BIMMERPOST Universal Forums Professional Motorsport Racing Discussion (IMSA, DTM, Formula 1, Grand-AM, Le Mans, IRL, WRC, etc..) F1 2021: Turkish GP - Istanbul (Oct 10)
      10-16-2021, 04:46 PM   #397
MKSixer
MKSixer's Avatar
34166
Drives: 2015 BMW i8, E63 M6, 328d
2016 M4 GTS (Allotted)  [0.00]
2013 BMW 328d  [0.00]
2007 BMW M6  [10.00]
2015 BMW i8  [10.00]
Originally Posted by F87source View Post
It would be funny if max left rbr and joined Mercedes, then all of a sudden Mercedes can do no wrong.
Absolutely spot on!!
Several actors have played James Bond, Sean Connery IS James Bond...
Sir 7ewis, 7X FIA Formula One World Championship, World Driving Champion. 100 Wins. 101 Pole Positions. 54 Fastest Laps. Actual Rain Master. Leave me to it, Bono. One Race Win in each of his 15 years in F1. Most Laps Led in Formula One. The Centurion.
F87source8200.00
minn1914514.50
      10-16-2021, 04:57 PM   #398
First everything you've countered with so far is just opinion based, more he said she said, I saw he saw. None of that will hold up in a court of law.
In regards to DAS Mercedes already consulted with the fia ahead of time, of course they have a back up plan Incase teams cry too much about new innovations and try to trigger a ban. This is because Mercedes thinks 10 steps ahead and are always ready, unlike redbull who knew they were pushing the limits with the rear flexi wing that flexed down and also rotated backwards to change wing angle - more on the flexi wing stuff in a bit. but the point is redbull were pushing the limits of the permitted wing flex grey area and had zero back up plan in case it was banned. Mercedes weren't even in a grey area, they had full approval and still they are 10 steps ahead just in case.
Now in response to flexiwings we all know no material has infinite stiffness under load, there must be a small amount of deformation. Since there is a permitted tolerance range of course every team is going to try to get into that grey area to capitalize on any but of advantage. Now how far they push the envelope varies from team to team, redbull likely pushed the envelope too far with a wing that not only flexed down but rotated backwards, and Mercedes likely haven't pushed to the limit of the rules being breached hence why one was banned and one was not. Again there are actual number based load tests to test this deformation, aka actual fact and the fia increased the load test even further to test fit the front and rear wings deformed too far. Red bull got caught out likely because they were literally ok the limit before the imcreasd load test, and Mercedes didn't get caught off because they likely weren't on the limit. If it was true Mercedes was being favored, I don't know how when you have physical numbers to go back on to prove if a wing flexed too much - say Mercedes did have a wing that failed inspection and the fia swept it under the rug, then red bull would have forced a law suit if they really believed that was the case and when they test it in court Mercedes would get absolutely screwed over. Again it didn't happen.
Also don't forget, this is only really the first year Mercedes has been complaining to the fia alot, the last few years it was Horner going all out at every team getting things banned left and right. Literally look at the thread put up on Reddit discussing redbulls complaints all the way back to 2015, it's insane how many things redbull had pushed towards the fia. That's why they call Horner, Karen Horner.
Like I said before when you hinge on opinions and conspiracy you just jump from one thing to another regardless if it passes the sniff test.
Merc has had a huge advantage from 2014 (when the hybrids were pushed in) the engine and everything connected to it.
Montezomolo then Ferrari F1 boss has said that Lauda told him that Merc were building a hybrid since 2007 and Lauda didn't deny he told him that while he still lived.
So let's look at it now with Austin coming up,Merc are up on performance and gov. body say it's fine, that in itself is highly questionable.
      10-16-2021, 05:01 PM   #399
'Ham was given a time penalty then went on to win', this is where Fia are a F* joke and are not fit for purpose.
      10-16-2021, 05:07 PM   #400
F87source
F87source's Avatar
Drives: Bmw M2
Again more speculation without proof. Back in 2007 mercedes didn't even have a team, they were just partnered with Mclaren. Back then it was Ferrari and RB being favorites.
