,247
I'm really a BIG fan of this Toyobaru... if BMW enthusiasts feel that the 1M is a sort of 'back-to-basics' machine, then what to say about this Toyobaru! In all honesty, the 1M is BMW's badge and own interpretation for a car like the Toyobaru in today's world and I'm positive that it won't get much better than this for a 4 seater. You can have a lighter 1M in the future but it will never be lighter than its japanese counterpart because that's the difference between 340 and 200hp, between 1570 and 1270kg, between double and half the cost. Who needs the extra weight and cost?! Not the true enthusiasts but those who need 4 true seats! And, that's the sole problem with this Toyobaru... it should have been a true 4 seater coupe and without any weight penalty except for the back passengers! Am I asking too much?! The answer lays in choosing between the 1M and this Toyobaru... I've chosen the 1M but I wish I didn't need back seats! |
12-15-2011, 12:55 PM | #246 |
Rep 1,680
If the BRZ is also called the "Toyobaru", the FR-S should be called "Subayota". The BRZ and FR-S look VERY similar, but with the right mods, the FR-S looks better.
Here's the FR-S btw. I'll just let the pictures do the talking...
Hellaflush? All I could say is "effyo'flush","flushnuff", and Instead of 'illest', I'm calling it "faillest". It's just form over function nowadays... -END RANT |
12-15-2011, 06:06 PM | #247 |
Rep 1,247
Very nice indeed. But try to find also a black BRZ (production model):
12-16-2011, 12:23 PM | #248 | |
Rep 1,247
I just want to add that there's more to it than just too much rubber (with 18 and 19" wheels) and relatively low power without LSD for such a good chassis like that in the Cayman which leads to understeer. The fact is that you can't switch off the DSC (Dynamic Stability Control) permanently, which is a petty! When the system detects a wheel speed difference, right and left, above a predetermined threshold it will actuate making the Cayman to understeer. Thus, a LSD would be of some assistance here too by retarding the DSC action. |
12-18-2011, 01:48 PM | #250 | |||
Rep 1,247
If Audi believes in compressor supercharging why wouldn't it be also feasible in this Toyobaru?
12-18-2011, 03:33 PM | #252 |
Rep 4,258
FI is not possible due to space restrictions. Take a look at that engine bay and consider how low that engine is mounted. You'd have to come up with some room there. There is definitely no room for the traditional TMIC. FMIC is possible but it will be tight.
///M Power
12-18-2011, 06:57 PM | #253 | |
Rep 1,247
Intercooler placement in the Toyobaru's engine bay would be critical. Traditionally, Subaru uses a hood scoop for air-to-air top mounted intercoolers (TMIC) located on top of the engine for their turbo versions: The Lotus Evora S, on the other hand, also has a non-intercooled Harrop HTV 1320 supercharger assembly (utilising Eaton Twin Vortex Series (TVS) Technology) BUT adds a pair of oil/water radiators mounted in the nose to cool it. In fact, the Eaton TVS supercharger, the same as used by Audi, was designed to not use an intercooler at low to medium boost levels and, actually, the lack of an IC improves throttle response. Moreover, TRD (Toyota Racing Development) Aurion was the world's first production car to use the Eaton TVS (Twin Vortices Series) supercharger: You can see its application on the Evora S (before and after): And there wasn't a lot of space either in the engine bay: Last edited by GoingTooFast; 12-18-2011 at 07:43 PM.. |
12-18-2011, 07:30 PM | #254 |
Rep 1,247
We can compare the BMW 1M twin-turbo to the supercharged Audi S4:
Engine Output: 1M................................................ ....... S4 335hp @ 5900 RPM................................. 333hp @ 5500-7000 RPM 332 lb-ft.* @ 1500-4500 RPM.................. 325 lb-ft. @ 2900-5300 RPM *An additional 37 lb-ft of temporary torque is delivered with the standard turbo boost function. Unladen Weight: 1M.................. S4 3362 lbs........... 3847 lbs Fuel Economy: 1M.................. S4 19 MPG............. 18 MPG (city) 26 MPG............. 27 MPG (highway) Both engines deliver practically the same power output from 3.0L and 6-cylinder and despite the Audi's weight disadvantage (485 lbs.) it manages to achieve the same fuel mileage as the 1M. Last edited by GoingTooFast; 12-18-2011 at 09:55 PM.. |
12-18-2011, 10:01 PM | #255 |
Rep 1,247
Levi,
I'm sorry to disagree, but the 1M does have lag whereas in the S4 it's virtually non-existent. That's the supercharger advantage. Last edited by GoingTooFast; 12-18-2011 at 10:06 PM.. |
12-18-2011, 11:57 PM | #256 | |
Rep 2,032
Drives: Red Flyer
If you look at this picture, you can see the engine cover that says "D4-S Boxer" on it doesn't even appear to clear the shock towers. Then when you see how much more space there is above those by looking at the fenders, it seems like they can fit a TMIC if they wanted to:
12-19-2011, 05:09 AM | #257 | |
Rep 1,247
Gladly, the Eaton TVS supercharger was designed without the need for an intercooler. |
12-19-2011, 05:24 AM | #258 |
Rep 1,247
As for the 1M against the S4 performance numbers, here they are:
1M......................... S4 155 MPH................. 155 MPH (Top Speed - electronically limited) 4.7 sec................... 4.9 sec (0-60 MPH ) |
12-19-2011, 05:54 AM | #260 | |
Rep 3,888
12-19-2011, 08:38 AM | #261 | |
Rep 4,258
Not only do we need to fit (a very thin) TMIC in there, we have to fit all the necessary connecting hardware, not to mention the bulky turbo inlet tube. If it does happen I will be extremely impressed (but ultimately worried about cooling). Thinking about it now, I agree with many of the other posters here saying that a S/C would be the way to go. A turbo would be pretty silly on a car that's main focus is on track handling. Turbo would just introduce lag and heat soak. Though, I doubt we will ever see a S/C if this car is to go FI. Simply due to emissions and fuel consumption. This is still a (generally uninspired) mainstream manufacturer we are talking about here.
///M Power
12-19-2011, 10:04 AM | #262 |
Rep 1,247
In order for the Toyobaru to be faster in the Nurburgring circuit it needs a supercharger.
See the Toyota TDR Aurion engine (3.5-litre V6, port fuel injection, high compression rate of 10.8:1): Although the Eaton supercharger unit does not require an intercooler at low to medium boost levels, the 3.0-liter V6 TFSI unit from Audi works with a boost pressure of up to 0.8 bar which is higher than the modest 0.4bar (5.5 psi) used by the TRD Aurion's engine. Therefore, two water-to-air intercoolers connected to a separate coolant circuit are integrated into the supercharger housing in the Audi's engine: The Eaton TVS supercharger: Last edited by GoingTooFast; 12-20-2011 at 12:54 PM.. |
12-19-2011, 10:17 AM | #263 | |
Rep 1,247
With the added boost in the Evora S the power output went to 345hp from only 276hp in the non-supercharged version and without intercooler. Last edited by GoingTooFast; 12-19-2011 at 11:48 AM.. |
12-19-2011, 10:40 AM | #264 | |
Rep 4,258
///M Power
