10-09-2020, 08:26 AM | #23 |
Enthusiast
117
Rep 150
Many useful information here - thank you all for sharing.
I retrofitted the F10m5 brakes and had zero issues, sold them to a friend who also have no issues with them whatsoever. The major downside was at the beginning I had to fit 20" M359s and then proceeded to grind the calipers for less than a mm to fit the oem m359 with 15mm spacers. Replaced them with CCBs from an audi (i know, Frankenstein Brakes) and have zero issues, been to the track 4 times since last year (screw C-19) and except for the crazy replacement cost I cannot see a downside. Do we need to replace the brake cylinder to accommodate for the change? and is that even doable taking into consideration the brake booster vacuum mechanism in the e9x m3 that will shoot a CEL if anything goes wrong. I agree with Phonsalb as my mechanic said the same, the ABS would control the bias and the vacuum pump would accommodate for pressure.
SilverSlug684.00 |
10-09-2020, 10:39 AM | #24 |
Rep 1,184
if you upgrade from 360mm to M4 380mm or M2 comp 400mm rotors you can reduce proportionally the piston area to keep the F/R balance
Small rotor = big piston area Big rotor = small piston area That's why many BBK have smaller pistons than the OEM ones I am putting Renault megane RS brembo 4 pot calipers with M4 380mm rotors on my E92 M3.... with custom brackets homemade Best bang for the bug or use this kit https://freakyparts.co.uk/collection...15487394971693 400mm M2 comp rotors are too wide for megane caliper and tooo heavy.... Last edited by marconi118; 10-09-2020 at 10:46 AM.. |
SilverSlug684.00 |
10-09-2020, 02:42 PM | #25 | |
Rep 75
The Megane Brembos have 40/40mm x 2 =2512mm x 2 piston area per caliper which is 11.1% smaller than the stock front E92 caliper. Increasing the disc size from 360 to 380mm is only a 5% increase in disc size, so the piston area reduction is greater than the corresponding increase in disc diameter. Also, and importantly - increasing the disc diameter will offset the torque loss caused by the smaller piston area (by the % increase in disc diameter), but it WILL NOT offset the resulting change to pedal travel, firmness/softness and modulation. The Megane Brembo will give you a 11% firmer pedal and 11% less travel and potential modulation. Just saying. Last edited by Captain Caveman; 10-09-2020 at 02:51 PM.. |
10-09-2020, 02:47 PM | #26 | |
Rep 75
Be good to know more about your setup. |
10-09-2020, 03:45 PM | #27 | |
Enthusiast
117
Rep 150
I still have a picture of the front which I posted in another thread. You can see the clearance is like 1mm in the front. Please note that I did grind the calipers around 1mm on the 2 corners to get them to clear (nothing that might cause any issues) I did assist a fellow member in the UK who contacted me on Instagram (his insta: M.O.l.i.v.e.r) who did the same retrofit but using the m4 rear brakes in case you needed any local help. keep in mind that IRON>Carbon ceramic for track weapons but my is a semi-daily/weekend/track car, and Essex did comment some valuable info on an earlier post. https://www.m3post.com/forums/showthread.php?t=1627094
LEBLEUM30.00 |
10-09-2020, 04:46 PM | #28 |
Rep 75
Thanks, that's immensely useful! Do you think the M5 Brembo caliper is larger than the normal Brembo GT6 caliper? It looks fatter to me?
10-10-2020, 03:05 PM | #29 |
Enthusiast
117
Rep 150
Both are almost the same - The GT6 is more defined. We actually tried to cnc an F10 caliper to for the look of the GT6 and it actually worked (No pics at the moment)
10-10-2020, 03:44 PM | #30 |
Rep 75
Cool - that would be amazing to see. So the F10 caliper is essentially the same basic design, just heavier and less sculpted or machined than the GT6? Be cool to see pics!
10-11-2020, 08:03 AM | #31 | |
Rep 1,184
will install and report on it. |
10-11-2020, 03:43 PM | #34 | |
Rep 935
What would your opinion be on upgrading just the front calipers to a 30/34/38 mm piston caliper and using them on the standard 360mm discs? By my calculations, the total piston area is 97.22% of the stock piston size - do you think this will result in a noticeable difference in pedal travel, feel, or significant change in braking torque or bias? At a guess, a 2.78% difference will probably be unnoticeable and upgrading the pads up from the standard Brembo ones to PFZ pads or something will make up for the tiny difference. I know a few people who have used the C63 AMG caliper which has piston sizes of 34/36/38mm - meaning a total piston area increase of 8.22% - and they report no noticeable change in pedal travel/feel and are very happy with the results. Based on this, I'm hoping that a 2.78% reduction will not be a negative thing, or even noticeable. Would be interested to hear your thoughts.
