BIMMERPOST Universal Forums General BMW News and Cars Discussion Best Explanation for BMW Break-In Service I've Seen
      10-25-2022, 03:37 PM   #23
AHall
Drives: 1993 Nissan 240sx
Good video, should have gone into the programming process to remove run in service.
      10-25-2022, 04:05 PM   #24
MrOhnoez
Drives: '21 GLI, '79 beetle, '99 M3
I know before the break in on my M2C, it was so difficult to shift smoothly perhaps attributed to the diff fluid, it literally looked like sandy oil coming out. Once it was done, it shifted like butter.
      10-25-2022, 04:10 PM   #25
Habber
Habber's Avatar
Drives: BMW M3 2024 Brooklyn Grey SOLD
  [9.87]
I was waiting for the million dollar confirmation that the break in maintenance does not open up performance rather than simply allow the car to perform at it's designed performance.
      10-25-2022, 04:37 PM   #26
nazali
nazali's Avatar
Drives: 230 2020 vert F23
Even when not recommended yes I did a break-in
Originally Posted by nioh_lbbm2 View Post
I've been saying this on this forum for years. Break in is needed 100%
MomoM31049.50
      10-25-2022, 05:05 PM   #27
Bimmerfun82
Bimmerfun82's Avatar
9972
Drives: anything German
25 Porsche Boxster ...  [10.00]
24 BMW iXM60  [9.17]
24 BMW X7  [9.00]
I couldn't get an appointment for 3 weeks at my dealer (booked solid when I took delivery), hit 1200 miles and they said it doesn't matter let her rip. Didn't go bananas until I had the service at 1800 miles, but highly doubt this matters. It's really about letting all the parts congeal and break in together. I will never understand people who don't follow the break-in procedures…
nazali1476.50
      10-25-2022, 06:19 PM   #28
DO444
Drives: 340i
Originally Posted by bangerman15 View Post
Good video.. In the g8x m3/4 Facebook group some of those guys ignore this and rip their cars at around a few hundred mile break in. They were also trolling others for following the recommended break in from BMW M division which, to me, sounds ridiculous not to follow the engineers lol.
Well, that’s pretty much the “tide pod challenge” crew.
If they can get anyone gullible to follow their horrible advice they laugh, dance and drink to the devastation.
You gotta know who you are watching.
Amazes me how many people are unfamiliar with the concept of schadenfreude.
      10-25-2022, 06:44 PM   #29
Remonster
Drives: E90 M3
It's crazy to think these people believe BMW would pay for all these free break-in services around the world if they were unimportant.
      10-25-2022, 06:46 PM   #30
DarkNight707
DarkNight707's Avatar
Drives: BMW G87 (2024),BMW E82(2009)-s
Great info… Thanks for sharing!
      10-25-2022, 06:59 PM   #31
Djhawkg79
Drives: 2022 BMW X5 M50i
Yes. Only 'full' M require the 1200 run in service. Not sure of M50i. The owners manual will tell you.
2022 M50i owner here..... vehicle DID NOT request a oil change until somewhere around 9000 miles.
      10-25-2022, 07:36 PM   #32
nioh_lbbm2
nioh_lbbm2's Avatar
1725
Drives: M2
there are idiots who also believe the earth is flat. there's just nothing you can do to educate ignorant people
      10-25-2022, 08:06 PM   #33
BobsM3Coupe
BobsM3Coupe's Avatar
Drives: X5MC
Originally Posted by Lloydy1980 View Post
If you ran fully synthetic from the get go you'd end up with an engine that won't bed in properly resulting in poor piston ring sealing and increased blow by resulting in oil burn and power losses.
This is hogwash. Many vehicles come from the factory with full synthetic oil. Corvettes, M-B, CVO Harley-Davidsons and others. They will just take a little bit longer to break in.
chris7197655.50
      10-25-2022, 08:23 PM   #34
MarcusM117
Drives: '23 BMW M3 Comp xDrive
Originally Posted by bcjbmwm3 View Post
Anyone had issues getting the service done on their g80. Dealer says that diff fluid is not available and don't have an eta. BMW is saying there is a global shortage.
Hearing the same. I assume there isn't an aftermarket diff fluid that they will substitute?
bcjbmwm3340.00
      10-25-2022, 09:00 PM   #35
BzsBimmer
BzsBimmer's Avatar
3462
Drives: '23 G80 FO M3 & '23 G05 X5 M50
And there are those idiots that think the earth is round…nothing you can do to educate sheep people.
      10-25-2022, 09:08 PM   #36
suitedcboy
Cattlecar
114
Drives: 16 X5 50i MSport, 21 M50i DHP
There shouldn't be any rough parts in an M Engine, these are ultra precision made pieces of equipment, the purpose of a running in oil is that it is mineral based with zero additives, it is these additives (found in semi synthetic and fully synthetic oils) that are designed to prevent wear which you don't want in a running in (mineral) oil as this prevents the engine from bedding in properly. If you ran fully synthetic from the get go you'd end up with an engine that won't bed in properly resulting in poor piston ring sealing and increased blow by resulting in oil burn and power losses.
