08-31-2016, 03:00 PM | #23 | |
Rep 3,456
Drives: Harrop E90 M3
Blubaron791436.00 |
08-31-2016, 03:04 PM | #24 |
Rep 713
///Mikey F80199.50 |
08-31-2016, 03:12 PM | #25 | ||||
Save the Manuals
1718
Rep 2,940
Would like to see port and direct injection from BMW. Until then I'll enjoy my S65, M54, and M52TU
2023 G80 6MT, CCBs
2002 330i Dinan, 5MT 2000 Z3 Conforti, 5MT |
08-31-2016, 03:39 PM | #26 |
Rep 7,887
08-31-2016, 03:43 PM | #27 | ||
Rep 10,394
"Drive more, worry less. "
435i, MPPK, MPE, M-Sport Line |
08-31-2016, 03:51 PM | #28 | |
Rep 1,523
08-31-2016, 04:04 PM | #29 |
Rep 65
GTS in the WINTER? Unless you are thinking of using your GTS as a snow plow, given the (lack of) ground clearance and compelling torque power band, not sure the winter + water cooling system issue is very relevant. At the same time, I have seen people drive rear wheel (not 4s) PCar's in the winter...
clbmw632.50 |
08-31-2016, 04:11 PM | #30 | |
Rep 1,523
AWDBooSTIn90148.50 |
08-31-2016, 04:15 PM | #31 | |
Rep 3,622
BMW CCA Member #516012
2016 340i, Estoril Blue, Manual Transmission, MPE, MPBBK, HRE FF04 Instagram: @brandons340i |
08-31-2016, 05:07 PM | #32 | |
Rep 6,764
That would be missing half the fun.
2018 F80 Santorini 2019 Z4 3.0i 2022 X2 M35i |
08-31-2016, 05:16 PM | #33 |
Warrant Officer
375
Rep 1,341
I wonder if the ECU compensates for added methanol into the injection system.
Straight water is pretty lame.
Deleted, ATM I/C and tuned by B.R.R.
08-31-2016, 05:19 PM | #35 | ||
Rep 2,561
Drives: Rapidly from A to B
'07 Z4MR '22 GT4 '18 GT3 '16 GT4, '16 M2, '14 X1, '13 135is, '06 330i, '03 323 Ci, '01 330i, '99 M3 (RIP), '96 318is, some non-BMWs
08-31-2016, 05:23 PM | #36 |
Rep 34
From what I have read, the Water Injection system drains its pipes and is freezing weather compatible. It is also no big deal if you run out, the engine will compensate and run as needed without the water.
Do you really think BMW will put something in their cars that the normal idiots that drive them every day can destroy the car with them? That would not make sense now would it? It is, and will be idiot proof. You would think the worst thing you can do to it is run it dry, but the car will run perfectly without it, it just wont tune itself to gain the advantages from using it and will run like any other non water injected engine would run. The actual worst thing you can do to it is put normal water in it but I can't even see that being that bad if it happens once twice.. If you keep using normal water I am sure build up will eventually clog it up and you would just have to replace a few parts and learn a well deserved hard lesson, but I highly doubt any catastrophic failures will happen due to peoples neglect. |
08-31-2016, 05:26 PM | #37 | |
Rep 2,367
Drives: 2011 335i
08-31-2016, 05:29 PM | #38 | |
Rep 2,367
Drives: 2011 335i
08-31-2016, 05:33 PM | #39 | |
Boost
66
Rep 108
2015 M3 DCT | Dinan Stage 3 Intake, Exhaust, Anti-roll, Mid-pipe, links, Heat Exchanger, Pedals, Coil-overs | Vorsteiner 106 CG 19-10.5 | Yokohama AD08R 305/30ZR19 | Aspen White/Black | M Flat Bottom Steering Wheel, CF Spoiler, Diffuser, Splitter Mirrors and Black Kidney Grills |
08-31-2016, 05:56 PM | #40 |
Rep 1,523
08-31-2016, 06:17 PM | #41 |
Rep 1,643
Oh wonderful - let's add more complexity and parts that can break to our other cars. I can see this on the m models, but they would be foolish to launch this in the regular line up unless it's a separate performance option.
2007 E92 335i MT
08-31-2016, 06:21 PM | #42 |
Rep 4,321
I needed this the other day when it was 105 outside
CURRENT: 2017 RS3 (miss you guys)
SOLD: 2012 335i Mineral Gray M Performance Exhaust/Brakes/Suspension/LSD|Bav Stage 1/AMP||ER CP/IC/DP/OC | Dinan CAI/N55 PWG BIG TURBO|BMWF30.com |
08-31-2016, 09:34 PM | #43 |
Rep 655
Pretty cool tech!
I read that Bmw is planing on using the Ac condenser to fill up the injection tank with distilled water automatically so you don't have to worry about filling it up yourself. |
08-31-2016, 09:41 PM | #44 | |
Rep 586
