07-29-2023, 04:41 AM | #3279 |
Rep 22,082
///M Power-Belgium70384.50 Car-Addicted8233.50 Efthreeoh19032.00 KRS_SN14624.00 DrFerry6884.50 Murf the Surf21125.50 Germanauto9840.50 |
07-29-2023, 05:49 AM | #3280 |
Rep 22,082
EV's are in crises with the fire balls happening that's not being addressed by the gubments, they have no answer to this.
07-29-2023, 06:00 AM | #3281 |
Rep 5,070
Car-Addicted8233.50 M5Rick68581.00 ///M Power-Belgium70384.50 PhaceN52177.50 DrFerry6884.50 Murf the Surf21125.50 |
07-29-2023, 06:14 AM | #3282 |
Rep 2,377
Drives: 2020 BMW M4 CS
Good news folks, The Chinese manufacture around 90% of our pharmaceuticals
What could possibly go wrong? |
07-29-2023, 06:25 AM | #3283 |
Rep 22,082
07-29-2023, 06:43 AM | #3284 |
Rep 26,602
Developed in the Covid lab ?
"MAX VERSTAPPEN" IS THE 2021+2022+2023 F1 WORLD CHAMPION - #UnLeashTheLion
BPM DEV-Tune & DCT Software-Tune & Servotronic & coding ///Alpine HID Angeleyes ///Oem.exhaust mod. |
07-29-2023, 07:01 AM | #3285 |
Rep 196
The flamethrower at 5:51 and the elevator fire seem particularly safe, something I can't wait to deal with.
07-29-2023, 07:38 AM | #3286 |
Rep 2,377
House Bill HR EVFire will force all EV owners to watch this video prior to signing contract for EV.
KRS_SN14624.00 ///M Power-Belgium70384.50 DrFerry6884.50 Murf the Surf21125.50 PhaceN52177.50 M5Rick68581.00 |
07-29-2023, 07:58 AM | #3287 | |
Rep 19,655
A manual transmission can be set to "comfort", "sport", and "track" modes simply by the technique and speed at which you shift it; it doesn't need "modes", modes are for manumatics that try to behave like a real 3-pedal manual transmission. If you can money-shift it, it's a manual transmission. "Yeah, but NO ONE puts an automatic trans shift knob on a manual transmission."
07-29-2023, 08:00 AM | #3288 | |
Rep 19,655
07-29-2023, 08:43 AM | #3289 |
Field Marshal
6885
Rep 1,881
Drives: '08 E92 M3
Running your Tesla off a Honda generator in the trunk...
https://youtube.com/shorts/_si36bGHnbc?feature=share and https://twitter.com/anandmahindra/st...340278784?s=20
'08 E92 M3 DCT Melbourne Red/Bamboo Beige Leather/EDC/SSP Spec-R DCT clutch discs/SSP Pro-Gold DCT Fluid/Quaife LSD/3:45 Final Drive by Diffs Online/BE Bearings & ARP Bolts/Vibra Technics Engine Mounts/LUX H8 180/DCT Tune by BPM Sport/PFC Z-Rated Pads/ECS Brass Brake Caliper Bushings/Alex Shop Solid Sub-frame Bushings/Motul 600/Tint
07-29-2023, 08:50 AM | #3290 | |
Rep 26,602
07-29-2023, 09:25 AM | #3291 | |
Rep 19,655
The Chevrolet Volt was the near perfect solution IMO, none have engine maintenance issues and in gas-only mode still returned 37 (Gen 1) - 42 (Gen 2) MPG. The combined EV/gas MPGe was 93 (Gen 1) and 106 (Gen 2) and better than the Prius (parallel hybrid). Detractors of the serial hybrid solution point to such a vehicle having a "complex" drivetrain, surely the Voltec drivetrain was complex since the planetary gear transmission allowed the ICE to directly power the drive wheels in some modes. But the Voltec drivetrain is quite robust and has very little failure issues. It works quite well. The reason it didn't sell better than it did is because sadly the majority of the driving public couldn't understand the technology, and sadly the Volt has the GM quality/American car company monkey on its back. Also, the majority of the driving public think the EV drivetrain is less complex than ICE. I disagree with that sentiment. While the EV motor maybe less complex than an internal combustion engine because it uses less parts and has less rotating/moving parts and there is no transmission, the EV drivetrain requires complex electrical current management and charging modules that trade machined parts for electronic components. EVs, especially Tesla, have quite complex heat management systems (equipment) to support battery temperature management and cabin HVAC management. Any subsystem with parts in it has a meantime-between-failure and will break and require repair or replacement. Any component that heat cycles eventually wears out and breaks. On top of the EV drivetrain