11-14-2016, 01:36 AM | #23 |
Rep 1,986
11-15-2016, 11:57 PM | #24 | |
#LSBM3
1424
Rep 1,973
Drives: 2016 BMW M3
Garage List 1984 BMW R65 [0.00]
2020 Ford F-150 XLT ... [0.00] 2003 Mitsubishi Evo ... [0.00] 2016 M3 Competition ... [10.00] |
Based on those numbers there really isn't a difference between ZCP & GTS wheels. Yes, the GTS has 19's in the front. However, the 1.3lbs weight difference is added back on the rear with the wider wheels. There is no real weight savings between the ZCP & GTS wheels. The combined weight of all 4 wheels add up to the same 104.8lbs.
/// M3 |
11-26-2016, 12:37 PM | #25 |
Rep 274
There is the weight comparison
2015 BMW F82 M4
2012 Audi RS3 2009 Honda Civic Mugen RR |
12-18-2016, 10:15 PM | #28 |
Rep 209
They should have made a carbon center lock wheel
For sale Custom Stainless Full exhaust $2500
2015 Apline F82 M4 / Sakhir Orange Interior / DCT /Driver Assist Plus / LED Lighting Package /Executive Package /437M Black 19" Wheels/Adaptive M Suspension / CF Diffuser / CF Mirror caps / CF 3D Design spoiler / Custom 3.5 inch Exhaust / H&R Springs |
LENBMW2.00 |
12-19-2016, 06:12 PM | #29 |
Rep 1,386
12-19-2016, 06:52 PM | #30 |
Rep 646
schnell325892.50 G35POPPEDMYCHERRY4998.50 |
12-20-2016, 05:55 AM | #31 | |
Fight On!
47
Rep 120
11-02-2023, 05:07 PM | #32 |
Rep 2,822
Holy thread bump. Question for the wheel gurus. Would the wider 666M front and rear with 265/285 cup2 as per GTS specs, with offset 29 front and 42 rear cause any rubbing on the struts?
They obviously clear the GTS which had Coilovers but with normal comp suspension and MPHAS, it goes approx 6mm further inwards and outwards due to the wider rim.
2020 M4 competition Mexico Blue / Opal white ultimate pack, full M perf carbon kit, MP HAS, Carbon Ceramics, 763M with cup2’s.
Instagram c1_cdg |
11-02-2023, 09:40 PM | #33 | |
Rep 1,696
DSC, you say? Never heard of it
https://youtube.com/@tractioncontroldelete |
Colinv64053.50 |
11-03-2023, 01:13 AM | #34 | |
Rep 2,822
I think I’ll stick to 763M in the end, there’s probably a reason it’s not been done (can’t find any regular M4’s with GTS wheels online)
Instagram c1_cdg |
TractionControlDelete4604.00 |
11-03-2023, 05:55 AM | #35 |
Rep 726
Drives: E46/F15/GT4
I have a set of GTS wheels on my F80 with MPHAS. No fitment issues.
11-03-2023, 07:11 AM | #36 |
Rep 2,822
Nice!! Do you have any pictures?
Instagram c1_cdg |
11-03-2023, 07:27 AM | #37 |
Rep 726
Drives: E46/F15/GT4
Colinv64053.50 TractionControlDelete4604.00 |
11-03-2023, 07:38 AM | #38 |
Rep 2,822
Thank you!! Looks great. So no rubbing at all and are you using spacers?
Lastly.. these or 763’s?! I’ve been debating on wheels for weeks now
Instagram c1_cdg |
11-03-2023, 10:13 AM | #39 |
Rep 650
I just got a set of 763m and I loved the 666 so much initially I wasn’t sure but now I’m lovin the 763 and so easy to clean
11-04-2023, 07:11 AM | #40 |
Rep 726
Drives: E46/F15/GT4
15mm spacers all around. No rubbing. I had 763M as well and they give a better track look. Hard to pick and I would have both if I had space.
11-14-2023, 02:12 PM | #41 |
Rep 9
The mass of the wheel doesn’t tell you anywhere near the full story.
You can have a wheel that is heavier, but has more of its mass closer to the hub and thus has a lower rotational inertia than a lighter wheel with more mass at the rim. It’s called the “radius of gyration”. In engineering terms, the radius of gyration (k) is defined as the square root of the moment of inertia (I) divided by the mass (m) of the wheel. The formula is: K = [ I / m ] ^ 0.5 People confuse rolling resistance (which is more down the wheel bearing) with rotational inertia which is really the radius of gyration and the wheel + tire mass. Tires are pretty much the most important component of any car, changing up the wheels and tires without really knowing what you are doing is just a lucky dip for driving performance. But hell we all do it. |
