10-02-2014, 03:39 PM | #23 |
Rep 25,988
Looking good! Hmm, I wonder if the negative camber from a drop would help "tuck" the rears in?
VMR|Wheels | 714.442.7916 |
sales@velocitymotoring.com | www.velocitymotoring.com | facebook | flickr | Instagram |
10-02-2014, 04:20 PM | #24 |
Comrade
56
Rep 211
Drives: 15 M4 DCT
10-02-2014, 09:38 PM | #26 |
Comrade
56
Rep 211
Drives: 15 M4 DCT
12-12-2014, 06:15 PM | #27 |
Comrade
56
Rep 211
Drives: 15 M4 DCT
Tommorow i will be attempting to put on the 265/35s on the rear, again. This time i am goingto make the call whether they fit on the car instead of the folks at the dealer while im not there. Will post pics.
12-12-2014, 06:18 PM | #28 |
Rep 25,988
Looking forward to it
12-12-2014, 06:35 PM | #29 |
Comrade
56
Rep 211
Drives: 15 M4 DCT
Does anyone know how much the wheel travels in relationship to the fender, up and down as you go over bumps and corners?
12-12-2014, 11:55 PM | #30 |
Rep 442
Drives: 2018 BMW M2
Awesome wheels, looks very nice...
12-15-2014, 12:48 PM | #33 |
Rep 25,988
That will vary quite a bit. With a stock car, suspension travel (generally) can range from 1-2". This will change depending on how stiff your suspension is (if added springs, coilovers etc). Your alignment/toe will also affect how the suspension travels. For example: with a bit of negative camber the wheel/tire assembly won't travel in a normal South-North but rather South-Northwest/east.
12-15-2014, 01:35 PM | #34 |
Comrade
56
Rep 211
Drives: 15 M4 DCT
I didn't get around to fitting the wheels saturday as planned, had to go pick up a 1970 Cutlass i stumbled upon on craigslist so that took up most of the day. I will try to get it done one of these days and post how it went. Thanks VMR for then info, with that in mind i think the wider rears should work.
11-01-2015, 08:06 PM | #36 |
Rep 566
sergkoko, did you try a 255/35 tire with that wheel (9.5 width ET45) after all? Did it work?
11-02-2015, 10:23 AM | #37 |
Rep 12
Just a note that the recent Dinan S3 prototype had a drop (Dinan) and managed to run this setup. I asked which wheels and tires were on the car and this was the response:
Wheels: Front: 19 x 8 ET 40 – BBS CH-R (custom modification) Rear: 19 x 9 ET 44 – BBS CH-R (custom modification) Tires: Front: 245/35-19 – Michelin Pilot Super Sport Rear: 265/30-19 – Michelin Pilot Super Sport Article with pics is here: http://www.autoblog.com/2015/09/18/2...i-first-drive/ Last edited by dglende; 11-25-2015 at 02:32 PM.. Reason: clarification |
