BIMMERPOST Universal Forums Off-Topic Discussions Board I have a brisket situation
      09-12-2022, 12:53 PM   #23
Alfisti
Drives: 2008 Saab 9-3 Combi
You think i can cook it the day before and if it stinks fire up another meal but if it's good can i keep it warm or re-warm it wrapped?
      09-12-2022, 01:05 PM   #24
Alfisti
Originally Posted by Caravaggio View Post
LOL
That is funny.
Brisket is usually about $20 a kilo, so in the region of $50 lb....... so to find it at about $20 lb..... i had to get some.
      09-12-2022, 01:20 PM   #25
aktif8
Drives: 24 Pure Blue M4 Vert
You can keep it wrapped in butcher paper and in the oven at low temp for a good 6-8 hours. You can keep it in the butcher paper then wrapped in towels in a cooler, immediately after cooking, and it'll stay warm for a few hours.
JMcLellan3010.00
      09-12-2022, 02:20 PM   #26
Tommy-G
Tommy-G's Avatar
4712
Drives: 2015 435 Vert Alpine White
I have smoked a lot of meat but NEVER did a brisket b/c I'm scared
vreihen1623703.00
      09-12-2022, 02:27 PM   #27
Isn't brisket what they make into corned beef? That would be my suggestion, but it doesn't get you firing up a grill.
      09-12-2022, 02:53 PM   #28
Alfisti
Saving for posterity.
vreihen1623703.00
Tommy-G4712.00
JMcLellan3010.00
BIGW0RM4450.00
Bingham280.00
      09-12-2022, 04:49 PM   #29
Chick Webb
Drives: '10 E92, '17 540i, '21 X6 M50i
This is no time for an experiment. Think of the long-term trauma your son will experience when 1) his 11th b-day turns into a complete CF, and 2) he sees what your wife does to you afterwards.
vreihen1623703.00
      09-12-2022, 05:04 PM   #30
dreamingat30fps
Drives: Miata, ES350, Model 3, F350
Not as good but yes. When I have cooked a whole brisket we typically have left overs for weeks. You can make burnt ends. I also like "reheating" the flat by cooking strips on a pan. It crisps them up and I think it comes out pretty good. Will it be as juicy and tender no, but since you have never cooked one it probably won't be that juicy and tender anyways.
As someone else said you can also cook it in the oven where it's easier to control.
      09-12-2022, 07:33 PM   #31
gary_william
Drives: 2013 128i
After about 4 hours in the smoker, pull it and set it in the oven to finish. Smoke can only penetrate so deep, so the rest of the time on the grill is not going to add benefit.
Alfisti7018.00
      09-13-2022, 01:55 PM   #32
billnchristy
Drives: 2022 M440xi GC
You don't have to cook the whole thing ya know.
I did a 15lb wagyu brisket on NYE and it was the first time I did the whole thing and in a smoker. I generally actually use charcoal and have done smaller briskets this way. The oven is fine too, especially if you get a couple good rounds of smoke on it.
When I do pork and brisket I generally "cheat" and sous vide the boy for 24-36hr at 130 or so and then you only need a few hours on the grill to get the smoke and bark you need.
UncleWede18691.00
      09-13-2022, 03:44 PM   #33
OkieSnuffBox
Drives: '13 135i
Yes, but it's totally different. You brine it for 7-10 days then boil it.
      09-13-2022, 03:48 PM   #34
billnchristy
That's a lot of words to say ruin it.
Buug95925569.50
Bingham280.00
Alfisti7018.00
jmack496.00
      09-13-2022, 04:01 PM   #35
Tommysalami
Tommysalami's Avatar
564
Drives: E92 M3
Best recommendation was going to a local bbq place and paying them to cook it.
Brisket is difficult to get right. You don't wanna waste 20 hours and end up with it dry. Not to mention wasting the cost of the brisket itself.
