06-28-2022, 01:17 PM | #353 | |
Rep 4,041
Drives: 2006 BMW 330i MT
Garage List 2009 BMW 328i Touri ... [8.00]
2013 BMW X5 35i [7.80] 2006 BMW 330i [8.45] 2011 BMW 528i [8.70] 2006 Mazda3 [5.50] |
Yeah, those are actually on my short list, but I can't stand the way the look. Take off all that stupid cladding and bump up the interior materials, then we'll talk! I'm really into the VW e-Golf, but their range sucks. Two of my friends have them, and they're great. Analog controls, and don't look like a science experiment! Yeah, I just don't like the look of them. Fickle, I know, but it is what it is. The only EVs I think look good are the above-mentioned e-Golf, BMW i4, and now the ID.Aero. I want a low-tech mid-sized car, not a CUV, or Mars Rover. |
06-28-2022, 01:47 PM | #354 |
Emperor
1620
Rep 2,765
I don't want to own one, because of Tesla's build quality and... questionable decisions (steering wheel, turn signal stalk, etc), but IMO the Model S Plaid is the best looking sedan on sale today by a mile.
2005 M3 Coupe, 2004 M3 Wagon, 2001 M5 Sedan, 2008 M5 6MT Sedan, 2012 128i M sport |
06-28-2022, 01:56 PM | #355 |
Rep 4,041
Oh yeah, the Model S is the only good looking Tesla IMHO. Nice fastback style works really well for me! But outside my price point.
06-28-2022, 03:25 PM | #356 | |
Emperor
1620
Rep 2,765
Every 7750 OBC "miles": -Oil change (including filter) n.b.: oil changes should be done yearly, even if you don't make it to the OBC mileage target. Combustion byproducts get in the oil that degrade it with time, in addition to the degradation of use. Every OBC Inspection Interval (so every other OBC service interval reset, ~30,000 miles): -valve adjustment -Trans fluid -Diff fluid -cabin air filter -engine air filter -fuel filter -power steering fluid Every other OBC inspection interval: -Coolant -spark plugs -belts Every other year: Brake fluid (M3 yearly, because track car) 50,000 mile intervals: -RTABs -FCABs -Trans mounts -Shocks 100,000 mile intervals: -entire cooling system (radiator, thermostat, water pump, hoses, coolant temp sensor) -belt tensioners and idlers -Guibo -CSB (driveshaft center support bearing) -fuel pump -replace or rebuilt fuel injectors, replace seals -pre cat 02 sensors -valve cover gasket -rod bearings -coil packs -Engine mounts -diff mounts -front control arms -rear outer upper and lower control arm monoballs -rear inner upper and lower control arm bushings -sway bar end links -sway bar bushings -rear shock mounts (RSMs) -vanos seals (beisan) When the trans is out: -Pilot bearing -pivot pin -throw out bearing -read main seal -all exhaust gaskets and nuts for sections that were removed for the job. Note: flywheel can be reused for at least 2 clutches, if not scored) When the rear subframe is out: -subframe bushings -diff bushings When doing rod bearings: -engine mounts -oil pan gasket Not to mention tires... just bought a set of tires for the e60 M5 and it was $1500. They'll be worn out in <10,000 miles :P
2005 M3 Coupe, 2004 M3 Wagon, 2001 M5 Sedan, 2008 M5 6MT Sedan, 2012 128i M sport Last edited by Obioban; 06-29-2022 at 08:21 AM.. |
StradaRedlands6746.00 chris7197617.50 |
06-28-2022, 04:18 PM | #357 | |
Rep 4,041
06-28-2022, 04:23 PM | #358 |
Rep 400
Drives: '23 AMG GLE53, '10 X6M
lol. i put the deposit on the cybertruck
'10 X6M
'08 Cooper S |
StradaRedlands6746.00 |
06-28-2022, 04:44 PM | #359 |
Emperor
1620
Rep 2,765
I plan to add a Silverado EV to the fleet when it comes out, in "normal" trim levels.