Again you're only twisting it to your own narrative, how do you know mercedes didn't have to pull back power previously to ensure their only 2 motors left in the pool didn't fail? How do you know if degredation didn't cause a drop off in power? You don't and thus you start to speculate. Redbull had a huge power jump mid season that was suspect - the FIA responded and said it was fine. How come you aren't all enraged by that? That's right, because you're so insanely biased you cannot see the world clearly.
Click on the link below to see a compiled list of every review I have ever written:
https://f87.bimmerpost.com/forums/sh...2#post30368242
MKSixer34165.50
Steeler2468.50
minn1914514.50
      10-16-2021, 05:11 PM   #401
Chappers 71
Chappers 71's Avatar
6233
Drives: Beige G31 540ix m sport
Originally Posted by MKSixer View Post
I did limit it to a couple of RBR fans...
I meant that I believe it's Max that they idolise it just so happens that he drives for RB, something rather unhealthy in it all imho
G31 40ix M Sport
E92 335i. E36 328is coupe
E39 540i V8 6SP manual
E34 3.6 M5. E34 525i sport.
VW Jetta Mk2 GTI 16v. 1679cc 1967 resto-cal beetle
F87source8200.00
MKSixer34165.50
3798j13979.00
minn1914514.50
      10-16-2021, 05:25 PM   #402
F87source
F87source's Avatar
Drives: Bmw M2
Imagine the salt if max looses this year, and RB next year is a mid field team because they dumped too many resources into 2021. I wouldn't be surprised if redbull dumped a bunch more resources into trying to ensure max wins, and thus compromises their 2022 generation car. They literally did the same thing in 2013 and it took them 8 years to catch up - well pu issues aside that is. I mean it did take them forever to understand their chassis (something that I was told was absolute BS and didn't need to happen for better development) and it still seems they don't fully understand it since the RB16B still retains some rear instability. So I wouldn't be surprised if RB gets caught off guard again in 2022.
Sure Mercedes have been working on a few upgrades, but apparently the majority of it was already done in silverstone and they just have a few bits here and there that were already done but not released such as the front wing.
MKSixer34165.50
minn1914514.50
      10-16-2021, 05:25 PM   #403
MKSixer
MKSixer's Avatar
34166
2007 BMW M6  [10.00]
2015 BMW i8  [10.00]
That makes is even more creepy!!
minn1914514.50
      10-16-2021, 05:28 PM   #404
2007 McLaren-''Mercedes'' engine, the time of 'Spygate'
      10-16-2021, 05:32 PM   #405
F87source
F87source's Avatar
Drives: Bmw M2
Which was all Mclaren's fault since they did it behind mercede's back - hence why mercedes left them..... This was well documented too...
Like I said when you rely on conspiracies you literally lash out to whatever suits your narrative regardless if it will hold traction or not, if it doesn't onto the next conspiracy.
MKSixer34165.50
      10-16-2021, 05:33 PM   #406
F87source
F87source's Avatar
Drives: Bmw M2
Having a favorite driver is normal, making him a roll model is fine.
It becomes a problem when it starts to twist your view points and make it so that every bad thing that happens to him (or any event that doesn't favor him) the fault of some other out side force trying to get him.
Steeler2468.50
MKSixer34165.50
minn1914514.50
      10-16-2021, 06:08 PM   #407
Chappers 71
6233
I can't be bothered to trawl back through all their posts to find it but one of them posted a pic of Max sitting back in a suspiciously tight pair of shorts, for me that's when the penny dropped
G31 40ix M Sport
MKSixer34165.50
      10-16-2021, 06:10 PM   #408
Come on now you're conspiring lol Mercedes were making the engines and wasn't dragging in McLaren,you are tut tut
      10-16-2021, 06:36 PM   #409
F87source
F87source's Avatar
Drives: Bmw M2
You do realize this went to court right. IIRC the documents were chassis related not engine related, and In the end they couldn't hold McLaren fully responsible because they couldn't prove the Ferrari parts were used on the McLaren to benefit it.
The engineer that got the documents were also a McLaren engineer, and in the end Mercedes were in the dark because they only made the engine not the chassis.
In the end fines and punishments were issued, and Mercedes left McLaren as a result of what the chassis side did... So what does this have to do with Mercedes of today? The case went to court and the evidence was read and due justice was served. The only reason why you brought it up is because it fits your narrative, either way I don't really care to correct you. You're way too far gone.
