12-03-2013, 11:12 PM | #23 | ||
Rep 19,368
All previous indications I've seen indicate that the F2x is a relative of the F3x modular architecture, similar in a way to the F0x/F1x platform. For example, SCOTT has used the phrase "F20/F30 platform" such as in this post: http://f20.1addicts.com/forums/showthread.php?t=536650 Quote:
12-04-2013, 05:22 AM | #24 |
Rep 4,686
Drives: L'Orange
what I know is based off conversations with someone who often works for BMW as a product consult.....BMW really screwed up their profit margins with the E8X 1 series by having a really expensive to produce car that couldn't be sold at a premium price in every market----there's no way they would want to repeat that mistake with the F2X.
From what I've been told in the past, the 1-series was never profitable enough to develop a new chassis for this generation, so they had decided on just tweaking the old chassis with more efficient production costs instead of putting the 2 on a whole new chassis design. I have actually emailed the source of this info to see if I can get further clarification on this matter. EDIT: OK so just had a conversation with someone in the loop and he said there is a lot of carryover from the E8X 1-series to the F2X 1 and 2-series----however the electric system and suspension architecture has been modified, hence those systems will have the most significant performance differences. Otherwise, there's not a lot different. The suspension differences will be the primary difference here it seems. Last edited by IEDEI; 12-04-2013 at 08:33 AM.. |
12-04-2013, 06:36 PM | #25 |
Rep 27
guys thanks for the advice, current update is my local dealer who ive done a fair bit of business with recently have given me a 135 to test over the next few days, the logic being that mechanically the 235 will be near enough identical, first impressions fantastic engine and handling, feels fast enough,fun but maybe lacking in solidity, kinda hard to explain maybe down to the suspension settings but il stretch the legs on it over the next few days and experiment with the settings.
with regards to the m4 now im not sure if this info is out there already but the dealer phoned me yesterday and confirmed that hed just received a set date in june thats going to be the international launch date, cant remember exactly but will ask again tomorrow, but he said this is when the first deliveries will take place. what he did say was if i hold of till jan when the pricing and options on the m4 are confirmed if i place an order i should have the june delivery, theres no need for a test drive if it falls in my budget then i will order however he also said if its outwith my budget come jan then if i place an order on the 235 i will should receive the car in the first batch of deliveries in march, dealer also confirmed absolutely no deals on m4 for first year, deals available on 235 so the moral of the story, i dont need a test in the m4 i know its going to blow me away, so if i can afford it i will order, if its outwith then i will go with the 235 and stick with for a couple of years, enjoy it then find a deal on m4, either way I MUST HAVE THE M4, i will not make the same mistake |
12-04-2013, 07:09 PM | #26 |
Law Enforcer
25302
Rep 22,324
12-06-2013, 05:16 AM | #28 | |
Rep 19,368
Looking past those fairly large omissions, what you describe is fairly typical for platform evolution. The same changes resulted in the switch from E9x to F3x, so I still don't see the evidence that the E8x is derived from the F2x as you had said formerly. |
12-06-2013, 07:47 AM | #29 | ||
Rep 4,686
Drives: L'Orange
Put it this way...the F3X doesn't carry over like the F2X carried over. |
12-06-2013, 08:10 AM | #30 | |
Rep 5,396
anecdotal evidence that there are substantial changes between the two are the performance times and reviews that the European M135i has been able to generate on the new platform (despite the fact that it is hideous)
12-06-2013, 08:41 AM | #31 | |
Rep 4,686
Drives: L'Orange
