04-13-2012, 08:40 PM | #25 |
Rep 2,377
Drives: Perfomance Model 3
i have posted rear and interior shots, enjoy!
'18 Tesla Perfomance Model 3 White on White Performance Upgrade Pkg & EAP
*RETIRED* 2015 435xi GC [f36] | 2012 335i [f30] | 2009 z4 35i [e89] | 2007 335i coupe [e92] | 2001 325Ci [e46] *RETIRED* |
04-13-2012, 08:43 PM | #26 | |
Rep 520
Drives: 2012 F30
Garage List 2012 BMW 328i [10.00]
(retired) 2009 528i [10.00] (retired) 2006 325i [10.00] (retired) 2002 325ci [10.00] |
2012 F30 328i, Melbourne Red, Premium, Sportline, Steptronic, Xenon, Harmon Kardon.
04-13-2012, 09:55 PM | #28 |
Rep 2,377
thx! Glacier Silver is a great color.
04-13-2012, 10:44 PM | #29 |
Rep 652
Wow! Makes me drool. Love Glacier Silver even more. Thanks for the pictures!
Michael
2016 F80 M3 Alpine White / Sakhir Orange / DCT |
04-13-2012, 10:50 PM | #30 |
Rep 2,377
enjoy!
04-14-2012, 01:22 AM | #31 |
Rep 1,322
Gorgeous looking car Matt. Love the clean look of the front end now that the reflectors have been painted.
Presumably you don't have to fix a front licence plate in AZ? Wish the UK was the same. |
04-14-2012, 01:27 AM | #32 |
Rep 2,377
thx PrinceBarin! no front plates required in AZ, now that is a reason to move across the pond.
04-14-2012, 07:22 AM | #33 |
Rep 4,587
Looks so much cleaner with the painted reflectors
Current: 2021 ///M3 Competition Isle of Man Green
Ordered: 2024 ///M2 Zandvoort Blue Past: 2018 X3 ///M40i | 2012 328i | 2009 335i | 2007 335i Coupe | 2005 545i | 2001 325i |
04-14-2012, 11:37 AM | #34 |
Rep 2,377
i have received a lot of questions about the installation of the painted reflectors. i have attached a pic of the reflectors before installation, as you can see there is a pull tab in the corner. around the reflector is a strong adhesive, so you will pull the tab and remove the sticker covering right before you install.
step 1 Drive around for a little while and let everything get hot. (This will make it MUCH easier to remove the reflector). to install you must turn your steering wheel so that your wheel is pointing toward the inside of your car; exposing the front side wheel well. then remove a couple of screws holding the wheel well. after you remove a couple you will be able to pull it back enough to get behind the wheel well. step 2 Use "Goo-Gone" / 3M remover / "Oops"... now, apply the 3M remover to the outside of the reflector around the edges and also behind the reflector, behind the bumper. I used "Oops" and just squirted it all around the reflector and it worked like magic. from behind the reflector pry around the factory reflector and also press on it from the outside of the car. step 3 Now, just SLOWLY push the reflector in (from outside the bumper). Start from the left of the reflector and work your way to the right, slowly pushing the reflector in. You can repeat step 2 as many times as you want to loosen up the 3M tape even more. after it removes wipe down any excess goo gone, get it dry on the inside of the opening. finally, pull the tab on the new painted reflector and press into place - obviously it is installed from the inside of the car. reinstall the wheel well and then repeat on the other side.
*RETIRED* 2015 435xi GC [f36] | 2012 335i [f30] | 2009 z4 35i [e89] | 2007 335i coupe [e92] | 2001 325Ci [e46] *RETIRED* Last edited by matt_435xi; 04-14-2012 at 11:51 AM.. |
04-14-2012, 12:27 PM | #35 |
Rep 4,587
Did you take any pics of the install? I remember on the E92 you didn't need to remove any screws in the wheel well.
04-14-2012, 12:37 PM | #36 | |
Rep 2,377
you are correct, i had an e92 and the reflector was not behind the wheel well. the F30 is similar installation as the e92, but you have to get behind the wheel well.
04-14-2012, 12:41 PM | #37 | |
Rep 520
Drives: 2012 F30
04-14-2012, 01:17 PM | #38 |
Rep 857
when I did this on my E46 M-3, the reflector was on a spring clip. does this appear to be spring loaded ?
To clarify, you used the OOPS on the OEM reflector to loosen its factory adhesive then pushed it out from behind. Is the pressure on the front side from the opposite side you are pushing out from behind. Love the look. Hope to do the same when my AW 335 arrives. |
04-14-2012, 01:20 PM | #39 | |
Rep 2,377
push from outside of the car and the reflector will fall behind the bumper.
04-16-2012, 06:03 PM | #40 |
Rep 151
The painted reflectors look fantastic.
Is there any way to accomplish something similar (at least get rid of the ugly yellow/amber color) while still keeping the car legal in the USA? The problem is not so much the possibilty of a ticket, or failing a safety inspection, rather it's the potential liabilty in an accident. |
04-16-2012, 06:14 PM | #41 | |
Rep 2,377
you must be either an Engineer (like me) or a Lawyer.
04-17-2012, 07:46 AM | #42 |
Rep 68
I have a silver one on the way, but didn't get gray inside. (Black) I sure like the look of your gray.
Order: 13 Mar 2012, F30 328i Luxury, Silver, Black.
05-05-2012, 05:39 AM | #44 |
vrooom
Rep 47
if your f30 is black or white, can't you just plastidip the reflector?? itll be much easier and you can remove it on the spot if you ever get shit from the cops
