(torque curve + technical info) - Euro E92 335i turbo and 3.0 DI engine Power diagram
04-25-2006, 04:30 PM | #23 |
Rep 10,185
Some words on the DI Engine
Introducing direct gasoline injection, BMW is taking yet another major step in enhancing the efficiency of its straight-six power unit. Retaining all the features and characteristics so typical of this engine, High Precision Fuel Injection is becoming a new highlight on the six-cylinder. One of the special achievements in engineering is that the new piezo-injectors have been fully integrated without requiring any compromises in the design and configuration of the cylinder head and pistons. The engine thus maintains its original character based on free-revving performance and outstanding running smoothness, despite the optimisation of all-round efficiency. With maximum output of 200 kW/272 hp and peak torque of 315 Newton-metres or 232 lb-ft, this is also the most powerful version so far of BMW’s 3.0-litre six-cylinder normal-aspiration engine. And on the road, this means two advantages in one: a further increase in engine dynamics and a new dimension in all-round economy. Clean and intelligent: NOx storage catalysts. BMW’s new straight-six power unit with High Precision Fuel Injection is being launched initially in the European markets. Then, with sulphur-free fuel becoming increasingly available also elsewhere as the prerequisite for the NOx storage catalyst technology featured in the engine, the new power unit will make its entry step-by-step into other markets. Yet a further advantage is that European customers will also be able to use their car in countries where sulphur-free fuel is not yet available everywhere. While in such cases the engine will not be able to offer its particular fuel economy in full, since in that case the storage catalyst will require regeneration more often than when running on fuel free of sulphur, there are no objections to running the engine also on fuel containing sulphur, when a European customer travels abroad.
BMW if you are reading, I need a job, Please. |
04-25-2006, 04:33 PM | #24 |
Rep 10,858
Any thoughts about the different hp/torque specs on euro vs. USA versions of the 335?
Euro: 306hp, 295lb-ft USA: 300hp, 300lb-ft smoke and mirrors, or some real tuning difference? And do we have any fuel efficiency data on the N53 yet? They keep claiming it is better, but where are the figures? Note also that the N54 is 57 lbs heavier than the N52. It might be lighter than a V8, but it is a lot heavier than the magnesium/alu composite engine. The N52 actually has the best power/weight ratio of all three engines. |
04-25-2006, 04:42 PM | #25 | |
Rep 10,185
In laymans terms "USA Horses are bigger "
04-25-2006, 04:44 PM | #26 | |
Rep 10,185
Unfortunately the N52/N53 manesium/aluminium block cannot take the forces of the turbo
04-25-2006, 05:02 PM | #27 | |
Rep 10,185
But it looks like the USA wont get DI for now
04-25-2006, 05:08 PM | #28 |
Rep 10,858
I have heard that next spring/summer might be a possible release date for the N53 in the USA, but that such plans were especially vague given their dependence upon the fuel availability. That would facilitate a move to a 325 N51, 330 N53, 335 N54 (perhaps upgraded) lineup for 2008.
04-26-2006, 12:50 AM | #29 | |
BMW, can I have some LSD please?
88
Rep 1,591
Man, it really sucks to be an early adopter!
