08-31-2017, 05:36 PM | #23 |
Rep 9,783
Yeah that takes way too much work. We make a lot of changes so I was hoping for a quick solution. Basically it goes into a bunch of files and I don't want to have to go through all those steps every time I make a change to the master file. I'll chalk it up that there's no easy way to do this. Thank you for chiming in though!
08-31-2017, 05:40 PM | #24 |
Rep 474
Drives: 2014 328D xDrive
Just FYI, you can copy that data to a new sheet and link it to the original master file.
Master file gets updated, the new file does as well automatically; but the ppt viewers still only see the one sheet from the new file. Either way, good luck with it |
08-31-2017, 06:16 PM | #25 | ||||
MUHAAHAA
236
Rep 610
It seems that the other solution works for you so good luck with that and hopefully that gets you what you were looking for. If done right the way I did it, you can not edit/ delete data, i may have missed some info while typing as well, i am very capable of doing that, that's why I like screenshots. At least i figured out something today because of your question, so thanks. |
