10-03-2016, 04:46 PM | #23 |
Clean is the new cool, keep it that way.
816
Rep 1,685
Ain't that the truth though about that shitty Honda paint. I have owned many. My GF had a 2010 Mazda 3 Touring with the bigger 2.5L and you never felt like you needed power but it's no sports car. I still own my pristine 98' GSR though
10-03-2016, 05:05 PM | #24 |
Rep 1,575
that's where it was 8thgencivic and hondatech. I knew your name looked familiar.
2.0l ecosmackkaa
10-03-2016, 10:20 PM | #25 |
Rep 318
I'm going to be keeping my eyes open for some 8th gen Honda Civic Si as well. I guess with winter coming, the selection is not as great currently...they also all seem to have very high miles, so I'm going to keep on searching.
10-03-2016, 10:53 PM | #26 |
Rep 1,575
100k civic isn't to spicy. 100k bmw go play the lotto.
2.0l ecosmackkaa
10-03-2016, 11:01 PM | #27 |
Rep 318
10-03-2016, 11:24 PM | #28 |
Rep 1,575
I put 40k on my civic in 2 years. 11 years later it just cracked 120k and the only thing i replaced were a few bushings and the timing chain. It's hard to say but my car i know for sure will make it past 200k miles. If you do get a higher mileage car just make sure the wear and tear items get replaced and your golden. I'm thinking about picking up another si to pay down some bills as well.
2.0l ecosmackkaa
10-03-2016, 11:51 PM | #29 | |
Rep 318
10-04-2016, 12:04 AM | #30 | |
Rep 1,575
2.0l ecosmackkaa
10-04-2016, 12:27 AM | #31 |
Rep 318
Wow where did you find one with such low miles? Thats amazing! All the ones I've seen so far have 90k+ miles, and they're asking $8k+.
10-04-2016, 01:08 AM | #32 | |
2JZ-GTE
3189
Rep 4,181
10-04-2016, 01:31 AM | #33 |
Rep 3,395
If you want a car that is reliable and low maint as a DD for just basic transport then look at the Toyota Corrolla
that 1.8 engine you can beat all day long with a stick and it will keep on going Its got a timing chain vs belt so maint is a lot less and people regularly go 300k without significant issues on these cars Change the oil and replace brakes......flush coolant every couple years and brake fluid |
10-04-2016, 10:23 AM | #34 |
Rep 318
From what I've read, Hondas seem to be one of the most reliable car brands available. I would look into a Toyota Corolla, but that car is way too bland for me...I want something that'll still be fun to drive daily and look less....bland.
10-04-2016, 01:17 PM | #36 |
Rep 518
The only honda I ever had paint issues with was the first gen type r. But they had thinner paint from the factory. But I haven't owned any honda newer than a 97 so maybe things have changed.
10-04-2016, 02:57 PM | #37 |
816
Rep 1,685
My 98' GSR currently has just over 200k and it has driven pretty hard every day of it's life. My daughters 95' Accord EX V-6 has 229,000 miles on it. They both have been meticulously maintained of course. My GSR just got it's second timing belt and water pump change and new engine mounts.
10-04-2016, 04:00 PM | #38 | |
Rep 6,196
I recommend NOT following the factory oil change schedule with the maintenance minder. (just like following the BMW recommended oil changes is a bad idea) I do oil changes with full synthetic every 6000 km. Letting the oil level get low will wear out the timing chain. That is one repair you don't want. If oil level is kept at the proper level, the chain should never require replacement. Every single 8th gen Civic has a paint problem, cracking of the paint on the hood and top of front fenders, and peeling of the clearcoat on the roof. There is an extended warranty from Honda on it. My 2010 is getting its roof repainted in a couple weeks. http://www.consumerreports.org/cro/n...aint/index.htm If you search, you can find the actual bulletins. The earlier cars (2006-2008) also had an issue with 3rd gear grinding, or popping out of gear. Fix is to replace the 3rd syncro. If you roadtest one, try and rev it right up in third gear and see if it goes in nicely. http://www.8thcivic.com/forums/mecha...-3rd-gear.html Last edited by MightyMouseTech; 10-04-2016 at 04:17 PM.. |
10-08-2016, 10:41 PM | #39 |
Rep 318
Okay, so I've been searching and just found this:
http://www.autotrader.com/cars-for-s...39512516&Log=0 What are your opinions? |
10-09-2016, 12:32 AM | #40 | |
Rep 1,575
2.0l ecosmackkaa
10-09-2016, 12:44 AM | #42 |
Rep 1,575
that's what I ran in my civic back in the day. gutted as well.
2.0l ecosmackkaa
10-09-2016, 10:25 AM | #43 |
Rep 19,259
OP, just drive the BMW you have. Why in the hell would you buy another cheap, unrefined Japanese car, when you have a perfectly good BMW? I drive my '06 325i 160 miles a day, hammer the crap out of it, and have been doing so going on 10 years now. Adding another car as a daily driver will just add purchase cost, maintenance cost, and insurance cost for a 2nd car, when you can spend that money on maintenance for the 328xi. The E90 with the N52 easily reach 200,000 miles with little trouble. Hitting 300,000 miles is not much more costly or difficult. The E90 IS a daily driver...
I've been running high mileage BMWs for the past 28 years. There is no better car to drive long term in my opinion. None of the expensive parts (engine, trans, diff) break if properly cared for.
A manual transmission can be set to "comfort", "sport", and "track" modes simply by the technique and speed at which you shift it; it doesn't need "modes", modes are for manumatics that try to behave like a real 3-pedal manual transmission. If you can money-shift it, it's a manual transmission. "Yeah, but NO ONE puts an automatic trans shift knob on a manual transmission."
jpnh1429.50 |
10-09-2016, 12:47 PM | #44 | |
Rep 121