Steeler2468.50
minn1914514.50
MKSixer34165.50
      10-16-2021, 06:54 PM   #410
Killed by Death
Killed by Death's Avatar
17391
Drives: '23 X3 M40i
This has to be the biggest pile of steaming horse $hit EVER posted reference "Flexiwings." Of course no wing can be completely static but MB fans lost their minds with RB's rear wing. Visual evidence and HAM's radio comment was all that was needed to change testing. Remember? It was a movable aerodynamic device!!!! Banned whether is passed previous testing or not!!!! But now legality rests on two elements? Talk about moving the goal post
MB flexing down on one axis is OK (Vertical strakes or support could easily fix this movement) but FIA looks the other way!
RB flexing on two axes is verboten (RB & others must redesign the rear wing)...No small task!!!
Hypocrites!!!!
M5Rick73131.50
      10-16-2021, 07:02 PM   #411
F87source
F87source's Avatar
Drives: Bmw M2
Hypocrites!!!!
Like I said there's a tolerance limit, how far you push into the grey area dictates that.
So at first RB's rear wing passed the test no problem, after a bunch of whining to the FIA they increased the load for the test and redbull failed. This means they pushed too far into the grey area. When retesting the merc front wing it still didn't fail any tests based on the parameters given - hence mercedes didn't push into that boundary as far as red bull did.
There's no such thing as "looks away", if they didn't test the mercedes front wing as per the rule book then again redbull would have a slam dunk law suit. What likely occured is like I said before, they're in the grey area but there is still enough wiggle room because they didn't push it to the absolute limit. Thus mercedes still passes tests.
In regards to what triggered the fia investigation, well mercedes likely played a butt ton of mind games with hamilton's radio call then launched a formal complaint to the FIA - IDK that's just how inter team politics works I guess. In the end the FIA did their tests and that's that.
minn1914514.50
MKSixer34165.50
      10-16-2021, 07:05 PM   #412
///M Power-Belgium
///M Power-Belgium's Avatar
Belgium
74114
The only access to a Merc seat is to be a lap dog on a leash !
MAX's mission is to beat Mercedes to 5H1T.
Hopefully HONDA can close the gap ASAP and the RB-16B is fast enough in coming 6 races .
So actually your statement is funny ..
M5Rick73131.50
      10-16-2021, 07:12 PM   #413
Bubbles
Bubbles's Avatar
Cayman Islands
2831
Drives: Green Bastard
Originally Posted by yco View Post
Awesome seats
      10-16-2021, 07:14 PM   #414
Killed by Death
17391
Drives: '23 X3 M40i
Simply, what I'm trying to say is that RB didn't pass the eye test and got hammered with new testing.
MB doesn't pass the eye test and it's ignored!
Again, I get what you are saying and respect your opinion but HATE the double standard IMHO...Good nite all
M5Rick73131.50
      10-16-2021, 07:15 PM   #415
///M Power-Belgium
Belgium
74114
Man .Good lord ! I'm not religious , but I'll try to pray for you anyway !
"In nomine Patris et Filii et Spiritus Sancti"
M5Rick73131.50
      10-16-2021, 07:17 PM   #416
F87source
F87source's Avatar
Drives: Bmw M2
Hmm so kind of like the second redbull seat, except if you get that seat you won't get any decision on how the new car is built. You will get treated like garbage by marko, and you future is never guaranteed. So pretty much torture and toxicitiy.
Honda already introduced new electrical systems a couple of races ago so no more development there, and no more pu updates this season since a new pu was introduced start of season so unlikely for Honda to do anything. If they want to crank up the power to full beans and at that point who knows if the PU can hold up (might need another grid penalty then), Max's engines have a few races on them now so they're not fresh.
Either way if Max doesn't get a competitive car he might be gone (might be a possibility if red bull drops the ball on the 2022 car), and at that point if he goes to mercedes then I guess you will be the number 1 mercedes fan.
minn1914514.50
MKSixer34165.50
      10-16-2021, 07:20 PM   #417
///M Power-Belgium
Belgium
74114
That's BS my friend !
M5Rick73131.50
      10-16-2021, 07:21 PM   #418
Killed by Death
17391
Drives: '23 X3 M40i
I've been tested with death many times and try to remain religious enough to cover my a$$
So, I'll lay down a prayer for you my friend!!!!
M5Rick73131.50