2006 330i | TiAg | Black | Al | 6MT | Sports Package | Logic 7 retired
2008 335i | AW | Black | Al | 6MT | Sports Package | Logic 7 retired 2013 328xi | Red | Gray | Al | 8AT | Sports Line | Premium | Executive | Heat Pkg retired 2017 340i xDrive | Estoril | Black | Al | 8AT | M Package |
04-26-2006, 07:52 AM | #31 | |
Rep 7,047
I was just pointing out that the NA engine has a "longer" rev band and revs higher. That is a more desireable trait in racing as some feel it has gearing advantages. That new TT engine looks like a sweet piece albeit a low revving engine more like a diesel. Odd, but cool. |
04-26-2006, 07:58 AM | #32 | |
Rep 10,185
04-26-2006, 08:04 AM | #33 | |
Rep 713
Drives: e46 330ci, e92 335i, 2008 128i
granted the torque comes on early bit there's way more top-end than even the relatively high-revving bmw diesels have( it's still making 100hp/ltr compared to 75 or so for the diesels). |
04-26-2006, 08:14 AM | #34 | |
Rep 7,047
It's interesting that the redline is still listed as 7000rpm, but power drops WAY down after 5800. Gearing will be quite interesting in this thing. BTW, that "torque curve" listed in the picts looks more like a marketing torque curve. I've never seen a curve that flat, it's truly "table top" flat. It almost looks like something is holding it back. Either there is a bit more there or they've pushed the turbo's to the limit. Given the small size fo the turbo's they are using, chipping may not net much without some turbo replacements. And, if one goes that way that power band will probably move up the rev band. The prospects of a 3.0 liter twin turbo are really cool. Remember the TT Supra's and Mit's VR4? BIG power could be made with some work. BTW, what is the compression ratio in this new TT engine? And, what is max boost pressure rated at? I think I missed it in the chart. |
04-26-2006, 08:17 AM | #35 | |
Administrator
41326
Rep 21,249
04-26-2006, 08:24 AM | #37 |
Rep 10,858
IMO there is little doubt but that the engine management is very conservative, limiting power to avoid reliability issues and perhaps enhance fuel efficiency. The CR is 10.2. Boost is low and steady, 1.6 (about 3.5 in US lingo).
04-26-2006, 09:45 AM | #38 | |
Rep 713
only 3.5psi! i'd say that's good news: lag should be virtually non-detectible and the overall stress on the engine likewise should be minimal. |
04-26-2006, 11:26 AM | #39 | |
Rep 7,047
These are low pressure turbo's and 3.5 psi would be VERY low pressure. However consider that they are extremely small in the world of turbo's. Fuel efficiency of this engine is good for the power output, but not in terms of mass sales on a bread and butter car. The MPG is lower than the E90 3.0 engine. The CR is very conservative also for a small lower pressure turbo, if those numbers are correct. The new Audi DI 2.0T turbo is running over 12psi of boost and compressions is at least 10:1 and more. Limiting power boost in the BMW 3.0 is probably more to do with the small turbos to spool faster/sooner- less lag, more so than being conservative in tuning. Those stock turbo's don't appear to have much in reserve for future modders. There may be a bit more, but it seems the turbo's will need replacement for serious modders. For average Joe's, why bother changing the stock power? It looks pretty amazing as is. |
04-26-2006, 12:08 PM | #40 |
Rep 10,858
I am not sure about the stats on boost. I am straining my memory, I think from Klaus Borkmann's speech.
1.6 bar = 23 psi But that is not feasible and not what I remember as the boost level on the N54. Edit: maybe the 1.6 bar stat listed in the spec sheet is a typo, .6 bar would be 8.7 psi, which makes more sense as the absolute max. boost stat. |
04-26-2006, 12:15 PM | #41 | |
Rep 2,099
The turbo engine on the other hand, well.... we'll just have to wait and see what that co$t$. |
04-26-2006, 12:32 PM | #42 | |
Rep 374
Drives: '05 645Ci Coupe
My handy dandy converters get from 225kw the following horsepower measurements. Metric (PS) = 305.9 US (SAE) = 301.73 SAE TSB 003 dated 1999 where HP to Kw = multiply by 0.7456999 and my torque conversion obtains from 400Nm the following 295.0248 ft-lb with no European/USA distinction. I use the official formula from SAE TSB 003, dated 1999, where ft-lb to Nm for engines = 1: 1.355818. You can find several unit converters that get u close to these numbers but not exactly probably due to rounding. |
04-26-2006, 12:35 PM | #43 | |
Rep 374
I believe we need another source or two on the boost figure. |
04-26-2006, 12:59 PM | #44 | |
Rep 645
Also, has anyone seen the size/location of the intercooler on the 335i? |
