06-14-2021, 07:50 PM | #26 |
Rep 3,955
10-26-2021, 09:25 AM | #28 |
Rep 275
Oil change
I realize this is an old post. Thanks for the information. It's just what I was looking for. I just had my 2021 X5 M50i in for its first servicing (13 months/8400 miles) and now it has oil leaking on the ground. Found a couple of spots of oil on the garage floor. It's very irritating as the dealer's an hour's drive away.
I dread taking my cars in for service due to the many points you made and for bad experiences in the past. We only checked under the hood, and not underneath, when we picked it up at the dealer and didn't see any oil drips. I've done some of my own oil changes years ago (yeah, I'm a woman ) I know there are a few things that could cause a leak. I checked under my car and see drips of oil along the skidplate. Since they don't remove it to do the oil change, how can they clean up any spilled oil that might get in there? (Does it require a torque wrench?) I don't think my car has a dipstick. If it does, it's not obvious. I think mine has the N63B44T3 (My 2014 F15 didn't have a dipstick either). I ran an oil level check just in case, and it was fine. I'm taking it back in on Thursday morning. smh
'24 X5 M60i Tanzanite Blue II/Coffee
'21 X5 M50i Tanzanite Blue II/Coffee (RIP) '21 M240ix Long Beach Blue Metallic/Red '14 X5 s35i Lux Line Mineral White/Mocha (re-homed) |
10-26-2021, 08:18 PM | #29 |
Rep 3,955
Your M50i should have a dipstick. It's not real obvious to see like many years ago, but it's near the oil fill cap. Has a black handle.
12-12-2021, 12:16 PM | #30 |
Rep 112
Drives: 2020 LBB M2C
The car measured full after adding 7 liters back in, so the amount in the filter was negligible. I'd assume it's less than a tenth of a liter.
07-13-2022, 12:37 PM | #32 |
Rep 1,110
Just picked up a new '22 X7 M50i last week! While I have only 500 miles on it, I wanted to find out more about changing the oil and filter, when I came across this thread describing everything start to finish. Many thanks to the OP for providing this procedure.
I've been underneath enough cars in several decades that I can usually figure out the oil sump plug and oil filter, but it always helps to get a nudge in the right direction. So I slid under the X7 this morning. Drain plug and filter are located as the OP's photos show. Both are close enough to the skid plate to be reached without having to drop the plate (whew!). First -- I always use ramps to elevate the car. Jacks and jack stands cannot be trusted. A set of Rhino Ramps will set you back about $50. If your life is worth less than this, continue using a jack. Second -- There is a dipstick on this N63 engine. It's that unconventional flat top plug looking contraption right next to oil filler cap. Twist a bit and pull up and you'll find a dipstick and level gauge at its end. I'm sure BMW had a good reason for deviating from the conventional yellow finger ring pull that identifies most oil dipsticks. Third -- Most of these cartridge type filter caps have a drain plug in them. The cap on my X7 has a Torx T55 plug to remove before unscrewing the entire cap. Usually, there's at least a pint of oil that needs to come out, and there's much less mess doing this first. I can't see the OP's cap clearly, but there appears to be a removable plug. BTW, this is what the small o-ring in the oil filter box is for. Fourth -- my cap requires a 36mm socket to fit its hex head for removal (1-7/16" is close enough). No filter wrench is necessary as in the OP's procedure. Fifth -- the oil sump plug on my X7 is a Torx T50. I won't bore everyone with the physics behind the T55 on the filter cap and the T50 on the drain plug. Now that I have all the info I need to do an oil change, I can focus on selecting an oil. The OM says 0W-30 with BMW LL-01 approval, but it seems as if many owners are using 5W-30 or 0W-40 of various brands in the Euro spec variety, such as Valvoline, Castrol and Pennzoil. I have about 4500 miles to go to figure it out. |
11-04-2022, 12:59 PM | #33 | |
Rep 1
mvigod181.50 |
01-10-2023, 03:57 PM | #34 |
Rep 326
Drives: 2021 X5M
No mention of torque for oil drain plug or filter housing. I have a torque wrench and was wondering what torque is recommended for the drain plug and housing? Is there a typical range or a specific number for the G05 2019 X5 M50i
02-05-2023, 08:46 AM | #38 |
Rep 64
Anyone else use Amsoil? Royal purple is great too but I’ve used amsoil in my other vehicles for years. If so, do you keep the scheduled service interval? I was wondering with the 45e, since the engine runs less if you can extend the service life of oil.
02-06-2023, 04:38 AM | #39 |
Rep 54
Yes, I'm a long-time Amsoil user - I use it in 4 of my 5 cars (the Cayman takes a C40-spec oil that doesn't have an Amsoil equivalent). My oil change intervals were chosen a long time ago, and Blackstone oil analysis confirms that they are plenty conservative: for anything with a turbo, I replace the oil annually or every 5K miles (all my BMWs and Mini's fall into this category). For any naturally-aspirated engines, I replace the oil annually or ever 7.5K miles. Super-easy to keep track of the intervals if you follow this schedule from new.
FLYSWA30.50 |
07-26-2023, 04:06 AM | #40 | |
Rep 1,110
09-08-2023, 09:04 AM | #41 | |
Rep 15
The manual on the iDrive says sae 0w-30 and Longlife-12 FE or 19. I am not sure if LL-01 is still ok to keep the warranty. Also the genuine oil filter model number has been updated to ‘11425A33C42’. I am going to let a local mechanic to change the oil while I supply the parts and oil. Do I need to buy an oil sump plug as well? I thought I just buy 10.5 Liter of oil and the filter and let the mechanic do the job. |
09-28-2023, 08:26 AM | #42 |
Rep 5
I have a 2019 X7 xDrive50i. The black dipstick next to the oil filler is very tight and I am afraid that I will break it if I tug too hard on it. How do I remove it? Is it supposed to be unscrewed and then pulled out ?
12-16-2023, 02:08 PM | #43 |
Rep 31
Just changed the oil in my 2023 X5 M50 and everything was just like the original post, with the exception of the oil filter housing. On mine, to remove the housing it required a 36mm socket.
I drained the filter housing before removing the filter, but not a lot of oil came out, so when I removed the housing there was still a lot of oil left in there. Not a big deal, but a little messy if you're not ready for it. I'll probably skip the filter drain next time. |
12-18-2023, 10:35 AM | #44 |
Rep 1,022
Haven't attempted it yet but getting close to a mid-cycle oil change
Is there enough room for filter drop without lifting the front on jacks or ramps. Drain plug - usually less. Since the filter is on the bottom, me thinks a smidge more clearance would be required |
