03-15-2017, 12:57 PM | #23 |
Rep 4,743
Drives: S65 1M Clone & E92 M3 4.6L
03-15-2017, 01:00 PM | #24 | ||
Rep 4,743
The fact that the steering is compromised is really the turn off. You do an s65 swap for character, feel and emotion - the steering should be an extension of that. |
03-15-2017, 01:09 PM | #25 |
#buildnotbought
14226
Rep 5,553
Z4 coupe might be the best chassis. Lighter and much stronger than the e46, especially the rear end. And lower center of gravity.
But that has space under the bonnet for the mighty s85 (which has been done numerous times as a swap)
Z4 3.0i | ESS TS2+ supercharger | Quaife ATB LSD | Brembo/BMW performance BBK front/rear | Schrick FI cams | Schmiedmann headers+cats | Powerflex/strongflex PU bushings | Vibra-technics engine mounts | H&R anti rollbars | KW V3 coilovers/KW camber plates | Sachs race engineering clutch | tons of custom sh#t
03-15-2017, 01:15 PM | #26 |
A family of bimmers
2864
Rep 7,769
built for a shop so more than likely its a writeoff so the 50k price didnt matter much to them.
sounds good and the e46 chassis is a timeless design. if it brings the shop more business then it was worth every penny.
2018 PB/Black G01 X3M40i | 699M | ZDA | ZPP | ZPX | Maxton front lip | X3M vents | 15mm Spacers | Diamond G20 style grills |
03-15-2017, 01:15 PM | #27 |
Rep 1,424
Fun build and nice little package. V-8 in a smaller and lighter car is ideal! The only reservations would be the cost and sacrifices made with the steering. The steering column should be okay (depending on design) for street use. I would be concerned if a car started using sticky tires and lots of track use (which I would).
03-15-2017, 01:23 PM | #28 |
#buildnotbought
14226
Rep 5,553
Somehow if the steering got worse, there would be no point in putting a bmw badge on it.
To me steering is more a bmw trait than power. If you want power, you just as well buy an audi or so. Maybe they'll improve on that.
ilikebmxbikes1524.50 |
03-15-2017, 01:32 PM | #29 |
PAZUZU
546
Rep 2,058
Drives: '15 M4
and as someone mentioned probably positioned in a more favorable way as well (v8 vs straight 6). everyone wished that the gtr would have been produced, well, here it is. you can swap an ls or turbo the s54 but it's not the same.
2009 M3 DCT ESS625+ SOLD 2015 M4 BSM/Silverstone F4LCON @texasMclub IG @jagemoets |
Bolos22.00 |
03-15-2017, 01:45 PM | #31 |
Rep 1,020
03-15-2017, 01:47 PM | #32 | |
Rep 11,907
What are you talking about? The official BMW spokesman has said that he's not aware of any rod bearing issues:
22 Phytonic/Coffee X5 45e (Retired)
08 Speed Yellow 911 GT3 Sharkwerks 12 AW/Cinnamon X5d Sports Pkg (retired) 14 AW/Beige M6GC ZCP, MPE, V2 steering wheel, vorsteiner (retired) 08 SSII/Black E90 M3 (retired) |
Lorde267.00 |
03-15-2017, 01:48 PM | #33 |
Rep 2,013
The vehicle in the video is not a $50K build. He said that at $50K, it would be lower than what the first car cost because all the R&D and trial and error were performed on the first build. It would run one $50K, an S65 powertrain, an E46 M3 donor car, and 6-8 months now. There is no telling how much it cost, and how long it took, for the first car to be built. He did mention that they were incredibly patient during the process...
03-15-2017, 02:08 PM | #35 |
Rep 313
It's actually just the aluminum block from the S65 that weighs less when compared to the S54 cast iron block. Once everything else gets bolted on, it ends up weighing slightly more.
Cool build for sure... Shame about the steering though |
Bolos22.00 |
03-15-2017, 02:15 PM | #36 |
Lord Scrip
1917
Rep 3,089
Drives: 2011 M3 Coupe
Lame that I have to see a sunglasses or watch commercial to see his takes! I get that you have to pay the bills but keep it to 20 seconds bro.