There is no normal oil made that is so slick it stops modern ring sealing. The break-in oils in the past, and still today for engine builders of flat tappet V8s, is actually extra additives to stop cam lobe and tappet scuffing. In years past piston to wall clearances were tighter but vast improvements in piston technology and manufacturing have eliminated the need for tight initial fit and the risks of piton skirt scuff and failure. There were loads of reasons 50 years ago for break-in oil and brea-in drains of fluids. One of the biggies is that the engine did not have a determined vehicle when it was filled with oil in times past and break-in service was the chance to get the right viscosity in it for the climate (and years before, for the season when oils ere different for cold and warm ambient temps). The S motors have tight running clearances for crankshaft mains and rod bearings and BMW likely does use an enhanced additive package and an altered viscosity in these engines for initial starting and the multiple starts before it gets to dealer. It is never bad idea to do early drains, even if the ONLY thing it fixes is your peace of mind, as any metal or other debris can get out sooner. Magnets in drain plugs or transmission pans can be cleaned if accessed and that is also never a bad idea so that magnet can hold more as they lose hold power when there is accumulation. I worked for a car manufacturer (and before that, dealers) and did a few port visits where vehicles came off the ships. Your vehicle has been substantially broken in before it ever gets to a dealer. Most vehicles gets loaded and unloaded between many transporters before it gets to you. End of line to factory parking, parking to truck if the train line isn't on-site (not sure about which BMW plants have resident rail lines), truck to overseas shipping, offload from ship to port parking, port parking to port inspection and processing, processing back to outbound lot, lot to truck or train depending on the port and final destination, if by train then there is train offload to lot and then loading for truck and then finally it is at dealer. Not all those different handlers will be kind to the vehicles. The period between starts will be hours to weeks. The guys that off load ships often run into boat from lot shuttle tram and race to see who gets down ramp first. You most certainly do not get to pop the cherry on that ride when it gets to you, you are getting sloppy seconds.
Ilyam5947.00
      10-25-2022, 10:48 PM   #37
phantom7835
Professional Nostalgist
phantom7835's Avatar
1010
Drives: 20 M2C, 92 Miata
Has been common knowledge for years now since they implemented it, not sure what the shock is. It's why you always make sure the break-in service was done on a used vehicle
2020 M2 Competition, Long Beach Blue, Exec, 6 Speed
2005 M3 Coupe, SMG, eventual S62 swap candidate
2013 X1 x28i, Valencia Orange, Premium, Cold Weather - N20 exploded
2002 325i/5, Tiag - sold
1998 M3/4/5, Cosmo - scrapped
1992 Miata, Brilliant Black, STS - on the island of misfit toys
      10-25-2022, 11:45 PM   #38
jkoral
Drives: 2017 M2 LBB 6MT
Originally Posted by unfoundnemo View Post
Correct... only M cars that require it.
BMW used to require 1200-mile break-in service for ALL cars, I definitely had it done for my 1996 E36/5 per the manual (oil and diff change). But once they began paying for scheduled maintenance, the 1200-mile break-in service was done away with except for M cars.
(Coincidentally around the same time the OCI increased to 15K and diff and manual tranny fluids magically became "lifetime fill" on non-M cars).
      10-26-2022, 12:14 AM   #39
backslashv
backslashv's Avatar
116
Drives: 2022 BMW M3 Competition
free ? Ain't nothing free. You've already paid for it with the car.
      10-26-2022, 12:18 AM   #40
ST3
ST3's Avatar
363
Drives: F90 M5
Which is why I cringe to think about buying a used M car. I knew who the owner was of my first M car and my current F90 was bought new…gonna hang on to it for a while and keep doing full maintenance per BMW. 4yrs and counting…
      10-26-2022, 12:58 AM   #41
TractionControlDelete
TractionControlDelete's Avatar
Drives: F82-E92 M3-E46 M3-E30-S1K-330i
2004 X5  [9.00]
2006 325i  [9.67]
2021 S1000RR  [9.67]
2006 330i  [8.00]
1986 325e  [9.67]
2005 M3  [7.67]
2009 M3  [8.70]
2018 M4  [10.00]
Motorrad division does the same thing for the bikes.
DSC, you say? Never heard of it
https://youtube.com/@tractioncontroldelete
      10-26-2022, 02:24 AM   #42
DO444
Drives: 340i
Would love to hear more about this…
      10-26-2022, 02:27 AM   #43
oskariker
Drives: BMW X1
Originally Posted by HotRodM4 View Post
Sounds like BMW uses thin oil for the break-in 1200 mile period for the components to set properly and clean any metal shavings. Essentially get it ready for normal/thicker oil.
Great video, really enjoyed it and I think it's something new M owners should watch before they make a mistake with their new cars..
      10-26-2022, 03:05 AM   #44
Efthreeoh
Drives: The E90 + Z4 Coupe & Z3 R'ster
M is for Marketing. The more you can change oils the more special your M car is.
chris7197655.50
F32Fleet3993.00
