BIMMERPOST Universal Forums Cosmetic Care & Detailing (PPF/Wash/Wax/Detailing/Restoration/Repairs) Car Soap for Ceramic Coated G8X
      09-18-2022, 08:34 AM   #23
PHXATC
Drives: '22 911 '20 430i '20 Explorer
Originally Posted by Limegrntaln View Post
I just washed my car, yesterday, and although they tout the hell out of Koch Chemie GSF, I've used it a few times, and I think it leaves some ugly residue behind. I don't know if maybe I'm using too much in the bucket, or what? But I find myself having to wipe the soap off of the panel, that doesn't rinse off, even with a good pressure washer.
I don't remember having that problem with the Gyeon Bathe. I may go back to that. Or, next time, just pay more attention to making sure that the soap is actually mixed better in the bucket.
I have that same problem with GSF and have found that using less soap seems to help, no matter in a foam cannon or in just a bucket. The key to me, although for the record it does NOT completely eliminate the weird film it like to leave, is to suds up and use your mitt, then rinse quickly with a normal hose pattern (just a hose, no pressure washer, on full tilt boogie) on each panel that you wash.
I found that even using optimal conditions with a pressure washer that has more water volume than high pressure, washing inside in my AC'ed garage, the GSF still requires some extra attention and care to get that wonky weird film off (or not allow it time to dry and form up).
I am not getting any more GSF after I use these two bottles up, as it doesn't seem to raise my wash game any at all, in fact, it adds another item for me to put in my checklist when washing with GSF. Not worth it. Washing should be easy!
Limegrntaln14354.00
      09-18-2022, 10:48 PM   #24
Limegrntaln
Limegrntaln's Avatar
14354
Drives: 2024 Model S Plaid
I'm definitely getting something else, next. I haven't tried Reload, yet. I may give that a try. My car is full PPF and Ceramic anyway.
SOLD: 2022 DravitGrau /Black Full Merino M4 Competition M xDrive / Production Week 34/ Delivered 10/19/21/ IG: dravit_m4_comp
YT: G Dubyou
PHXATC82.00
      09-19-2022, 10:42 AM   #25
shawndean22
Drives: 2022 BMW M3 (on order)
How much soap are you using? I use GSF as well and did not have any issues. I use 1oz for every 8 oz in foam cannon. I end using 3oz for 24oz of water.
Limegrntaln14354.00
      09-19-2022, 06:52 PM   #26
PHXATC
Reload does the full PPF and ceramic quite handily. Just washed the 911 (PPF and ceramic) and the BMW (just ceramic) and used Reload, outside, cloudy FL day, dried both inside the AC'ed garage and zero janky film that GSF leaves.
Cheers!
Limegrntaln14354.00
      09-19-2022, 07:15 PM   #27
Limegrntaln
14354
Cheers!
That's what I need, for sure. I'm still wiping the GSF film off the car, that didn't wash off.
YT: G Dubyou
PHXATC82.00
      09-19-2022, 09:28 PM   #28
Limegrntaln
14354
I don't measure it into a 5 gal bucket. I just dump it over and let it chug 2-3 times. Leaves a dollop about the side of a grapefruit.
YT: G Dubyou
      09-20-2022, 10:32 AM   #29
shawndean22
Yea not too sure, I am thinking either too much soap or the type of protection on the vehicle already.
GSF is pretty solid for most people.
Limegrntaln14354.00
      09-20-2022, 06:58 PM   #30
Limegrntaln
14354
It seems like Feynlab ceramic doesnt like it.
YT: G Dubyou
      10-05-2022, 02:12 PM   #31
forumlurker
forumlurker's Avatar
790
Drives: almost every day
Reset. It also foams really well in a foam cannon.
      10-14-2022, 02:23 PM   #32
adr_M3
Drives: G80 Comp RWD Oxide Grey
Thanks all for your suggestions. It seems like CarPro Reset is the popular choice so I went ahead picked some up and I see why it's so popular. A little goes a really long way and it manages to produce a lot of suds. I was particularly impressed during the drying process there was no hint of sticky residue; something that I noticed when using Chemical Guys. All in all I'm very satisfied and grateful for everyone's advice!
      10-15-2022, 10:43 AM   #33
PHXATC
Good to hear you like it and Reset fits your needs. Plus, it just smells good too.
adr_M3374.00
      10-23-2022, 05:33 PM   #34
Seanhfx
Drives: 718 Porsche BGTS
Have used GSF only since the spring, before that it was off and on with Adams. GSF is great, love the smell. I have had no issues with it and use it both in cannon and in the bucket.
As for reset, that's more of a 2-4 times a year soap to help get rid of road film and reset the coating.
