02-23-2025, 07:50 AM | #3565 | |
![]() 20470
Rep 7,568
02-23-2025, 01:34 PM | #3566 |
![]() 12866
Rep 2,014
2024 Mercedes Benz GLC300 Has it been 4 years yet? |
02-23-2025, 02:46 PM | #3567 | |
![]() 87795
Rep 1,080
02-23-2025, 03:40 PM | #3568 |
![]() 2776
Rep 1,771
My Dad's last duty station was South Weymouth Naval Air Station. It too was at one time a blimp base. He was no longer flying when he got there in 68. I was born not far from there in late 66 case of Dad leaving for Vietnam.
![]() Used to go to all the airshows and we sat in the flying squadron seats. |
02-24-2025, 09:14 AM | #3569 |
![]() ![]() ![]() ![]() 23938
Rep 805
One of the U.S. Navy's most unusual squadrons is Air Test and Evaluation Squadron 30 (VX-30) "Bloodhounds" based at Point Mugu, California.
VX-30 used a number of P-3 Orions for many years for range clearance and surveillance in the Pacific missile test range. Those P-3s are now gone or nearly so, leaving the squadron with three aircraft types: Lockheed KC-130T Hercules refueling aircraft (ex-Marine Corps), Northrop Grumman E-2D Hawkeye airborne warning and control aircraft and a single NC-20G Gulfstream IV. As indicated by the N prefix, the NC-20G has been modified for test work.
'25 M850ix GC
BMW CCA 31 years |
02-25-2025, 09:41 AM | #3570 | |
![]() 12866
Rep 2,014
engine. Way ‘mo better than the early versions: https://cessna.txtav.com/en/piston/c...B&gclsrc=aw.ds
02-25-2025, 01:37 PM | #3571 |
![]() 87795
Rep 1,080
WHOA...!!!
" Southwest flight barely misses collision at Chicago Midway International airport" VIDEO: https://www.nbcchicago.com/news/loca...rport/3682589/ |
02-25-2025, 02:17 PM | #3572 | |
![]() 12866
Rep 2,014
vreihen1623666.50 |
02-25-2025, 02:46 PM | #3573 | |
Rep 1,045
M-technik-32776.00 |
02-25-2025, 03:24 PM | #3575 | |
![]() 12866
Rep 2,014
an errant pilot to “Pick up the phone at the base of the tower” after he parked his airplane.
vreihen1623666.50 |
02-25-2025, 08:09 PM | #3576 | |
Rep 13,500
27 March 1977 - Los Rodeos Airport (Tenerife North Airport): KLM Flight 4805 impacting the right side of Pan Am Flight 1736. 583 fatalities. ![]() "Collision According to the cockpit voice recorder (CVR), the Pan Am captain said, "There he is!" when he spotted the KLM's landing lights through the fog just as his plane approached exit C4. When it became clear that the KLM aircraft was approaching at takeoff speed, Captain Grubbs exclaimed, "Goddamn, that son-of-a-bitch is coming!", while first officer Robert Bragg yelled, "Get off! Get off! Get off!" Grubbs applied full power to the throttles and made a sharp left turn towards the grass in an attempt to avoid the impending collision. By the time the KLM pilots saw the Pan Am aircraft, they had already exceeded their V1 speed and were moving too fast to stop. In desperation, the pilots prematurely rotated the aircraft nose upward and attempted to clear the Pan Am by lifting off, causing a 22 m (72 ft) tailstrike. The KLM 747 was within 100 m (330 ft) of the Pan Am and moving at approximately 140 knots (260 km/h; 160 mph) when it left the ground. Its nose landing gear cleared the Pan Am, but its left-side engines, lower fuselage, and main landing gear struck the upper right side of the Pan Am's fuselage, ripping apart the center of the Pan Am jet almost directly above the wing. The right-side engines crashed through the Pan Am's upper deck immediately behind the cockpit, instantly killing all of the passengers seated there. The KLM plane remained briefly airborne, but the impact had sheared off the outer left engine, caused significant amounts of shredded materials to be ingested by the inner left engine, and damaged the wings. The plane immediately went into a stall, rolled sharply, and hit the ground approximately 150 m (500 ft) past the collision, sliding down the runway for a further 300 m (1,000 ft). Upon impact with the runway, the full load of fuel, which had caused the earlier delay, ignited immediately into a fireball that could not be subdued for several hours. One of the 61 survivors of the Pan Am flight said that sitting in the nose of the plane probably saved his life: "We all settled back, and the next thing an explosion took place and the whole port side, left side of the plane, was just torn wide open." Veldhuyzen van Zanten was KLM's chief of flight training and one of their most senior pilots. About two months before the accident, he had conducted the Boeing 747 qualification check on the first officer of Flight 4805. His photograph was used for publicity materials such as magazine advertisements, including the inflight magazine on board PH-BUF. KLM had suggested initially that Veldhuyzen van Zanten should help with the investigation, unaware that he was the captain who had been killed in the accident." (source: https://en.wikipedia.org/wiki/Tenerife_airport_disaster) Further to this horrific accident, 'crew resource management' or 'cockpit resource management' was introduced or at least streamlined. "Lessons Learned from the Tenerife Airport Disaster" (Aug 18, 2020): https://incident-prevention.com/blog...port-disaster/
///M is art ↔ Artemis
02-26-2025, 01:24 AM | #3577 |
Rep 805
During World War II, it became clear that jet-powered aircraft had good potential for high performance. But they also suffered from slow initial acceleration. In 1943, the U.S. Navy contracted with Ryan to design and test a composite fighter with both piston and jet engines. The Navy ended up buying 66 Ryan FR-1 Fireball fighters -- only enough to equip a single squadron. The FR-1 only served for a short period after the end of the war in 1945. Its performance did not match contemporary piston fighters such as the F6F Hellcat, F8F Bearcat or F4U Corsair.
