04-11-2016, 01:32 PM | #23 |
Rep 3,622
I actually feel like I'm blinded by Prius headlights the most. Interesting. I had a hunch my headlights were aimed low
BMW CCA Member #516012
2016 340i, Estoril Blue, Manual Transmission, MPE, MPBBK, HRE FF04 Instagram: @brandons340i |
04-11-2016, 01:57 PM | #24 |
Rep 4,473
The adaptive headlamps at least with AHL2 (retrofittable to E9x cars via coding and I believe standard on F Series cars with adaptive lamps) will aim farther down the road and with a narrower beam at higher speeds, and they deliberately aim lower and wider at low speeds. You can see this happen in your garage with AHL2 enabled by toggling your headlamp switch between Auto (which uses adaptive functionality) and regular On. I wonder if the IIHS testing took that into account? That might also affect the practicality and safety of a DIY headlamp aiming since setting it to satisfaction at low speeds could become dangerously high at higher speeds, and you as the driver wouldn't notice that as much.
And to the point about making sure the left and right beam cutoffs align on a DIY, I don't think that's right either. The charts indicate that the lamp farthest away from oncoming traffic is aimed higher to cast a longer beam because it's safe to do so on that side, which is a standard practice even for non-adaptive lamps,so I would imagine that the cutoffs SHOULDN'T align on a wall test even when aligned with the switch in the regular On mode.
'16 Cayman GT4 (delivery pics, comparison to E92 M3 write-up)
Gone but not forgotten: '11.75 M3 E92 Le Mans | Black Nov w/ Alum | 6MT (owned 5/2011 - 11/2015) |
04-11-2016, 02:00 PM | #25 |
Rep 1,384
Drives: 2018 M3 CS, 2022 911 GTS
All the more reason those with LEDs need to code in VLD and NGHB...only way to realize the full potential of the LEDs.
2018 M3 CS F80 l SMB l EXEC
2020 X5 M50i G05 l MW l BLACK l PREM l DHP l 22” l PARK l EXT S-LINE l LASER l TH l AG |
04-11-2016, 02:02 PM | #26 | |
Rep 4,473
04-11-2016, 02:11 PM | #27 | |
Nomore
158
Rep 793
Or maybe just a short write up on how they should be aimed. Like say. Position car X' feet away from a flat and straight vertical wall. Position headlights so beam is X" inches from the ground... Also theres another adjuster screw that seems to move the actual projector lense itself closer or further away from the HID bulb/internals of projector. What does this do and how does it affect the light beam. Does it widen it in some way or should that not be touched. I accidentally moved that on my car ('07 E92) and i put it back the best i could to where it was originally, but my headlights seem all out of whack and i can't find a guide on how to properly adjust Bi-Xenon projectors or even better specific to the E92 AHL projectors or a guide on how to set up a typical BMW Bi-Xenon headlight for optimal lighting on dark back woods county roads without having to use the high-beams unless necessary or when able too. If anyone has any input on this I'm sure a lott of people would find this helpful!!! Thanks Anthony |
04-11-2016, 02:16 PM | #28 |
Rep 417
Since this got posted on the main page, graphs for the 2er drivers reading this:
According to the new IIHS headlight test, to the front left of the car low beams should shine about 200 ft forward and directly in front of the car the low beams about 320 ft. The IIHS tested 2er with HID headlights measured just under 100 ft on the left (less than half!!! ) and about 250 ft in front (still 70 ft short). For all the halogen people ... |
04-11-2016, 02:50 PM | #29 |
Rep 1,585
This makes a lot of sense. My previous E92 M3 had Xenons with the US-specific coding disabled so I had the full functionality of the Xenon system as they are sold in Europe. Those headlights were incredible, they would adjust at highway speeds to light very far ahead of the car and at lower speeds would aim out wider to cover the right and left. The swivelling into corners was also much more aggressive and useful than the default US setting.
Now, I drive an F30 with LEDs (non-adaptive) and they are pointed straight down into the ground. The low beams are plenty bright but only for objects very close to the front bumper. I'm sure this aiming was done to meet some archaic US regulations, flick on the high beams and you can practically see into the next state. |
04-11-2016, 03:00 PM | #30 | |
European Editor
10851
Rep 22,992
I think the biggest thing is US cars, have weird ride heights. Also the spings tend to sag after a while. And also the car gets strapped down during transport many times over(factory to ship, PDI center, then truck to dealer). This all changes the car's ride height. Then the car gets to the dealer - where they are paid to align the car and check the headlight's aiming. Most of the time this isn't done. I bet IF the car just had their headlights properly adjusted... the test would come out differently. Also the EU coding for the AHL are way better than what passes for DOT/NIHSA laws. The headlight laws in Europe are many times safer than what we have in the US. For my 135i... I had my US spec car "coded" to EU headlight specs. The difference is very noticeable. Starting with the e60... BMW has headlights that put out twice as much light as the US allows on the high beams. On the low beams the headlights have a wider setup, allowing for more wider lit road. As your speed increases, the headlights move to a "straighter" setup - see attached BMW picture. Remonster you can have your F30's LED's coded to EU specs and you will be amazed on the difference in beam pattern and light brightness. IF you have HBA(high beam assistant) you can also have the car turn on the highbeams automatically. Dackel
04-11-2016, 04:14 PM | #31 |
Rep 3,959
Drives: '23 G80 M3C xDrive; '13 e92 M3
I coded on the adaptive headlights... Which are amazing when you actually need them imo.