on the flipside...where is your evidence that the M135i differs greatly from the outgoing 135i coupe in terms of performance times? The 135i was always an extremely capable car....so in terms of a 'night and day' difference it is likely not going to be there. I don't really care at all for the underwhelming 8 speed automatic...so when equipped with a manual there are no real spec differences in speed between something like a 135is and a M135i. If you put a DCT on a 135is (a much better gearbox than the ZF autobox), then you're back in the same realm as an Automatic M135i. |
12-06-2013, 09:14 AM | #32 | |
Rep 5,396
135i - nordschlieife time 8:39.20 M135i - nordschleife time 8:18.00 Pretty clear that it is the quicker car. Its also 2 seconds quicker on hockenheim short. http://fastestlaps.com/cars/bmw_m135i_f20.html http://fastestlaps.com/cars/bmw_135i_coupe_e82.html
12-06-2013, 10:57 AM | #33 | |
Rep 548
"The 8:39 northloop laptime was driven by a 135i with Perfromance package and it was a full lap by a not so skilled driver.. same driver did a 8:31 with a Cayman S (295hp)in the same test a car that was already tested with 8:11 ...most likely the 135i would be 20seconds faster with a better driver at the wheel..." |
12-06-2013, 12:03 PM | #34 | |
Rep 519
_____________________________________________
2016 M6 GC under construction,2013 F10 M5 Akrapovic(sold) 2012 F10 AW 550i MSPORT,Vossen CV3s,ACS Springs,Meisterschaft GTC,.Totalled! E60 M5 Dinan stg3,hiflow throttle bodies,coldair,evosport rear diff,Eisenmann Race sold E39 M5 UUC short shift,UUC Corsa and More Sold |
12-07-2013, 12:43 AM | #35 |
Rep 3,402
I think the M235i will be an excellent car but the M4 will likely be spectacular. If price is not an issue clearly the M4 would be the way to go. The M235i is an excellent value and I think will be a pure drivers car. The M4 will be spectacular and very special. You can't make a bad choice here in my opinion but if you have your set on the M4 it would be a mistake to get anything else.
12-07-2013, 05:45 AM | #36 | ||||
Rep 19,368
It is true we can look at the M235i at the high level and estimate some level of incremental improvement over the 135is. To me, it requires more analysis to attribute the result to commonality between those two cars' platforms rather than to some of the same things that seperate the performance of an F30 335i and an E90 335i, whatever those might be. |
12-08-2013, 09:31 PM | #37 |
Rep 850
looks like it http://www.2addicts.com/forums/showthread.php?t=922022
01-21-2014, 01:34 AM | #38 |
Rep 9,034
Found this on Yahoo of all places.
http://autos.yahoo.com/news/bmw-m2-l...164326487.html They seem to get the feeling there will be a lighter M2. I didn't realize the M235 is a little heavier than the F8x M3/M4?? That thing's a porker, but if it's making 375hp and weighs 3,300 lbs, that would be REALLY interesting since it'll probably have the F8x M3/M4 suspension arms and fixed caliper steel brakes. I'm willing to bet someone will be able to get the full power out of the S55 wtih a tune eventually, maybe even a little more. Similar to the AMG C63 or was it the C55?? If it does have the F8x M3/M4 suspension and a detuned engine and one doesn't need all the lux in the F8x, I'd say this is pretty tempting. .
Let me get this straight... You are swapping out parts designed by some of the top engineers in the world because some guys sponsored by a company told you it's "better??" But when you ask the same guy about tracking, "oh no, I have a kid now" or "I just detailed my car." or "i just got new tires."
01-21-2014, 03:10 AM | #39 | |
Rep 25,151
Good luck.
My car made front page of Bimmerpost
01-21-2014, 06:58 AM | #40 |
Rep 1,140
01-21-2014, 02:06 PM | #41 |
Rep 1,131
01-21-2014, 02:48 PM | #42 |
Rep 896
Well it turns out that M235 is heavy and soft (it should really be called 235). I thought that car would weight 3200 lbs at most...what's the point of smaller car if it almost weighs the same as M4.
Bottom line, wait for M4. |
01-21-2014, 05:43 PM | #43 | |
Rep 27
01-21-2014, 06:33 PM | #44 | |
Rep 2,722
