BIMMERPOST Universal Forums Off-Topic Discussions Board Photography/Videography *OFFICIAL* general photography conversation thread
      04-18-2012, 12:31 PM   #3081
The1
Drives: white 135
Mark, did you have the camera jammed up agaist your face or just placed against it? One hand under to stabilize?
      04-18-2012, 12:57 PM   #3082
dcstep
Drives: '09 Cpe Silverstone FR 6MT
2009 M3  [8.40]
Originally Posted by M_Six View Post
No, I was just being a dunce. I went to f11 to get a nice deep DOF, but that brought me to 1/60 SS at ISO 100. I should have bumped the ISO to 400 and got a faster SS. For the macros I just need to get a tarp or something else to lay on so I can hold the camera steady.
1/60 should have been fast enough for hand holding, with good technique. For scenics, I'd rather shoot at ISO 100 and pull out the tripod if needed. Still, even without IS, you should be able to hand hold for a static subject.
Dave
      04-18-2012, 12:59 PM   #3083
The1
Drives: white 135
Depending on forcal length too thoug.
      04-18-2012, 01:13 PM   #3084
dcstep
2009 M3  [8.40]
Yeah, like this 500mm shot hand held at 1/250-sec.:
Curious yearling. by dcstep, on Flickr
The lens DOES have IS.
      04-18-2012, 01:22 PM   #3085
Originally Posted by Chewy734 View Post
ahh... well, at least your way is much cheaper. Still pondering the 5D2?
I'm on the fence. I had a refurbed MkII in my cart at the Canon Store the other day. It would have been just under $1500 shipped with the coupons they had running. But I just can't justify that expenditure right now.
Dave
Yeah, normally that works ok. I mean the shots weren't too fuzzy, but I was trying to crop quite a bit so I really needed some serious sharpness. And I was having the hardest time holding still this morning. I needed the higher SS.
These were probably 60mm or so. The SS I had should have been enough, except as I said above, I was not too steady this morning.
Crap! Just checked my lens. I had shut the IS off the other day when I was shooting from the tripod with the stacked filters and never turned it back on. D'oh!!
      04-18-2012, 02:22 PM   #3086
dcstep
2009 M3  [8.40]
That'll do it.
      04-18-2012, 11:47 PM   #3087
Better light this afternoon *and* IS turned on.
Corn Begins
      04-21-2012, 05:31 PM   #3088
Got my Katzeye yesterday and installed it today. Do not try this without a good lighted magnifying lens if your eyesight isn't really good. I have a so-so lighted magnifier and it was a royal pain trying to see what I was doing.
That said, I did eventually get it installed properly and I think if I have to do it again, it would be easier. I'm fairly happy with the results. Below are some comparison images with 100% crops.
Auto focus and 100% crop.
Manual focus and 100% crop
One more manual focus with crop.
      04-22-2012, 02:25 AM   #3089
rodi
192
Drives: your FACE!
what did you put it in, Mark? does it have a split-prism/micro-collar?
i got a Brightscreen one for my D3, since Katzeye didn't make on for that cam. Althought i got a katzeye for my ex-girlfriend's D40 years ago that worked wonderfully.
i wish someone will make a split-prism screen for the 5D3 and still keep all the AF features/VF display.
2009 135i | space grey | sport | navi | hifi | heated
dinan stage 2 software | bmw performance exhaust
kw v2 | hotchkis front sway | vmr v710
      04-22-2012, 09:43 AM   #3090
Chewy734
Drives: 2006 BMW 330i ZPP, ZSP
I heard the 5D3 has a fixed focusing screen that you can't replace, unlike the 5D2. Correct me if I'm wrong...
      04-22-2012, 10:37 AM   #3091
It's in the T1i. It's the split-prism/micro-collar. I thought the split-prism part would be the most useful, but I'm finding the micro-collar is easier and more accurate in many cases. Unless there is a sharp vertical line in the image, the split-prism isn't of much use.
I ordered a Roki 85mm f1.4 to see how the longer focus throw works. The problem with my existing lenses is the point between OOF and sharp focus is a tiny movement of the ring. Something with a longer throw would make it easier to adjust to a really fine focus, I think.
      04-24-2012, 12:00 PM   #3092
I picked up a Roki 85mm f1.4. It has a really nice, long focus throw. Super easy to MF this thing. Love the DOF wide open.
      04-24-2012, 12:15 PM   #3093
The1
Drives: white 135
nice. should have some good fun with that piece.
      04-24-2012, 12:17 PM   #3094
It's amazing how cheap Roki MF lenses are considering the build quality. Next up is the 14mm f2.8 I think.
      04-24-2012, 12:26 PM   #3095
The1
Drives: white 135
are they EF mounts or EF-S only?
14 is nice and wide!
      04-24-2012, 12:34 PM   #3096
dcstep
2009 M3  [8.40]
I'll be happy if, like with the 7D, you can put an electronic grid in the viewfinder. I use that a lot to make sure that horizons are straight and also as a compositional guide.
Dave
      04-24-2012, 12:38 PM   #3097
dcstep
2009 M3  [8.40]
Nice bokeh.
      04-24-2012, 12:39 PM   #3098
Good question. I know the 8mm FE is APS-C only. Not sure about the 85mm.
The mount is EF, but I'm not sure about the image circle size.
      04-24-2012, 12:39 PM   #3099
Dave
I love the grid in the 7D. Mine stays on all the time. Very easy to keep a straight horizon.
      04-24-2012, 12:41 PM   #3100
The1
Drives: white 135
has it got a red marker dot or a white one? or since it's not a canon specific lens, they likely don't do that...
      04-24-2012, 12:43 PM   #3101
The1
Drives: white 135
Dave
that grid is a nice touch, it isn't too intrusive.
on my 5DII I use 2 of the focus points as my bearings for lining up the horizons, but as on the 7D, the camera only shows the active focus point, I need to rely on the grid more
(I could be wring, it's been a few days since I touched my 7D)
      04-24-2012, 01:10 PM   #3102
Red dot, but the 8mm FE has a red dot, too.
I just checked Rokinon's site. The 35mm f1.4 and up will work on FF. The 8mm and 14mm are APS-C only.