10-12-2020, 05:18 AM | #35 | |
Rep 75
Here are the calcs with the new fronts and stock rears: 30/34/38mm - 2748mm x 2 46mm rear - 1661 x 2 Total piston area 4409 - 1.74% smaller than stock Front/Rear bias 62.3% front bias - so 0.7% more rear bias It's worth stating that there is very little benefit to simply enlarging the caliper without also increasing the disc thickness and diameter. Sure, the larger pad will have greater heat resistance than the smaller pad, however the disc will be the limitation here. The smaller piston area of the new caliper with everything else the same will actually give you less clamping force. I am guessing the caliper you are considering is either the Porsche/Brembo 18Z or the Maserati/Alfa Romeo Brembo caliper? The larger piston area of the W204 C63 Brembo caliper will give you slightly longer pedal travel and a slightly softer pedal, however will provide greater clamping force. Most BBK makers tend to opt for a smaller piston area than stock to allow for the additional torque provided by a larger disc diameter, so if you ever plan to track your car or are likely to go with a larger disc at some point, it's worth going for the smaller piston area to be safe. For example, lots of people are fitting the M4 setup which has about 10% smaller piston area, but larger discs all round. Hope that helps! |
10-12-2020, 06:09 AM | #36 | |
Rep 935
Yes it is indeed the Alfa Romeo caliper that I'm looking at. In all honesty, the biggest motivator for this change is simply aesthetics. I'd like to get the brakes looking better as long as there is no noticeable/significant degradation in braking performance. My reason to consider this caliper instead of the AMG one is mostly due to the piston sizes (97.22% of stock rather than 108% like the AMG is) and the other, much less important reason, is that the caliper is slightly better looking than the AMG one. The Alfa caliper is also designed to fit on a 360mm disc in on the Alfa itself which is spot on here, and hence why I'm not looking to increase the disc size (I would use the M4 380mm disc but I don't believe that this is a good idea if the caliper and pad are sized/curved to a 360mm disc). I'm struggling to decide whether it's better to use the AMG caliper with a 108% piston area and the consquences that come with that, or is it better to use the Alfa caliper at 97.22% because the 2.78% change should hopefully be unnoticeable...
ppatel1471.00 |
10-12-2020, 06:18 AM | #37 | |
Rep 75
Other big problem is the AMG caliper is designed for a 36mm thick disc, whereas the Alfa disc is 32mm. As the stock M3 disc is only 30mm, I would advise against going with such a big thickness difference, as there is a risk of the pistons popping out of the caliper. Calipers are designed for only small thickness ranges. The other difference between the AMG caliper and Alfa caliper is pad size. The alfa uses a comparatively small pad compared with the AMG, so they will wear faster and have less heat resistance. You want a pad height that will sweep the full disc height without overlap or unswept area. Stock M3 front pad: Alfa pad: AMG pad: With all the above in mind, if you plan to stick with 30mm thick discs then I would definitely go with the Alfa Romeo Brembo caliper. The AMG caliper is both too large a piston area so will cause a longer pedal, transfer the bias more to the front (which u don't want) and isn't designed for a 30mm disc. Speak to Freakyparts as they have experience of the Alfa setup and will be able to a advise you. Last edited by Captain Caveman; 10-12-2020 at 06:46 AM.. |
ppatel1471.00 |
10-12-2020, 06:53 AM | #38 | |
Rep 935
I also did look at the disc thickness comparisons and I think that it wouldn't be an issue to use a 30mm disc if the caliper usually uses 32mm. Going from 36>30 doesn't sound like a great idea, though. Would you personally up it to a 380mm disc, despite keeping stock rears? 380mm is a 5.56% increase on a 360mm disc - is it fair to relate that figure to the 2.78% reduction in piston area (and therefore the clamping force) and say that the final brake torque over the stock setup is approximately 5.56-2.78 = 2.78% increase? One other issue with using a 380mm disc is then that according to PFC, the M4 pad height is 71mm which will leave an even bigger ring of unswept area. This is obviously fine if it's the better setup to use, though, can just paint it.
10-12-2020, 07:22 AM | #39 | |
Rep 75
In terms of swept area, there are 2 pad heights available for the Alfa Brambo caliper; D1116 which has a 55mm annulus and D1666 which has a 65mm annulus. You should be able to get the right swept area with one of these. |
10-12-2020, 09:08 AM | #40 |
Rep 103
Thanks @Captain Caveman for the detailed explanation. I've been patiently waiting for BPM Designs to come out with their retrofit BBK using 6 pot AMG calipers with stock rotors. But your explanations make a lot of sense with rotor size/thickness, piston area, and brake bias. I think for the time being, I'll add some titanium shims with my brass caliper guides and some cooling ducts to manage heat.
2013 E92 ZCP /// Alpine stage 2 tune, Bomiz Race X-Pipe, ARC-8 wheels, Vorshlag camber plates, Wheel studs, TMS spacers F15mm/R12.5mm, Stoptech SS lines, BW brass caliper guide |
10-12-2020, 09:26 AM | #41 | |
Rep 935
Have you found any specific pads yourself that are 65mm tall for the Alfa caliper? If not I'll have to go with the 57mm pad and paint the 8mm as originally planned. What is most likely going to be your final choice of brakes, by the way? Have you decided yet? Cheers Az
10-12-2020, 11:46 AM | #42 | |
Rep 75
TRW, EBC, HAWK Performance, Porterfield, Posi-Quiet and Pagid to name a few have the taller pad available. |
10-13-2020, 07:30 AM | #44 |
Rep 75
