04-03-2024, 08:44 AM | #2663 | |
Remove Before Flight
8265
Rep 1,654
Google SAGE (Semi-Automatic Ground Environment)-- and it cost more than the Manhattan Project. This was a system in the '50's - 80's that provided semi-real-time radar coverage over the entire US and parts of Canada that essentially watched for the Soviet's coming over the horizon using nuclear-armed bombers. It was extremely high-tech for the day and provided the ability to give Ground to Air guidance to interceptors (including the F-101). The buildings were MASSIVE-- they called them blockhouses and they were hardened against NuDet. I don't know if they would have survived a nuclear strike in the '60's, but I wouldn't bet against them. The one at McChord AFB (near Tacoma) is still there. The concrete was so thick that they couldn't afford to destroy it..... so they turned part of it into the base library. The concrete where they (eventually) cut windows in is *really* thick (measured in feet, not inches). Since my father was the Base Commander there at one time, I got to wander around inside a bit when they were doing the conversion-- that building is HUGE, and is a part of history that's mostly forgotten. R. https://en.wikipedia.org/wiki/Semi-A...nd_Environment https://en.wikipedia.org/wiki/SAGE_radar_stations https://military-history.fandom.com/...nd_Environment
Current: F87 M2C, Miata RF-GT, RDX & Element // R1200GS & VRSCF
Previous: E46 M3, Focus ZX3-S2, Superchaged Solara, Samurai, Integra, Pinto & RX-4 // VRSCR, R6S, FZ1 & FZ600 |
04-03-2024, 09:32 AM | #2664 |
Rep 1,045
The SAGE DC-02 blockhouse at KSWF is still standing and unused. The inside is supposedly like a time capsule of the cold war, with furniture and stuff still in place.....
04-04-2024, 05:38 AM | #2665 |
![]() ![]() ![]() ![]() 24020
Rep 805
Just in case the strategic bomber business did not pan out
'25 M850ix GC
BMW CCA 31 years |
04-04-2024, 06:26 AM | #2666 |
Rep 805
A special Tomcat Thursday today. Before Tommy got two tails, he apparently had just one -- along with large ventral fins for stability.
Here are the photos of an early mockup -- 1967? Earlier?
'25 M850ix GC
BMW CCA 31 years Last edited by Llarry; 04-04-2024 at 08:05 AM.. |
04-04-2024, 08:37 AM | #2668 |
Rep 805
Here's a rare aircraft with an interesting story. The Vietnam War resulted in the loss of many RF-101C Voodoo (single-seat) photo recon aircraft. Despite the fact that the USAF was buying more modern RF-4Cs, they felt the shortage of RF-101s. In 1971-72 they converted 22 ex-RCAF F-101B interceptors to RF-101B photo recon aircraft and equipped a squadron of the Nevada Air National Guard with those airplanes for three years, after which RF-4Cs replaced the RF-101Bs.
'25 M850ix GC
BMW CCA 31 years |
04-04-2024, 08:45 AM | #2669 | |
Rep 1,045
Somebody apparently forgot to tell Ghostrider that the pattern was full.....
![]() https://news.yahoo.com/faa-probing-c...025314858.html Quote:
BMWGUYinCO4462.50 Nighthawks813.50 |
04-04-2024, 07:39 PM | #2671 | |
![]() ![]() ![]() 5934
Rep 5,922
vreihen1623731.50 Nighthawks813.50 |
04-05-2024, 06:22 AM | #2672 |
Rep 805
Thirty-plus years ago, the U.S. Air Force decided that Tactical Fighter Squadrons and Fighter Interceptor Squadrons would now just be called Fighter Squadrons.
Last month, though, the 18th Aggressor Squadron in Alaska, which flies F-16s, was redesignated as the 18th Fighter Interceptor Squadron. They will probably lose their spiffy paint jobs. ![]() I'm thinking this may presage the redesignation of a number (fewer than ten) of fighter squadrons that specialize in air defense as Fighter Interceptor Squadrons. Offhand, that would include current F-15C units in Oregon, California, Massachusetts and Florida, some of which will get F-15EXs. What's old is new again. EDIT: I've added a photo of one of the squadron's aircraft in the new plain livery.
'25 M850ix GC
BMW CCA 31 years Last edited by Llarry; 04-06-2024 at 09:52 AM.. |
04-06-2024, 05:42 AM | #2673 |
Rep 805
After some years of negotiations, one of the ex-USN Martin JRM Mars flying boat firefighting water bombers has found a new home. C-FLYL "Hawaii Mars" will be carefully prepared for a final flight to the British Columbia Aviation Museum -- probably late this year. The aircraft has not flown much in the last ten years or so; thorough checks need to be made of all systems.