06-29-2022, 08:24 AM | #360 | |
Emperor
1620
Rep 2,765
I did build my own wiring harness for the M3. I was able to take ~50 lbs of wire/modules out of the car, without losing any functionality. ... The M3 is on its 3rd set of wheel bearings, but that's just because tracking is hard on wheel bearings. They show signs of wear before failing, so don't really need to be on a schedule. Beyond that, what can I say. I like my cars driving nicely and being reliable. Nobody makes any new cars I want to drive, so I keep my old cars nice.
chris7197617.50 StradaRedlands6746.00 |
06-29-2022, 10:12 AM | #361 |
Rep 7,537
06-29-2022, 10:18 AM | #362 | |
Emperor
1620
Rep 2,765
High performance tires: I was doing my 105 mile commute in less than an hour of commuting... AND there was a high speed backroad section. The tires were matched to the task. I think most people's cars, over 100,000 miles, have severely compromised driving experiences vs new and they don't realize it. Bushings/bearings wear out slowly, and there's a lot of slowly boiled frog going on. It's also just easier to drop the entire front/rear end and replace everything in one go, rather than doing one or two at a time as diagnosed formally as bad. I can do every bushing/bearings/balljoint on the car in 8 hours, or a can do a single control arm in 1-2 hours. Easy access:
Cos270610.00 StradaRedlands6746.00 |
06-29-2022, 10:46 AM | #363 |
Rep 373
06-29-2022, 04:39 PM | #364 | |
Rep 7,537
06-29-2022, 05:11 PM | #365 | ||
Rep 3,317
freakystyly3716.00 |
06-30-2022, 05:48 AM | #366 | |
Emperor
1620
Rep 2,765
EPS in the F22 (and all bmws) is garbage, turbo engine dynamics are boring and annoying, and you get much less useable space in a similarly sized car in the F22 than e90 (meaningful because smaller cars always drive better, all else equal, but practical needs exist). Last edited by Obioban; 06-30-2022 at 07:11 AM.. |
freakystyly3716.00 Red Bread4459.00 |
06-30-2022, 07:24 AM | #367 |
Rep 2,047
Not going to argue, but the F generation cars took a step in the wrong direction. The EPS, soft(er) bushings along with no natural aspiration and increased weight. The 2 series isn't really that tiny compared to the E90, certainly not lighter.
on EVs, we need more affordable options for vehicles before the total ban. Who is going to offer a $5000 EV? Are they expecting people to walk? |
06-30-2022, 07:51 AM | #369 | |
Rep 721
Drives: 06 Black Sapphire Z4MR
In Canada, the cheapest EV is the Hyundai Ioniq, and it is 45k compared to the cheapest new ICE car the Chevy spark is 11k. That's not a small amount of money, the difference is a year's salary (pre tax) for a lot of people. The elites just want to limit the peons from traveling, sounds like we are going back to the Victorian times. Where are these millions of EV going to charge, the grid is strained as it is in most countries. Are they expecting all the EVs will be powered by hopes and dreams?
Revolution of our Times
I will return to the track, one day. |
Murf the Surf22127.50 Cos270610.00 |
06-30-2022, 08:08 AM | #370 | |
Rep 636
06-30-2022, 08:52 AM | #371 |
Rep 2,047
Yeah, if you take a look around on your average drive around town. Run a quick price estimate in your head of the cars you see. How many old early 2000s civics and corollas are people using for commuting? EVs simply haven't been around long enough and in large enough volumes to depreciate to a cheap commuter car level.
Cos270610.00 Murf the Surf22127.50 |
06-30-2022, 09:28 AM | #372 | |
Rep 636
06-30-2022, 10:31 AM | #373 | |
Rep 1,411
Relying on fossil fuel technology has helped Europe end up where they are now with Russia. The decisions made 10 years ago directionally put them dependent on a egomaniacal dictator with designs on world domination. For people who say "what we have now is good enough", that's what they're investing in. For me, Mad Max's glimpse into the future doesn't look appealing. Having my own home solar and windmill charging up my electric car looks a lot more appealing. Can't run your own petroleum well and refinery in your back yard as easily. Ethanol? Maybe. But you need 15% petrol in there to keep the water out. Shawn |
06-30-2022, 11:11 AM | #374 | |
Emperor
1620
Rep 2,765
...And when the grid's not offline, I get a check for $300-400 per month from the electric company, and have no gas/oil bill.