'25 M850ix GC
BMW CCA 31 years |
02-27-2025, 05:28 AM | #3578 |
Rep 805
The U.S. Air Force bought 180 T-1A pilot trainers. Of those, half have been retired, and the Air Force plans to retire the other half over the next year or two. VR and simulators will fill the void and prepare pilots for their final assignments.
Does this sound wrong to anybody else? ![]()
'25 M850ix GC
BMW CCA 31 years |
02-27-2025, 07:13 AM | #3579 |
Rep 1,045
Having a meat-based control interface inside of an airplane is soooooo 20th century. Drones flying either autonomously or via remote control from a central video game room on the ground are going to be the future of the Chair Force.....
M_Six20469.50 |
02-28-2025, 03:42 AM | #3580 |
![]() ![]() 6218
Rep 5,869
Drives: Beige G31 540ix m sport
A Lancaster flew over my house & despite hearing the four Rolls Royce Merlin’s before it came into sight by the time I’d found my phone, gone outside & switched to camera these were the best pics I was able to take.
G31 40ix M Sport
E92 335i. E36 328is coupe E39 540i V8 6SP manual E34 3.6 M5. E34 525i sport. VW Jetta Mk2 GTI 16v. 1679cc 1967 resto-cal beetle |
11
02-28-2025, 06:25 AM | #3581 | |
![]() 87795
Rep 1,080
In the past, many training flights took place in other aircrafts. For example, my dad's Sabre training took place in a T-Bird. Experience and proficiency came on the job. "Here's the key. Try to bring it back." |
02-28-2025, 07:24 AM | #3582 | |
Rep 805
The USAF bought many two-seat trainers such as F-100F, F-104B/D, F-105D, F-106B, but not so much in recent decades.
'25 M850ix GC
BMW CCA 31 years Last edited by Llarry; 02-28-2025 at 07:32 AM.. |
vreihen1623666.50 |
02-28-2025, 07:36 AM | #3583 |
Rep 805
Speaking of "station wagon" fighters, one of the differences between the U.S. Navy F-4Bs and those of the Air Force was dual controls in the USAF F-4C.
'25 M850ix GC
BMW CCA 31 years |
03-01-2025, 12:10 AM | #3584 | |
Rep 1,045
https://www.businessinsider.com/test...nd-f-35-2025-2
Llarry23937.50 |
03-01-2025, 06:00 AM | #3585 |
Rep 805
Although I did post an F-4 photo on Phantom Phriday, this is the one I originally intended to post. A UK RAF Phantom FGR.2 loaded for Bear or Badger or Backfire or whatever else was a threat. Eight AAMs, a centerline gun pod and two external fuel tanks.
The UK Spey-powered Phantoms are easy to differentiate from the jet exhausts. Just to confuse matters a bit, there were a few ex-USN F-4Js (with original J79 engines) in service with the RAF late in the Phantom's life. (see second photo.)
'25 M850ix GC
BMW CCA 31 years Last edited by Llarry; 03-01-2025 at 06:08 AM.. |
03-01-2025, 07:45 AM | #3586 |
Rep 805
A better photo of the appearance of an OA-1K Skyriader II, complete with sensor pod and a pair of rocket pods, plus a bomb (?) under the right wing.
The OA-1K designation is ludicrous, as the aircraft has nothing to do with the A-1J Skyraider, which was retired ages ago.
'25 M850ix GC
BMW CCA 31 years |