The disposition of the other two surviving aircraft is not yet clear.
'25 M850ix GC
BMW CCA 31 years |
04-08-2024, 07:19 PM | #2674 |
Rep 805
And then there were none...this is the very last U.S. Coast Guard seaplane in service. A Grumman HU-16E Albatross that was retired from the Cape Cod station in 1983. (The last Navy HU-16E was retired in 1976.)
'25 M850ix GC
BMW CCA 31 years Last edited by Llarry; 04-08-2024 at 10:23 PM.. |
04-08-2024, 08:13 PM | #2675 | |
![]() 2784
Rep 1,779
https://www.ll.mit.edu/about/history...defense-system |
04-08-2024, 08:17 PM | #2676 | |
![]() 2784
Rep 1,779
04-09-2024, 06:28 AM | #2677 | |
Rep 805
![]() Oregon 20 Fresno 20 Florida 20 Seymour-Johnson AFB schoolhouse 20 which leaves enough for one more squadron... Both Mass and Louisiana fly the F-15C now, but Wikipedia (not an unimpeachable source) says it's Louisiana. It appears that Massachusetts loses out on the F-15EX. Unless Congress does their thing. There's also been some pipe-dreaming about putting two active F-15EX squadrons in Okinawa to replace F-15Cs. I believe one of two 18th Wing F-15C squadrons is already gone and the other is on life support. So far, the plan has seen temporary deployments from elsewhere. A case could be made that reducing forces in Okinawa in the current climate with China is not a good move. ![]()
'25 M850ix GC
BMW CCA 31 years Last edited by Llarry; 04-09-2024 at 08:30 AM.. |
04-09-2024, 06:03 PM | #2678 |
![]() 2784
Rep 1,779
Okinawa has transient fighters like back in the day of Air Expeditionary Wings. DUMB. They are slated for F35A's but that will take some time.
104Th has C/D models that are ancient they are 77 and I think the newest airframe is an 80, edit I see four 85's. |
04-09-2024, 06:30 PM | #2679 |
![]() 28222
Rep 1,713
Time "fly" when you are having fun... https://ottawa.ctvnews.ca/mint-marks...coin-1.6840342
04-09-2024, 06:39 PM | #2680 |
![]() 88162
Rep 1,081
And the return of "Sic itur ad astra" replacing "Per ardua ad astra."
https://www.canada.ca/en/department-...rce-badge.html |
04-10-2024, 06:11 AM | #2681 |
Rep 805
The world's first variable-sweep design was a World War II-era Messerschmitt design that never flew. But it inspired a design that did fly and had the world's first variable-sweep wing: The Bell X-5, which first flew in 1951. As indicated by the X designation, it was strictly an experimental aircraft and only two were built. One was lost in an accident and the survivor is in the National Museum of the USAF.
'25 M850ix GC
BMW CCA 31 years |
04-10-2024, 06:12 AM | #2682 |
Rep 805
Tomcat Thursday!
![]() Although we sometimes forget that combat aircraft are associated with death and destruction, the insignia of VF-101's predecessor, Fighting Ten (VF-10) "Grim Reapers" left no doubt that bloodletting was part of the mission.
'25 M850ix GC
BMW CCA 31 years Last edited by Llarry; 04-10-2024 at 10:30 AM.. |
04-10-2024, 07:28 AM | #2683 |
Rep 805
Here's an important aircraft not often seen in this thread: A Ukrainian air force Su-27 Flanker. 2018 photo.
According to Flight Global's World Air Power 2024, there are 1,243 aircraft of the Su-27 family (including Su-30, Su-34, Su-35 and Chinese J-11) operational at present, making the Flanker the second most numerous fighter active -- second only to the F-16. I count a dozen operators including -- surprise! -- the USA. Two examples were obtained from Belarus some years ago and are/were active in the Nevada desert ranges.
'25 M850ix GC
BMW CCA 31 years Last edited by Llarry; 04-10-2024 at 07:42 AM.. |
04-12-2024, 05:08 AM | #2684 |
Rep 805
A day late posting this (but, hey, I was a day early for "Tomcat Thursday" so it all evens out, right?) but 65 years ago yesterday the Northrop T-38 Talon first took flight. This is a photo of the second prototype YT-38A.
The replacement T-7A is coming, but the T-38 has rendered honorable service for many decades -- no doubt training both fathers and sons or daughters. ![]()
'25 M850ix GC
BMW CCA 31 years |