03-15-2017, 02:23 PM | #37 |
Rep 1,340
Swap is redundant. Especially if the goal was to put the S65 into a lighter chassis. The E9x M3 is only about 200-300lbs heavier than the E46 M3. That amount of weight is removable on the E9x M3 without stripping it down to a bare bones. What makes the swap even more redundant is that swapping the motors apparently messed with the steering on the E46.
So basically, they have an E46 M3 that no longer has the original steering feel. The car gained about 100hp, but the motor is now in a car that has an even more outdated interior. All for the price of an: E46 M3, S65 engine, and an additional 50k for the next buyer. And the wait time would only be about 6-8 months. Damn, that's a good deal. |
03-15-2017, 02:42 PM | #38 |
Rep 3,296
#Beastmode
Eendraght Maeckt Macht
FOF82,3pedals,MPE,CCBs,Multicams, CarbonStrucktureAnthracite, CF_Everything BMWPhotoVin, 01of01, GTS DCT, EPS, MDM, CS EDC,Analog Dip ,GTS parts. Euro Vin e30 M3, FIA cage / 14.7 p / w ratio. Euro E30 touring G30 MSport i3s LBB X5M 3.2carrera https://www.youtube.com/channel/UClRTsfNzuz_EjUBu59UCykA |
03-15-2017, 03:19 PM | #39 |
Ya ya ya, I am Lorde, ya ya!
267
Rep 2,771
Drives: E90 M3, 2015 SQ5
Flying Ace5049.50 |
03-15-2017, 03:29 PM | #40 | ||
Emperor
1619
Rep 2,765
BMW was very misleading in their advertising, claiming the s65 engine was lighter. Technically correct, if by engine they meant just the block, but doesn't really paint an accurate picture (full engine weight). But, 30 lbs isn't a ton and the s65 is shorter by two cylinders, so my guess is that weight distro wasn't significantly changed. S62 is far easier-- the electronics, including the stock ecu, are plug and play with the e46 chassis. Electronics are what make BMW engine swaps tricky.
2005 M3 Coupe, 2004 M3 Wagon, 2001 M5 Sedan, 2008 M5 6MT Sedan, 2012 128i M sport Last edited by Obioban; 03-15-2017 at 06:34 PM.. |
03-15-2017, 04:34 PM | #41 |
Rep 1,710
M3Dragon on here is working on a GTR as well. Not sure if he finished it.
DONE: Seibon CF Hood, M3 Rep, MSport rear w/DD CF Diffuser, M3 Rep Skirts, Seibon CSL trunklid, Forgestar F14 18s w/Michelin PSS, Eisenmann catback, AA Headers, BPC Stage 2, Charcoal Delete+revMotor+AFE Drop In filter
FUTURE MODS: LED headlights, CF rooftop, M3 Suspension Conversion, Dinan CAI Mod |
03-15-2017, 04:56 PM | #42 |
Rep 2,777
Drives: M3
Garage List 2016 BMW X5M [0.00]
08 BMW M3 [0.00] 14 BMW X5 50i - sold [0.00] 09 BMW 335i - Sold [0.00] 09 BMW 328i - Sold [0.00] 07 BMW 328i - Sold [0.00] |
honestly this is a great build, but with bugs here and there and costing total within $75K area I think buying a used e92 and e90 m3s would be a much better choice for a daily driving purposes!
Evolve, Eisenmann, Strasse, StopTech, Active Autowerke
03-15-2017, 04:57 PM | #43 |
Rep 1,225
I would choose E46's handling characteristic over S65. S54 is already a great setup for this chassis, why mess up the steering rack?
I hoesntly don't see the point in this build, waste of money and time (6 months? No thx). Not to mention, MPG really sucks on S65s. |
Cbozz746.50 |
03-15-2017, 04:58 PM | #44 |
Rep 1,113
I give him credit but the 6 month build time and so many unknowns in terms of reliability would put me off to something like this. The S54 is already an amazing engine when properly maintained.
2003 11/02 Steel Gray Metallic on Red M3 - SMGII - VF570 - SUPERSPRINT - KW - BBS - CSL ROOF SOLD
2015 09/14 Alpine White on Red 435i xDrive MPPK - Expensive black vinyl with special lettering. SOLD 2020 12/19 Mineral Gray Metallic on Black Vinyl interior M340i xDrive |
