10-23-2024, 09:50 AM | #353 | |
Rep 1,728
While my info is premium gasoline can contain a bit more energy than regular gasoline the difference is not significant. The primary benefit of premium gasoline over regular is -- for engines that require it due to higher compression/better cylinder filling (due to turbo/super charging) -- the better resistance to detonation so the engine controller can use more timing advance. In the test both test vehicle engines were tuned to run best on premium gasoline. The gain in power was I believe due to better combustion. |
10-23-2024, 10:12 AM | #354 | |
Rep 1,728
So you did the right thing switching from Shell to Phillips 66. |
10-29-2024, 06:35 PM | #355 | |
Rep 2,835
Go ahead and point out anything I said that is wrong, that would be a good start.
2006 Z4M Coupe - ZHP knob, stubby antenna, clutch delay delete
10-30-2024, 11:36 PM | #356 |
Rep 947
It's very easy for businesses to rip people off. Just add a couple of cents and pennies to a price and no one cares. Need to buy a new yacht, just add $ 0.50 to the price of gas per gallon to your thousands of customers and, bingo.
12-05-2024, 10:25 PM | #357 |
Rep 632
sign up for Fuel Savings card, gives me 10c per gallon off every time. but if you have a Costco it will still be cheaper. also, its not like shell has a special refinery making special gas, it all comes in on pipelines, shell just markets based on their additives, are they really better? who knows.
DanG11520.50 |
12-05-2024, 11:27 PM | #358 |
Rep 635
Drives: 2016 F10 BMW 535i M Sport
FrankMstein1499.00 |
12-05-2024, 11:59 PM | #359 |
Rep 635
This one here is more in depth, had to browse a bit to look for it,
12-06-2024, 04:04 PM | #360 |
Rep 19,834
Valves in my 2008 Z4 (pic dated 12/1/2024), which has probably run 90% on shell gasoline for the last 100,000 miles and I've never added any fuel additives (cleaners):
12-06-2024, 05:08 PM | #361 |
Rep 72
LogicalApex2214.50 Westside Guy7463.00 |
