05-16-2023, 02:19 AM | #353 | |
Rep 3,925
That said, I bet the bearing issues would be solved by a good ~5w-30 oil instead of the factory spec treacle. Remember, more oil pressure isn't better, so long as you have enough! Last edited by Tambohamilton; 05-16-2023 at 03:47 AM.. |
05-16-2023, 08:42 AM | #354 | |
Rep 3,223
05-16-2023, 06:32 PM | #355 |
Rep 1,844
anyone else curious about the e93 m3 vert that sreten mentioned in one of the recent episodes. did he buy a whole car just to take the motor for his e92? it didn’t even look crashed… but maybe i’m wrong.
05-18-2023, 10:04 AM | #358 |
BMW Miniature Collector!
13829
Rep 8,003
And here is Part 3 of Project Frankfurt (E92 M3).
05-18-2023, 12:30 PM | #361 |
Rep 522
Also Sreten Next time you do a tear down, tap on each piston to see if you have a "disconnecting rod".
Mods to date: The list grows...
05-19-2023, 09:21 AM | #362 |
Rep 3,925
Pretty clear what happened there: the first main bearing spun, because s65. Owner kept driving, as it deteriorated further and further... That bearing got so loose that the nose of the crank started to flex a lot. This probably caused a lot of wear on 1 and 5 rod bearings, and destroyed the front main seal...but the owner kept driving. Eventually the front main bearing got so loose that the flex was enough to break the crank. Only then did the driver take notice. I bet it was driven for hundreds of miles, eating the front main bearing, before the crank snapped. Heat doesn't really factor in the crank failure at all, though for sure there would have been a fair bit generated. Special.
06-09-2023, 09:34 AM | #363 |
13829
Rep 8,003
The next episode of Project Rottweil (E39 530i Touring) is now available.
Plus a special guest appearance of the lovely E39 M5.
06-09-2023, 11:41 AM | #364 |
Rep 3,223
Awesome, will check it out tonight.
Meant to ask earlier in this thread, going back to the B7 Sreten mentions some company in Czech Republic that does a lot of E65 stuff (it's Jarex or Yarex I think? not sure if I'm spelling that correctly). Does anyone have any info or a link to this place? I'd like to check them out (no pun intended Also, does anyone happen to know what phone mount he's using in the E65? Last edited by Chihuahua; 06-09-2023 at 11:53 AM.. |
M3_Legend359.50 |
06-10-2023, 11:06 AM | #366 | |
Rep 478
2009 E90 M3 DCT Space Grey current
2005 E53 X5 3.0 Alpine white sold 2008 E90 M3 6-speed Jerez Black sold 2008 E90 335I 6 Speed Black Sapphire M-sport sold 2006 E53 X5 Black Sapphire sold 2011 E91 Silver Automatic sold 2006 E91 Silver Automatic sold 2007 E91 Black sapphire 6 Speed Manuel current |
Mani5913829.00 |
06-10-2023, 03:16 PM | #368 | |
Rep 3,223
06-15-2023, 12:07 PM | #370 |
13829
Rep 8,003
I will absolutely be using a Colourlock specialist when I get round to restoring the leather in my E38.
06-16-2023, 04:44 PM | #374 | |
Rep 10,394
"Drive more, worry less. "
435i, MPPK, MPE, M-Sport Line |