2023 M3 Competition xDrive Edition 50 Jahre (Techno Violet Metallic) August 11, 2022 Production Date - SOLD
Delivery Date - October 24, 2022
2021 M340i xDrive M Performance Edition - Sold
2017 340i xDrive - Sold
      10-26-2022, 01:04 AM   #35
Aalfred
Drives: '25 IX50, '23 M3CX
Might be considered Blasphemous here, but can I just go to a touchless carwash if I have Xpel PPF and ceramic coating or is that a big No No. Dont have much time to hand wash the car and isnt the PPF supposed to protect the paint anyways.
      10-28-2022, 05:00 PM   #36
GoBlue0310
GoBlue0310's Avatar
Drives: 2023 IOMG M3CX
I'm no expert but I probably wouldn't. I would be concerned about the PSI coming out of sprayers on the touchless car wash. I have to imagine it's pretty high given they want ANY car that goes through to come out clean regardless if it's coated, PPF'd, or factory clear coat. Have you thought of ways to reduce the wash/dry time so you can fit a quick wash into your schedule occasionally? Don't have my G80 yet but I have a X7 that is ceramic coated that's fairly easy to wash. I save a ton of time by using a DI rinse. You can legit just rinse it then let it dry, full sun, no sun. Doesn't matter dries without spots. With the ceramic coat and a good soap most things wash right off. Get a good maintenance spray/wash and the ceramic coat hydrophobic properties will last and make washing way easier. Another time saver is a retractable hose reel. Has to save at least 10-20 minutes of uncoiling/coiling a hose back up and storing it. I totally get the busy life thing so I spend the extra money trying to cut time off of the time consuming things like washing my car.
Aalfred3074.00
      10-28-2022, 05:05 PM   #37
GoBlue0310
GoBlue0310's Avatar
Anyone have any experience with Adam's Graphene Shampoo? It's pH neutral and has SiO2 to help maintain the ceramic coat hydrophobic properties.
      10-28-2022, 06:34 PM   #38
luckylingy
luckylingy's Avatar
3377
Drives: X3M
If you don't mind light surface scratches that you (or a paid detailer) periodically remove, an automatic carwash is a reasonable option for us in northern climes with limited time to keep a car clean. Regular washing is better than leaving road salt residue to fester until you have time for a proper hand wash.
Such was the case with a Black Sapphire X5 we recently replaced. It was ceramic coated upon (new) delivery, then run through a decent automatic carwash at least weekly. I applied a light polish and touch-up layer of paint sealant a couple times a year. TBH, it looked pretty good to the naked eye after 3 years.
On the other hand, both current BMWs are hand washed exclusively, and neither are showing any surface scratches after 8 and 11 months.
Aalfred3074.00
      10-28-2022, 07:47 PM   #39
Aalfred
Thanks. Its really a pain to hand wash cars with temp consistently below 50 for like 6 months and winters being really cold with all the road salt causing more issues. The light polish and the paint sealant seems to be a good idea. Will try that atleast in the winters and then do a proper hand wash during the summer.
      10-28-2022, 07:50 PM   #40
Aalfred
Thanks. It gets cold up here by Oct and lasts till May. Average temp is like 50-55F with lows of like 35-40F. Doing a outdoor handwash is hard with the cold and the water freezing on the ground. Thats why thought id do the automatic wash during winters/spring and hand wash them in Summer.
      10-28-2022, 07:54 PM   #41
GoBlue0310
GoBlue0310's Avatar
No worries. I get it. I spent the first 18 years of my life in Michigan so I know where you’re coming from. Just trying to help you with possible solutions that won’t ruin your car.
Aalfred3074.00
      10-28-2022, 08:03 PM   #42
Aalfred
Appreciate it. How did u do it in the winters? I usually turn off my outside faucets by fall before the first freeze. Also my car is a detached garage and gonna be standing outside in the cold washing it
      10-28-2022, 11:57 PM   #43
GoBlue0310
GoBlue0310's Avatar
I just meant about doing anything in the frozen tundra up north. I was young in those days and wasn’t worried about how to detail a $100k car in the winter months. Wish I could help you there.
Aalfred3074.00
      10-29-2022, 06:10 AM   #44
luckylingy
luckylingy's Avatar
3377
Drives: X3M
I faced the same challenges as you, until a recent home renovation -- hence my reliance on automatic carwashes. Now our garage is heated and decluttered (new garden shed), and there's hot/cold soft water spigot installed. I can comfortably wash our vehicles indoors with the garage door cracked to let the water drain outside. The only downside is dealing with small area of ice on the driveway until the next warm-up.
Aalfred3074.00
