01-29-2022, 09:28 AM | #23 | ||
Rep 949
01-29-2022, 09:33 AM | #24 |
Rep 1,336
Might be a bit off the thread but we live in a 25 year old log home, 3000 sq ft on 3 floors, surprisingly easy to heat even in the -35C weather were having. Propane forced air furnace that is 12 years old so maybe 3-5 years life expectancy left. We are thinking about going to Geothermal. One of our neighbours has it, does heat and AC monthly hydro bill all in is about $150, which is about $50 more than I'm paying now. The upfront cost is a bite but hoping for government rebates so we are waiting for that before we pull the trigger. The thing will also make hot water so very cool.
01-29-2022, 11:41 AM | #25 | |
Rep 135
First, because it starts up at a very low (20%) setting, it's virtually silent. You can't barely hear the burner and induced draft blower, and the circulation fan at the setting produces just a whisper of air coming out of the registers. It'll ramp up if needed, but since it is most efficient at very low settings, the thermostat is set to keep the temp within a degree (F) of the set-point, and so it runs often, but almost always at the low settings. Second, since we have a pretty big ranch house we have a couple of remote temperature sensors that are tied to the thermostat, and it averages all the temps to decide when to start up. That makes it run even more often, which has virtually eliminated hot/cold spots in the house, and that's without any zoning. The entire house is +/- 1 degree of the set point all the time. Frankly, it's remarkable. We rarely hear it and the house is so much more comfortable than it was. And the new furnace is 97% efficient, so we're using less gas than before, as well. The unit is a Goodman (Amana) GCVM97971005CN |
01-29-2022, 12:34 PM | #26 |
Rep 3,292
I just had my whole HVAC system replaced due to impending failure and age. The units were the standard builder grade crap that were 20 years old. The evap coil was rusting and is probably the source of the refrigerant leak. The inducer motor in the furnace was making a loud whining noise that was causing the furnace an elongated light off time to get the burners going.
What I ended up doing was get a larger furnace that would work with my current ductwork/space in the mechanical room. I went from a 75,000BTU furnace to a 130,000BTU furnace. The new furnace is larger with 6 burners/heat exchangers versus the 3 with the old unit and a larger blower. I needed larger blower as my house originally from the builder was marginal for a 2 zone system. The builder opted to stick with the single zone. Since then, I had my basement finished and had an addition put in. This made the existing furnace system inadequate to condition all the living space. I also opted to increase the size of the A/C system from a 4 ton unit to a 5 ton unit. We'll see how it works when summer gets here. So far it's been great. I did think about going with a high energy efficient system. My friend who helped me acquire and install the system is an HVAC person by trade. He said the wait for any of the high energy efficient systems is months. In fact, my system which is a Bryant was almost not available. He said his supplier only showed 9 available in the Mid Atlantic and if those are gone he doesn't know when any new stock will arrive. The joys of the supply chain issues we're dealing with. |
tranquility3435.50 |
01-29-2022, 01:37 PM | #27 | |
Rep 135
We ordered ours in March. By the beginning of October I was starting to get a little worried, since our old furnace was on its last legs and not functioning correctly (short cycling). It took an email to the Goodman factory rep literally begging for one, and when we got it in November I noticed the build date was in 2019 and the box was very dusty. It must've been sitting in a corner of the warehouse someplace. |
01-29-2022, 01:38 PM | #28 |
sportscars only
3436
Rep 3,258
Tx all for your various inputs. According to the majority, it seems that the best is some sort of radiant in-floor heating, some ppl prefer baseboards and a few say new furnace types are great.
How about maintenance issues, after decades of use? I would think baseboards would be the easiest to repair, so if one has to take into account the 2 major factors of heating efficiency and reliability, would it still be in-floor heating?
The richest one percent of this country owns half our country's wealth, five trillion dollars. One third of that comes from hard work, two thirds comes from inheritance, interest on interest accumulating to widows and idiot sons and what I do, stock and real estate speculation...It's bullsh*t. I create nothing. I own. We make the rules, pal...Now you're not naive enough to think we're living in a democracy, are you buddy?
01-29-2022, 01:48 PM | #29 | |
Rep 3,292
That's nuts you had to wait that long and confirms what my friend was telling me about the supply issues with the higher end units. I wasn't willing to roll the dice as my furnace was giving me signs that it might break down soon. |
01-29-2022, 01:55 PM | #30 | |
Rep 3,292
01-29-2022, 03:30 PM | #31 | |
Rep 982
PEX tubing these days is probably much more flexible/durable than whatever they used back in the day. Still, I would engineer my own new-install with multiple PEX loops in the slab if I was going to use it, so that individual sections could be isolated if they develop leaks.....
01-29-2022, 03:36 PM | #32 | |
sportscars only
3436
Rep 3,258
01-29-2022, 03:45 PM | #33 | ||
Rep 982
On the bright side, I feel better that our pipe-eating well water will not destroy the stainless boiler in what's left of my lifetime.....
01-29-2022, 04:03 PM | #34 | |
Rep 135
01-29-2022, 04:30 PM | #35 |
Rep 1,003
The first place to spend your money is insulation and caulking of walls, windows and ceilings/subfloors. A well sealed and insulated home is easier and much cheaper to condition.
Then system design actually gets easier. If I was starting with a clean sheet, I’d go with floor heating (preferably liquid) and zoned AC (maybe using mini splits in some areas depending on floor plan). For a house I really like geothermal, but it is so expensive (and repairs on my last one were pretty expensive). Might not pencil. That’s what I’d be looking at if I still lived in KY or MI. Here in FL the floor heating won’t pencil so a heat pump system would be most economical. |
01-29-2022, 11:57 PM | #36 |
Rep 303
I've had my in-floor for 22 years with no issues, just basic boiler maintenance. Separate zones throughout the house with the garage and shop as a separate zone as well.
