330D Hesitation...
12-10-2007, 03:53 AM | #23 |
Techie Geek
37
Rep 681
Well, I can only think that it just needed a bit of a good blow out. I've been driving the car like I stole it all weekend and it hasn't done it since
330d M-Sport | Sapphire Black | Black Dakota | Nav Pro | iDrive | Bluetooth | PDC | Xenons | Hot Seats | Tracker | Blacklines
12-12-2007, 01:33 PM | #24 |
Environmental petrol head.
Rep 165
Drives: 330d Coupé
Never experienced anything like that, but I drive mine as if theres a fire on the back seat the whole time anyway
Currently : 330d SE Coupe, TiAg, Jade Leather Sports seats, HiGloss trim, 17" 188s, 6MT, CA, SunRoof, HBA, Pro Audio, 6CD, Bluetooth & Armrest Retired : 320d SE E90, SG, Blk Leather, Xenons, Bluetooth |
12-12-2007, 01:58 PM | #25 | |
Rep 5,080
Drives: 530d
Never noticed any hesitation on my car or this one.
Gone: Fiesta - Focus - E46 320dSE - E91 330dMSport - E82 135iMSport - R55 JCW Clubman - M135i Now: 530d |
04-28-2010, 06:59 AM | #27 | |
Rep 68
Its very noticable when cruising at anywhere between 50 -90 mph when i am just 'feathering' the throttle (if that makes sense?) , i describe it as a sudden jerk/hesitation ,and its not only when accelerating. There is another thread on this forum with others having the same issue? http://www.e90post.com/forums/showthread.php?t=21514 I have been into my dealer & they cannot diagnose the 'misfire' unless it gets worse first in order to find the fault. I might invest in a new fuel filter ,even though its replacement isnt due until 60k , It will hopefully eliminate poor fuel. We had major issues with fuel pumps & filters blocking up with a thick black oily substance on VW passat diesels 2 years ago which resulted in a worldwide recall of the fuel pump. VW put it down to the fuel quality but the dealers were not convinced. Last edited by jingle68; 04-28-2010 at 07:10 AM.. |
04-28-2010, 08:21 AM | #28 |
Rep 193
My 535d started doing this a while back. A slight drop in revs and deceleration when applying the throttle very very gently when cruising along in 6th at around 1,500 rpm. Feels a bit like feathering the brakes when you are expecting acceleration. I took the senior tech out for a test drive an he agreed it wasn't right. Reading the job sheet afterwards, he'd test driven it himself 3 times when I left it with them and concluded that it got worse as the car warmed up.
In the end they diagnosed that the DPF was requesting regeneration, but that conditions had not been met. At the time I didn't understand this because I do plenty of long runs, but they forced it to do a DPF regen and from what I can gather by the amount of fuel left in the tank and the average mpg falling off a cliff, thrashed the tits off it for a while, which cured the problem. Mine still does it inconsistently some of the time now too and has recently started to really hesitate very badly leading to it having a new DDE unit fitted last week and being left at the dealers again yesterday for who knows what else... |
04-28-2010, 10:26 AM | #29 |
24 cans in a case, 24 hours in a day Hmmmmmm
79
Rep 1,152
I have this on my 320d (163) also, got the BMW area manager looking at it soon at my local dealers as the dealership supervisor says he cant throw labour at it as it is not a consistant issue. But I have read up and the EGR seems to be the problem in some cases, so just need to wait and see.
Present: G30 530D XD MSport
E84 X1 20D LUX |
04-28-2010, 01:32 PM | #30 |
Black .... all the way !!
57
Rep 601
Drives: [Previous]2006 330d M-Sport
Have got this on my 330d - now and again.
Stuck in traffic doing around 45/50, just "moving" along, and it will blip like a split second misfire .... and then be ok for a while, only ever happens when stuck in this kind of traffic ... it makes me feel like I need to change from 4th down to 3rd, but thats too high, so I change back up etc, etc. I need to give it a thrashing I must admit, have been cruising around a little too much recently |
04-28-2010, 01:59 PM | #31 |
Zummerzet Zyder Drinker!
112
Rep 5,541
Drives: '06 330D Le Mans Blue
I'd say this was an EGR issue.......
04-28-2010, 03:26 PM | #32 |
57
Rep 601
04-28-2010, 03:57 PM | #33 |
112
Rep 5,541
Exhaust Gas Recirculation - happens at cruise conditions.
04-28-2010, 04:44 PM | #34 |
57
Rep 601
so is that a "normal" condition then Dave, and if so is there anything you can do to check and confirm it is ??
04-29-2010, 04:24 PM | #35 |
Rep 68
I was speaking to one of our (VW) master tech's today , describing to him the symptoms of what we are experiencing and he thinks it is
'EGR bump' , thats how the technical dept at VW describe it. It is known to happen on 2.0 TDI engines & there is no fix but it wont cause any problems.Something to do with pressure build up & change in the EGR system. So it sounds like you could be right Dr Dave. |
04-30-2010, 07:43 AM | #36 |
Rep 193
I got my car back from the dealers yesterday and they had been unable to reproduce and thus diagnose the problem. Then right on cue it started hesitating on the way back home from the dealer.
Without a fault code to tell them which part to change they are clueless and they aren't prepared to investigate the cause. I drove the car again today over a similar distance and it was fine. Whatever is causing the hesitation in mine, it's intermittent and gets worse as the car warms up. It feels like the airflow is being restricted by something, hence the throttle response is poor and you have to give it a good shove to make the car respond. Just easing the throttle down causes the revs to drop and the car feels like it is decelerating, but it isn't - it's just that it's not accelerating. In my case, it feels a lot like a DPF regeneration but it might not be one. AIUI cyclic regeneration of the DPF is performed by restriction of the air intake flow in combination with 1 or 2 post-injection phases. Mine feels like there is a restriction of the airflow when it happens. What is it that restricts the airflow for a DPF regen, or is this done by the throttle with the EGR valve opening more to compensate? I wonder if it isn't simply that my EGR valve is blocked... |
09-03-2013, 09:14 AM | #37 | |
Skint as always
96
Rep 443
I know this is rather an old thread but I'm wondering if anyone has been able to diagnose this problem. My 2007 (57) E91 330d M Sport has started doing this exactly as the above. Starts & runs perfectly from cold but once it gets warm the miss/Hesitation begins at roughly 1500 rpm. My car has had the DPF removed so it can't be trying to re-gen?? When the problem occurs I notice quite a bit of smoke from the exhaust. I have run BG244 fuel system cleaner through it but the problem still persists. I don't think that it's an injector problem as it only happens when it's warm. I suspect maybe a sensor breaking down?? Any help at all would be greatly appreciated. Kind regards, Kevin
09-10-2013, 10:55 PM | #38 |
Rep 72
I'd say EGR.
I had this problem on my 330d but since having the DPF removed and corresponding tune, I haven't noticed it. My EGR isn't physically deleted, but its function has been removed from the tune. I'm actually now looking into fitting an EGR delete pipe, but from most accounts it makes no measurable difference. I still like the idea of removing that massive obstruction though... |
09-11-2013, 03:18 AM | #39 |
Rep 735
Check your water temps by enabling the hidden menu. Thermostats go weak quite quickly and don't allow car to achieve hot enough temperatures to go into DPF regen ( or are just hot enough but choke when running a regen because extra fuel is dumped into the DPF)
09-11-2013, 03:48 AM | #40 |
Rep 39
+1 thermostat is a classic issue on m57n2 (not complicated).
If you want to check temperature without going hidden menu each time you start the car, you can try the Ultragauge. That's what I bought for my e90. |
