BIMMERPOST Universal Forums Off-Topic Discussions Board Home maintenance tips or home trickery
      11-14-2021, 03:47 PM   #23
dinonz
Drives: 2016 M3 MWM ZCP
Somebody was innovative right there.
Give her half a chance and she will ceramic coat anything. She's ceramic coated her sunglasses to keep them cleaner
      11-14-2021, 03:51 PM   #24
Loves her job, eh?
I need a detailer like that.
      11-14-2021, 05:10 PM   #25
Tommy-G
Tommy-G's Avatar
4685
Drives: 2015 435 Vert Alpine White
The local ceramic guy advertises coating counter tops and all kinds of home surfaces
      11-14-2021, 05:10 PM   #26
RickFLM4
RickFLM4's Avatar
Drives: M4
I put this stuff on our shower glass in Asheville before the shower was ever used:
https://www.nanovations.com/nano-glass-coating.htm
Works incredibly well. Sure wish I knew about it when we remodeled our FL bathroom.
Current: 2018 SO/SS F83 ZCP
Gone: 2015 SO/SO F82
      11-14-2021, 05:12 PM   #27
RickFLM4
RickFLM4's Avatar
Drives: M4
Dawn Powerwash for outdoor cleaning, such as sliding door frames.
Also Barkeepers Helper or Bon Ami for cleaning lots of stuff where a mild abrasive is needed. I use it in annual deep clean of my grill.
2000cs3985.00
wrickem2204.50
      11-14-2021, 07:41 PM   #28
overcoil
Drives: M235i 6spd
Dawn Powerwash Spray and cold water are also an excellent way to wash eyeglass lenses.
RickFLM411949.50
      11-14-2021, 08:09 PM   #29
lakefront
Drives: Whatever's in the garage
Originally Posted by upstatedoc View Post
Now you tell me I've been doing it wrong all these years…
Does anyone have a solution for losing those little red straws that come with the can?
Buy the newer cans that come with built in straw.
King Rudi13079.50
      11-15-2021, 03:16 AM   #30
Costco do large 3 can packs of WD40 with the built in straws.
      11-15-2021, 09:48 AM   #31
King Rudi
King Rudi's Avatar
13080
Drives: Meat Suit
Invite all your neighbors over for dinner.
After dinner, kill them, enslave them or imprison them all and take their land to establish dominance.
Sorry, the holiday next week has me in a Thanksgiving kinda holiday mood.
Seriously though, change the direction of your ceiling fans twice a year. Counter clock-wise in summer to push cold air down and the hot air up, reverse for winter months. Should save you between 7-10% on your energy bills.
Drill a hole in the back/lower section of your trash can. This allows the full trash bag to be easily lifted out, rather than creating the suction effect. I also keep a sock of rice in the bottom to reduce odors.
Originally Posted by jmg View Post
We're Americans. Leave your logic and science witchcraft out of this! Jesus and guns are all we need.
Tommy-G4684.50
vreihen1622118.50
2000cs3985.00
wrickem2204.50
      11-15-2021, 10:25 AM   #32
RickFLM4
RickFLM4's Avatar
Drives: M4
Put dry pasta, rice and flour in the freezer for a week to avoid weevils, also known as pasta bugs.
      11-15-2021, 10:38 AM   #33
OkieSnuffBox
Drives: '13 135i
Originally Posted by 2000cs View Post
Plug all holes in exterior walls with steel wool and caulk. That’s the only way to keep mice out that works.
We had a serious mouse problem over the winter and spring. Construction a few blocks away where they are building a new edition, plus two ice storms that caused huge amounts of brush to be piled up in yards, waiting for the city to haul them off, gave the perfect breeding ground/hiding places.
Sealing interior things didn't work, exterminator and poison didn't work either.
I finally called a wildlife remediation company. They don't use poison that way you don't end up with dead mice in the walls rotting away. They put some traps in the attic above the garage and made sure the entire EXTERIOR of the house was completely sealed.
Then they come back and check the traps every week for 4 weeks. By week 3 no more in the traps, and we haven't had any problems since in the last 9 months.