I live in LA, where nightly driving is usually no big issue. And I just turn on adaptive if I'm going down a dim lit road. Thank you for sharing and explaining the comparison test!
2023 G80 M3 Competition xDrive Isle of Man Green on Kyalami Orange full leather - 826M black wheels - Carbon Fiber Trim - Carbon Bucket Seats - Executive/Driving Assist/Parking Packages - Laserlight - M Shadowline Lights - M Drive Pro - CS Trans/Diff/Steering Coding
2013 E92 M3 Mineral White on Bamboo Beige noviello leather (Base w/ Nav, Comfort Access, Lighting Pack) - DINAN Stage 1 and Free Flow Axle-Back Exhaust |
04-11-2016, 05:07 PM | #32 | |
Rep 220
Drives: E39 M5, F15 35d
04-11-2016, 05:36 PM | #34 | |
Rep 354
04-11-2016, 06:34 PM | #35 | ||
11831
Rep 15,400
It's the darkness we are trying to keep at bay and sadly, the difference becomes too much. To the earlier posts, I appreciate the technology. I felt like stating what I knew was needed because a driver assumes certain things. A car moves. Scenery moves. Situation moves. And those are under our control. Until the world goes wrong and you can't trust all you see. The LED's got no arguments before I took the time to trash them. I was harsh but for a very good reason. Seeing so well in the spots the show is good. It just takes all the rest away. There will not be road testings such as I did with this generation, and my observations won't help many. I wanted to point the flaws out even if I took the hit.
04-11-2016, 07:05 PM | #36 |
Rep 1,747
From factory my low beam was abysmal. After aiming it up a little it is now perfect! The high beam is awesome, the brightest I have had to date.
04-11-2016, 08:41 PM | #37 |
Rep 889
When I had a LCI F30 loaner with the non adaptive LED I thought they light performance was very poor. I did not think they were any better than the adaptive HID in the F30. Whiter and slightly brighter, yes, but performance down the road was abismal.
04-11-2016, 08:47 PM | #38 |
Rep 4,320
BMW USA can easily remedy this.
At delivery, aim lights a few degrees up.
CURRENT: 2017 RS3 (miss you guys)
SOLD: 2012 335i Mineral Gray M Performance Exhaust/Brakes/Suspension/LSD|Bav Stage 1/AMP||ER CP/IC/DP/OC | Dinan CAI/N55 PWG BIG TURBO|BMWF30.com |
04-11-2016, 11:06 PM | #39 | |
Rep 394
04-11-2016, 11:19 PM | #40 |
Rep 2,395
Nice work. On the E9x gen, for non-adaptive headlights (but with the auto leveling feature), you could actually manually adjust how high the headlight pointed by turning the screw on top of the headlight. Does the new gen not have this (or is it just not part of adaptive headlight package)?
04-11-2016, 11:23 PM | #41 | |
In The Rain
8810
Rep 6,549
Drives: '24 GT4RS, '24 Macan GTS
If you have LEDs you will know because LEDs are extremely bright, it is so bright that for night time driving, you cannot see anything else. That is dangerous as LEDs blinds your surroundings at night. Your eyes won't adjust between such a bright object and complete no lighting that is beyond. A stock US LEDs spec is bad, it is aimed so far on the ground you cannot see anything after where your lights are aimed at, especially if there is no ambient lighting. A Euro Spec LED changes that enough where you can actually see things around it, especially with Auto high beams you can see hell of a lot more then what US spec has. The difference between a stock US LED and EU Spec LED is pretty big. Not to mention if you high beam a LED, you pretty much blind the opposite on coming traffic. The point of all of this is that BMW isn't adjusting their LEDs correct for US, it is fine for EU but it isn't for the US. US is pointed too far on the ground and most people that don't follow the forums or care, won't know about coding the LED headlights differently. It is dangerous in suburban areas and US have plenty of that. You will be surprised how low light some places in the US have. Edit: This is as much about how BMW's US Spec LEDs are pointed to the ground as how your eyes work at night. Either BMW themselves missed a step or they don't know how bad the US LEDs they have happens to be.
'24 Porsche Cayman GT4RS Arctic Grey "Alice"
'24 Porsche Macan GTS Dolomite Silver "Gina" Last edited by Arcades; 04-11-2016 at 11:28 PM.. |
04-12-2016, 01:58 AM | #42 | |
Rep 628
04-12-2016, 03:00 AM | #43 | |
Rep 93
04-12-2016, 04:36 AM | #44 |
Rep 1,368
I got the adaptive LEDs on my 428 and i fully agree ... they lighten the road extremely well for 20 meters and then nada... i really wish i could lift the beam a little...
