12-18-2020, 12:40 AM | #23 |
Rep 3,665
It depends on where you live and the actual dynamics you encounter.
Here, being able to start moving can be impossible with RWD, next to impossible with FWD at times. It's not snow, it's impacted ice, built up ice, uneven ice surfaces, uphill ice, etc. And it's hard to appreciate AWD until that time in the intersection when a vehicle was spinning towards me (against the signals) and I had to floor it to clear and not get T-boned while making a turn, not to mention the other stuff. A lot of the time, people just use snow-tires to drive on pavement that is warmed by the sun, sometimes a bit of snow, but the plow comes and the snow doesn't build up into ice, because the sun actually comes out there. The road will often be well above freezing due to being dark in color and absorbing the light. The function of the snow-tires for them is maintaining grippy rubber at colder temps...not so much for driving on snow and ice. There's always one person that claims they drive RWD all winter on frozen lakes with racing slicks and it's "just fine". AWD is sold as a gimmick and it is not needed a lot of the time...but then again, people are lazy and they don't put on proper snow tires either. AWD and 4WD are useful at times though and in some places, they do make a lot of sense.
Current: 2018 Camaro SS 1LE, 2023 Colorado ZR2. Former: BMW 428i Gran Coupe.
12-18-2020, 12:41 AM | #24 |
Rep 3,665
Would love to see some of the talkers here get started in an uphill intersection on impacted ice.
12-18-2020, 12:43 AM | #25 |
Rep 3,665
Well, actually, it does. The engine braking that is distributed more evenly is going to have less of a chance of breaking you loose, so when downshifting or letting off the gas, vs. doing the same thing with 2wd that may start you sliding. When traction is scarce, things like this start to matter more. It's not a huge effect, but it's there.
12-18-2020, 08:20 AM | #26 |
Rep 1,118
I’ve had 2 Volvo’s with AWD and my current ml320 cdi with AWD.
Absolute tanks in snow, Ice etc...and I love the traction. I also like stopping. I have winter tires and never worry. Current f10 m5 is a boatload of torque, and I can easily see why they went AWD with the current model, because you can’t put the power down. This argument about RWD is good enough, is just the chest pounding for the pundits about how great their driving skills are... I parked the M5 and bought a golf city with snows... |
12-18-2020, 08:32 AM | #27 |
Rep 2,835
AWD with snow tires is the best option but virtually everyone around here instead goes with AWD and All Seasons. I prefer Winter tires and RWD, mainly because of the negatives of the AWD system and how little it is really used throughout the year. I guess maximum acceleration in bad weather, not something that I care much about. I also live in a city, not Alaska, the Rocky Mountains or the frozen tundra of N. Dakota. Reality is a FWD with All Seasons works pretty well almost all of the time in the city I live in or staying on the major highways, another vehicle that I am not a huge fan of but by far the most practical.
I can never get random people to buy into the idea that my RWD with Winter tires will stop far better than their AWD with All Seasons in the snow/ice. Seems like I am suddenly speaking another language.
2006 Z4M Coupe - ZHP knob, stubby antenna, clutch delay delete
No Boost4053.50 |
12-18-2020, 09:32 AM | #28 | |
Rep 3,326
12-18-2020, 09:34 AM | #29 |
Rep 2,047
No argument that RWD is the worst of the 3 in the snow all things being equal. It's like that playful dog that's always happy to see you no matter what mood you're in. Sometimes you just want a quiet brainless drive to work in the morning. Maybe I should stop turning off traction control all the time.
12-21-2020, 09:58 PM | #30 |
Rep 8
What snow tires did you install? I'm currently looking for winter tires at 4WheelOnline. I've looking forward to trying out a dedicated set instead of using my all-season tires again.
12-22-2020, 12:25 AM | #31 | |
Rep 3,665
Blizzaks are still king.
12-22-2020, 09:20 AM | #32 |
Rep 3,326
I still think Michelin XIce is the better tyre in most urban, ploughed environments. It's not quite as good as the Blizzack in really nasty weather but it is close enough and it wears way slower, is far less noisy and feels better on dry roads than the Bridgestone.
12-22-2020, 11:05 AM | #33 |
///M
285
Rep 390
Winter tires should be mandatory, without them you don't have control over your car, braking, changing lanes etc, regardless if your car is rwd, fwd or 4wd.
Best winter tire is Nokian hakapelita, you have control even on the ice. Depends on your climate area, they offer 6 types of winter tires.
not rich enough to buy cheap
pennsiveguy3549.00 |
12-22-2020, 11:39 AM | #34 | |
Rep 3,665
Before you go off, I've owned the Hakas. Non-studded winter tires have been tested against studded tires. The studded stop in less than half the distance. Most of the test was done on snow, not ice. The difference stopping and starting on ice is still dramatic. AWD makes a huge difference starting on ice with all tires. Studs make a huge difference with control, stopping, starting on ice. The claim that "you even have control on ice" is a bit ridiculous. All of the serious non-studded winter tires do "ok" in some conditions on ice, they'll stop if you feather the brakes early on, you might get started depending on the slope and your traction control/weight bias, but the Hakas aren't dramatically different than the other top-tier non-studded tires.
12-22-2020, 12:11 PM | #35 |
enthusiasm > practicality
4054
Rep 2,245
Drives: 987 CS | G35x
Performance tires such as Michelin Alpin/Perelli Sotozero are good for light snow and dry roads. They provide better handling than Michelin X-ice or Bridgestone Blizzaks which are better for deep snow while sacrificing dry handling and noise. If you drive in the Southeast US, definitely go with winter performance tires.
FSI 3.8L Stg II|6MT|SOUL|IPD+GT3 TB|Numeric Racing|KW|Tarett|Rennline|Raceseng|APEX|Recaro|7.3 lb/hp
VQ35HR|5AT|Stillen|FI|UpRev tune 8k rpm|TransGo|Hotchkis|Whiteline|H&R|Z1|Corbeau|R1 Concepts|10 lb/hp Left lane campers, GTFO! |
12-22-2020, 12:20 PM | #36 | |
Rep 3,326
12-22-2020, 02:35 PM | #37 | |
Rep 923
Drives: 2024 BMW 230i xDrive
Every bit as good as the Blizzaks I had previously (although they were a generation older).
This post sent using 100% recycled electrons.
12-22-2020, 02:50 PM | #38 | |
Rep 1,062
Drives: F15 xDrive50i M-sport
Just mounted up a new set of the R3s. They're quieter than the R2s at freeway speeds and don't feel quite as squishy. Haven't had any snow to play in them with, unfortunately.
2017 F15 xDrive50i M Sport | Superformance GT40 Roush 511 IR FE
12-23-2020, 06:24 AM | #39 |
4054
Rep 2,245
The Perelli's? Read my original post as proof they are quite capable (for now with almost all tread remaining) in packed snow. On ice, I've yet to try but even the best winter tire is over-matched. That said, if Alpin/x-ice/Blizzaks were available in my size, I would've opted for either of those.
12-28-2020, 05:48 PM | #40 |
2006 TIME Person Of The Year
9709
Rep 6,445
What's the ideal tire choice for someone in Montreal isn't necessarily ideal for someone in Maryland, or Mississippi. There's countless factors at play including driver skill and usage pattern. Sadly people can't seem to look past themselves and consider other lifestyles might dictate a different solution, so I'll just leave my contribution here at that.