$1400 well spent.
vreihen1622118.50
2000cs3985.00
Buug95924461.50
      11-15-2021, 10:45 AM   #34
unluky
unluky's Avatar
7698
Drives: 04 z4 3.0 Sport & 15 X5 35i XD
https://www.amazon.com/Spray-Can-Noz...J%2CB06Y44MMT6
2015 X5 XDrive 35i - 2004 Z4 3.0 Sport
King Rudi13079.50
dtox9358.00
      11-15-2021, 11:05 AM   #35
infinitekidM2C
infinitekidM2C's Avatar
Drives: 2019 M2 Competition
Once the coachroaches have formed an HOA, it's time to call the exterminator.
      11-15-2021, 02:53 PM   #36
Put masking tape anywhere you are going to drill/saw, and the edges of the wood won't splinter.
King Rudi13079.50
wrickem2204.50
Tommy-G4684.50
jmack548.50
carseatsm51020.50
      11-16-2021, 11:21 AM   #37
You can cut a long length of wire coathanger and chuck it in your drill to put a starter hole through a wall or other material that is too thick to run a normal long bit thru - use dykes/plier cutter so the tip is sharp. Don't re-use it more than a couple of times - the heat will make the tip brittle, and you don't want it to break off in the pilot hole.
putting a little bar soap on the screw threads will make for easier install, especially in hardwoods (just pull the screw along a bar lightly).
wrickem2204.50
lakefront673.00
      11-16-2021, 01:25 PM   #38
Bonk!
Drives: 2016 235i m
Originally Posted by LemansE90335xi View Post
Rub a bar of soap on squeaky door hinges to end the squeakiness.
or on the bottom of drawers to make them slide more easily.
Buug95924461.50
      11-16-2021, 01:35 PM   #39
King Rudi
King Rudi's Avatar
13080
Drives: Meat Suit
This is the move for sure on acrylic countertops.
Or you can just use ultra high molecular weight polyethylene film coated with a pressure sensitive acrylic adhesive. Otherwise known as UHMW tape.
https://www.amazon.com/dp/B07JFTYPWK...dDbGljaz10cnVl
      11-16-2021, 01:54 PM   #40
I needed just one 6' fence panel to protect a side entrance so instead I did a bodge job lashing the loose edge of it to neighbours concrete post with a thick nylon string going over a strengthening piece of wood on the other side. I didn't want to order just one panel.
      11-16-2021, 01:55 PM   #41
2000cs
Drives: Potato
There is a technique for every job that will make it better, and sometimes faster. It is worth learning before starting. Old days we’d chat at the hardware store, now it is YouTube.
I used to believe in buying or renting the right tools for the job. Now I understand that the more tools I own, the more jobs I take on. So I got rid of all but the basic tools in our last relo.
King Rudi13079.50
vreihen1622118.50
      11-16-2021, 02:13 PM   #42
King Rudi
King Rudi's Avatar
13080
Drives: Meat Suit
There is simple genius to this.
      11-16-2021, 05:24 PM   #43
tranquility
sportscars only
tranquility's Avatar
Drives: 2011 Z4 sDrive 35i
For those w OCD about not making holes in walls, 3M Command Hooks/etc are a godsend (some can even hold 25lbs+!). The only holes I have are for the TV and window coverings.
The richest one percent of this country owns half our country's wealth, five trillion dollars. One third of that comes from hard work, two thirds comes from inheritance, interest on interest accumulating to widows and idiot sons and what I do, stock and real estate speculation...It's bullsh*t. I create nothing. I own. We make the rules, pal...Now you're not naive enough to think we're living in a democracy, are you buddy?
      11-16-2021, 05:28 PM   #44
XutvJet
XutvJet's Avatar
6102
Drives: 2011 Cayman Base, 2018 M2
Spring-loaded punch. It will punch a pit in hard metal, wood, sheet rock, whatever. I use it all the time to set a point for my drill.
https://www.amazon.com/General-Tools...a-428924058137
Dry wall anchor screws. No more fear hanging heavy items on walls. Yeah, it creates a big hole when you remove them, but it's easy to fill.
https://www.amazon.com/Drilling-Dryw...93753802&psc=1
Tools, tools, tools. Use the right tool for the job. It makes life much easier and will give you confidence.
The forest was shrinking, but the Trees kept voting for the Axe, for the Axe was clever and convinced the Trees that because his handle was made of wood, he was one of them.
