12-16-2021, 02:34 PM | #23 |
Rep 422
Drives: 2017 F31 328dx
I had this exact thing done in my basement about 7 years ago. Anytime it rained I had a little stream running from one side of the basement to a drain in the corner. We flooded once during a hurricane and after that we had the weaping tile, french drain and sump pump installed. It's been excellent and my basement has been dry since including when my water heater burst. They had put drains around it so that it saved the basement from flooding.
The only thing I recommend is when they put the drain out in your yard have them put in a dry well so the water has somewhere to go if you get a lot. I am going to be digging out a dry well next year where my drain is because during really rainy times my lawn becomes a big puddle. |
dreamingat30fps5996.50 |
12-16-2021, 02:43 PM | #24 |
Rep 1,264
Drives: 04 z4 3.0 Sport & 15 X5 35i XD
I'll agree with the start outside first. My buddy bought an older house with a basement when we were young. It had small cracks in the walls but the basement was pretty dry except for hard rains. It was "unfinished" and painted, but you still don't want water down there.
He worked on his gutters and we hauled in 3-4 loads of dirt and started against the house and tapered it out about 3-4 feet away from the house - then he was going to redo the drain in the basement - but the gutters and dirt fixed it all. Getting the water to flow away from the house cured all his issues and he lived there another 3-4 years and the basement stayed dry the whole time.
2015 X5 XDrive 35i - 2004 Z4 3.0 Sport
12-16-2021, 03:44 PM | #25 | |
Rep 3,025
If there is a french drain watch the clean out during the rain. If it becomes overwhelmed (rising water) then the sump pump cannot pump against it and the water will rise out of the sump pit. If you have a sump pump and a PVC pipe daylighting into it there is probably an internal french drain that they can also use for radon mitigation. Not sure if that is an issue down south. I thought I was fine. For the past 11 years nothing. Then w/the last hurricane the power went out and the water rose in the basement ~6". I believe the good news is that the water table around my house is no higher than 6" and above that will drain away no matter how much rain? So now I need to get off my a** and get a generator and backup for the sump pump so it doesn't happen again. http://constructionmanning.ca/french...waterproofing/ <- I've never heard of draining an external drain into the house sump. Usually the opposite my sump pumps into the drain which goes to a dry pit. Last edited by omasou; 12-16-2021 at 03:55 PM.. |
12-16-2021, 05:14 PM | #26 | |
Rep 2,039
Here is a pic of what the guy was talking about. |
12-16-2021, 09:05 PM | #27 |
Space Force - 4 Star General
11505
Rep 3,265
I might be in the minority here but when I see a house with a sump pump in the basement I think "no thanks, don't want those headaches." I'm not sure it would stop me from buying a house but it certainly would reduce the value in my mind. I know they are super common and no big deal so maybe I'm just weird but they freak me out a little. So I'd much prefer in my own house to solve the issue outside of at all possible and not risk taking a hit on home value by digging up the basement and installing the pump. Besides, all that water starts outside and comes in the basement so why not try to prevent it from coming in in the first place. Kinda like plugging the hole in the boat vs just bailing the water out after it comes in.
dreamingat30fps5996.50 vreihen1621641.50 |
12-16-2021, 10:36 PM | #28 | ||
Rep 949