      09-13-2022, 04:13 PM   #36
Lucky John
Out to Lunch
Lucky John's Avatar
Drives: 1965 Land Rover Series 2A
Can you say 1-800-PIZZA EMERGENCY?
      09-13-2022, 04:53 PM   #37
AWD Addict
Chief Executive
AWD Addict's Avatar
407
Drives: 2008 335xi 6spd Coupe
2008 335xi  [0.00]
Buy a smoker, and do it right. I doubt that will even fit on your grill with indirect cooking.
Medium rare, that thing's going to be bootleather.
Otherwise, rub it, throw it in the oven with a drip pan underneath, and cook it for ~20hrs at 250*F. It won't have that great bbq pit smoke flavor, but it'll be tender and delicious, and great for slicing onto sandwiches.
All that, and without the trouble of maintaining the pit temp all day.
Todd0131371.50
      09-13-2022, 06:33 PM   #38
paquet
Drives: 2019 540i M Sport etc
OP: Memphis BBQ has multiple locations around Toronto...
      09-30-2022, 12:04 PM   #39
Alfisti
2kg of the 8kg been going for 5 hrs so far, grill at 225 with a brick between the meat and the smoker burner. I have spritz with apple cider and water once.
I smell delicious I might add.
kscarrol10013.50
      09-30-2022, 12:24 PM   #40
TheWatchGuy
TheWatchGuy's Avatar
3970
Drives: Ford, Genesis, Kia
my general guesstimation for brisket cook time is 1hr per lb @ ~215. Can speed it up by wrapping after the stall ( it will get to 150-160 degrees or so and temp will kind of stop rising for a while).
Ive never done one on a gas grill, usually use my smoker, but i have had to finish them a few times in the oven. Really no difference between the smoker and the oven outside of the smoke. In the case you dont have a smoker, id probably do the first few hours on the grill to get the smoke, then move to the oven for the rest of it.
Pull from heat at 200ish, wrap it up in butchers paper and a towel and stick in a cooler to rest. Rest for at least an hour, but ive kept a brisket resting in a cooler for several hours before and usually time my cook to be done a couple hours ahead of when i want to eat it. If you finish too early, spritz it with some apple juice and bbq sauce mixture, wrap it up, and stick in the oven at 200 till its hot enough for you. keeps it from drying out.
In my experience, its really hard to screw up brisket if you cook it low and slow. The people that tend to screw them up go too hot trying to speed up the process.
I'll be doing a 20ish pounder this weekend for the games on Sunday. Will be starting my cook early morning saturday to be ready by 11am Sunday.
@drunkcowatches on ig
Am I a watch guy, or do i watch guys?
Alfisti7018.00
      09-30-2022, 01:19 PM   #41
I did a small 2lbs brisket last week in my slow cooker. I seared the entire piece on the BBQ then made thin slices and added watered down BBQ sauce. Cooked for about eight hours.
https://x3.xbimmers.com/forums/showp...postcount=6882
      09-30-2022, 04:14 PM   #42
Alfisti
So I had it on the grill for 4 hrs, around 220 degrees. Tried to keep it moist. Wrapped it and put it in oven for another 3 hours at 215. That should be plenty of time, it's about 5 lbs.
Took out for a sample, flavour is really good, used pepper, salt, mustard rub, apple wood chip for smoke and apple cider mixed with water as a spritz. But there's no black crust, it's kinda bleh and the texture is edible but "tough". I say tough, not boot leather but not soft by any means.
So have I over cooked it or hit the stall or what? Bit lost so threw it back in hoping for the best. The narrower parts are better texture (softer) than the thicker parts which to me suggests it is not yet ready?????
      09-30-2022, 04:23 PM   #43
dreamingat30fps
What was the internal temperature? Since you say it's now 5lbs I'm assuming you cut it? Is it the point or the flat?
      09-30-2022, 04:29 PM   #44
Alfisti
I may have forgotten to check internal temp but it was not hot to touch. I cut off some from the flatter section.
