11-12-2008, 07:39 PM | #25 |
track junkie
Rep 60
really? that much? does the dealer use something better than for example a Good Year Dealer? I had mine done and they charged my $60.
however, i live in the suburbs |
11-12-2008, 07:40 PM | #26 | |
Rep 4,737
As for whether this makes a difference, I dont know... |
11-12-2008, 08:11 PM | #27 |
Rep 8,033
Rldzhao, what one really needs to know is the effective spring stiffness vs. displacement. As I've said earlier, if you plot the force vs displacement curve for the H&R springs+stock bumpstops, you'll see that you will run into the really steep part of the curve sooner (the bumpstop curve will probably look like two straight lines with distinct slopes; the slope of the second line at larger displacement will be significantly higher than the slope of the line at smaller displacement). I appreciate you documenting H&R's answer, but I still think messing with the force vs. displacement curve in a significant way, especially during the initial displacement interval, without retuning the dampers is not sound. Nothing in their answer suggests they are doing the right thing here.
The other thing is that the H&R guy is making claims about how the Dinan bumpstops behave. Has he actually seen/tested one of them? How does he know how they behave exactly? I sure don't know, and would like to find out, but I suspect that he doesn't know either.
11-12-2008, 08:46 PM | #28 | |
Rep 4,737
I have the H&R installed and I am monitoring it closely. I think this is the best way to review a product instead of just listening to both company's marketing. Until I have more miles on the car, do a track session, and conduct a side-by-side comparison, I am not making any conclusions. |
11-12-2008, 08:49 PM | #29 |
Rep 2,867
Hey rldzhao, I c ur in NY. Where did u install ur springs? I am either gonna go with rd sport or dinan springs but need someone to install and wouldnt mind going to someone who has already worked on our cars.
11-12-2008, 08:55 PM | #30 | |
Rep 8,033
Do you still have your stock springs? Maybe we can get force vs. displacement data from them. If I can find someone local who has purchased H&R or Dinan springs (and bumpstops), I'll try to convince them to let me take data on them before installation. It would be great to have that all documented.
11-12-2008, 09:04 PM | #31 |
Rep 4,737
Hey. I actually installed the springs myself. ICS performance in Stamford, CT has a mechanic who used to work for Ferrari, and he seems to be quite knowledgeable and quite a gentleman.
11-12-2008, 09:07 PM | #32 | |
Rep 4,737
11-12-2008, 09:10 PM | #33 |
Rep 8,033
You can ship one of your front springs to me if you'd like, and I'll ship it back after I get the data. We can split the shipping costs. Shouldn't be much. Or we can meet up if you are ever in the area. I have access to equipment that will yield accurate force vs. displacement data. Just an offer.
11-12-2008, 09:29 PM | #34 |
Rep 6,107
it would be great if you guys can do that test ... i just purchased h&r springs too ... would be good to know what kind of results lucid can get from that test ...
11-12-2008, 09:48 PM | #35 |
Rep 4,737
11-12-2008, 09:51 PM | #36 |
Rep 8,033
Just to clarify: I don't have Dinan springs or bumpstops.
11-12-2008, 10:02 PM | #38 |
Rep 8,033
Good idea. I'll check with my colleague who manages the test equipment to make sure it is available and up to spec first. If it is, it would take only a few minutes to run each test, so doing them together is not a major requirement. It sould be fine. He was demonstrating some titanium samples he pulled apart the other day. The only setup issue might be to build a rig to keep the spring stable under compression so that it doesn't fly out.
11-12-2008, 10:13 PM | #39 |
Rep 4,737
Just to be clear, this will not be destructive testing right? We should probably define a range such that the normal operational range is not exceeded.
My idea is that we should start by applying up to 3700lb/4 on the front spring, and then compress another 3-4" max. This should give a pretty good idea of the behavier of the spring. Also, we could probably do a little "fund raiser". We can accept small contributions like $5 to cover the logistics and testing costs. We would probably want to buy some bumpstops as well (they are cheap) . lol this sounds like fun. |
11-12-2008, 10:21 PM | #40 | |
Rep 8,033
11-13-2008, 11:48 PM | #42 |
Rep 12,654
Lowering height is one thing but spring rates is another. Just because one is lower doesn't mean that it will ride worse if using a lower spring rate. Oddly, RD springs ride better with the lower stance than H&R. I have not installed Eibach springs yet so can't provide any real input.
The proper way is to have springs matched to shocks like the KW Coilovers |
11-14-2008, 11:03 AM | #43 |
Rep 8,033
Hi guys. I just checked the specs on the machine and it can easily handle the forces and the displacements we are talking about. I just need the dimension of the stock springs to make sure I can mount them properly. Diameter and uncompressed length? Also, can someone post a pic of stock and aftermarket springs? Once I get this info and verify that we are good to go, I'll start another thread on this.
11-15-2008, 02:07 AM | #44 |
Rep 2,426
How about a 300lb woman in the passenger seat?
“For God so loved the world that he gave his one and only Son, that whoever believes in him shall not perish but have eternal life.”
- John 3:16 |
