M2 Technical Topics > Mechanical Maintenance: Break-in | Oil & Fluids | Servicing | TSB | Recalls > Check engine light came on
      11-29-2017, 04:19 PM   #23
bollinm
Old Guy
bollinm's Avatar
Drives: 2018 M2 LCI, 2019 X3
2018 M2 LCI  [10.00]
? Update
Curious, what was the answer from the dealer?
      12-02-2017, 06:58 PM   #24
RockinTwinTurbos
RockinTwinTurbos's Avatar
Drives: 2021 BMW SPY M4 6MT
Originally Posted by Prudhvionline View Post
The car is at the dealer from past two days. getting the diagnostic done and spark plugs and coils being checked. they couldn't figure out the problem yet.
at 400+/- miles and just had this happen today. Coil and spark plug replaced.....along with a lecture about break in period
2021 Sao Paulo Yellow M4 6MT (on order)
      01-09-2018, 01:34 PM   #25
Prudhvionline
Prudhvionline's Avatar
Drives: 2018 M2 BSM DCT
Light Came on Again
This may be the fifth time the light came on. The dealer replaced the coil and spark plug last time when it went into the shop. The light comes on every 1000 miles and stays on for couple of days and goes away. Anyone else experiencing the same problem??
      01-19-2018, 01:45 PM   #26
Prudhvionline
Reported the problem to BMWNA
I called up BMWNA and reported about the problem. They have called the dealer and got the info from the previous visits. The car is at the dealer with the check engine light on since yesterday.
      01-27-2018, 05:35 PM   #27
Alpine F82
Alpine F82's Avatar
42
Drives: BMW M3 E92 ZCP (SOLD)
Hey guys! any idea whats on?
Im having the same issue, this is the second Time it happened to me. Im sending the car to the dealership Monday. The first time I sent it they changed my coil packs and spark plugs but it didn't fix anything since it turned back on 1000 miles later.
      01-30-2018, 12:07 PM   #28
Prudhvionline
Got back the car
initially they changed the coil and now they changed the spark plug to fix the issue.
      01-31-2018, 10:02 AM   #29
Prudhvionline
I have seen several people having the same issue. I am guessing mostly with the 18 LCI models. Lets see what happens.
      02-01-2018, 01:00 PM   #30
Alpine F82
Alpine F82's Avatar
42
My CEL went away magically, let me know what the dealer is saying.
      02-08-2018, 08:26 AM   #31
Prudhvionline
Dealer changed the coil and the spark plug. It did make the light go away but if the light comes on again. I have to take the issue seriously. BMWNA is also aware of my issue.
      02-16-2018, 02:39 PM   #32
RsPhi135
Drives: 2018 BMW M2
Any updates on this issue?
      03-12-2018, 09:20 PM   #33
qnet
qnet's Avatar
Drives: 18 Jeep Wrangler, 18 M2 LBB
I hope it's resolved.
      03-19-2018, 02:46 PM   #34
Prudhvionline
Issue Resolved
first attempt they changed the coil and on second attempt they changed the spark plug. its been more than 3k miles after that the light didn't come back. I assume the problem is fixed.
      03-22-2018, 11:57 AM   #35
McPurrs
The deuce gets loose
290
Drives: '17 M2 BSM 6MT
The CEL doesnt just turn off after a few days... codes move from pending to confirmed(CEL) after 5 instances of the pending condition. After 5 full warm up cycles, the confirmed code will clear if the condition is no longer occurring in the last 5 periods. A CEL hardly is a condition to NOT drive in, unless it is blinking. If blinking, shut the car off and tow it.
      04-17-2022, 11:14 PM   #36
shsolus
shsolus's Avatar
Drives: 18 F87 LBB MT / 21 G01 x30i
Does anyone know root cause to this issue?
I have experienced similar behavior on my LCI recently - no drivability issue but CEL just lit.
Following codes were stored but not currently present:
11 errors
  • 140010: Misfire, multiple cylinders: detected
  • 140310: Misfire, cylinder 3: detected
  • 140610: Misfire, cylinder 6: detected
  • 140002: Misfiring, multiple cylinders: harmful to exhaust gas after starting
  • 140302: Misfire, cylinder 3: harmful to exhaust gas after starting
  • 140602: Misfire, cylinder 6: harmful to exhaust gases after starting
  • 213601: Power management: Quiescent current violation
  • 140510: Misfire, cylinder 5: detected
  • 140502: Misfiring, cylinder 5: harmful to exhaust gas after starting
  • 140410: Misfire, cylinder 4: detected
  • 140402: Misfiring, cylinder 4: harmful to exhaust gas after starting
2018 M2, 2021 X3 x30i,
m2