complexity issue, EVs require an expensive and complex charging infrastructure to be set up and maintained. Drawing current out of a battery is no less complex than moving current into the battery. So, the EV carries a charging module on-board (weight-cost-reliability) it also requires a charging machine dockside to recharge it (availability-cost-reliability). So IMO, saying the BEV drivetrain is simpler and more reliable is BS. Again, most of the driving public does not understand the complexity of the BEV and equate it to just plugging in their cell Phone every night to recharge it. The majority of the driving public think the ICE drivetrain is more complex than BEV because it makes noise, gets hot, makes exhaust, and requires slightly more periodic maintenance, on top of they have no idea actually how an ICE operates. If their cell phone needed a tiny noisy ICE-powered charger on their nightstand to charge their phone they'd think their phone was an atrocious planet killer too. But since electricity is a clean fuel available at their wall outlet, and silently charges their cell phone while they sleep, it's no harm to the planet. Most people don't understand all the noise, emissions and complex machinery that requires repair and periodic maintenance to make that "clean" energy at the wall outlet exists out somewhere in the rural landscape where they don't see or hear it (windmills included). Regarding the killing oneself, December 2009 was when the US EPA declared CO2 a "dangerous pollutant". Last time I checked I exhale CO2, so shit, I'm killing the planet just by breathing. Easy to do the math after that (if one believes in anthropogenic climate change). But I'm not insane like this person was... https://en.wikipedia.org/wiki/Self-i..._of_Wynn_Bruce To live life, a whole bunch of chemical reactions happen every second. Every chemical reaction has waste heat (including the ones needed to make this post). Waste heat is killing the planet according to the Globalwarmingclimatechange Fearers.
///M Power-Belgium70384.50 Car-Addicted8233.50 Murf the Surf21125.50 kyriian959.50 M5Rick68581.00 DrFerry6884.50 |
07-29-2023, 09:31 AM | #3292 |
Rep 2,377
07-29-2023, 09:43 AM | #3293 |
Rep 19,655
That generator will take a week to charge that Tesla.
07-29-2023, 09:52 AM | #3294 |
Rep 2,377
Got me thinking, It not like you can call AAA for a can of gas or a tow for a EV?
Well here is the answer. There are certain complications that apply only to electric-powered vehicles. Most electric vehicles don’t have a true neutral position in their transmissions. Because of this, moving the wheels can cause the motor to turn as well, which can damage the engine. EVs generally require flatbed towing to prevent this type of damage. Rather than requesting a tow, you can ask for a charging truck. AAA now offers mobile electric vehicle charging in 15 cities across the country. |
Murf the Surf21125.50 DrFerry6884.50 Efthreeoh19032.00 ///M Power-Belgium70384.50 KRS_SN14624.00 M5Rick68581.00 |
07-29-2023, 10:02 AM | #3295 |
Rep 2,377
Things that make you go Hmmmm.
The disapproval of Elon Musk is the top reason Tesla Model 3 owners are selling their electric vehicles and going for another brand, according to a new survey of 5,000 Model 3 owners. Musk becoming more political is clearly having a negative impact, but it’s overall minimal when compared to the 87% of Model 3 owners still looking at a Tesla for their next vehicle. https://electrek.co/2023/07/27/disap...elling-survey/ |
07-29-2023, 11:02 AM | #3296 | |
Rep 19,655
07-29-2023, 11:04 AM | #3297 | |
Rep 19,655
07-29-2023, 12:26 PM | #3298 |
Rep 2,377
The Greenies are likely to be a very a fickle market. We can see that they are more influenced by emotion that facts. Me, if I had Ferrari money I wouldn't care if Mussolini was still Prime Minister of Italy, there would be a Ferrari in my garage.
Murf the Surf21125.50 DrFerry6884.50 |
07-29-2023, 12:58 PM | #3299 |
Rep 1,746
Car-Addicted8233.50 |
07-29-2023, 01:02 PM | #3300 | |
Rep 1,746
Efthreeoh19032.00 Car-Addicted8233.50 |
