11-30-2023, 07:18 AM | #23 | |
I Shoot People For Money
1264
Rep 2,167
Drives: 2023 Portimao MSport X1
2008 335i Alpine White Coupe -sold-
2011 335i Alpine White Sedan PPK -sold- 2020 430i Estoril Coupe MSport -returned- 2023 X1 Portimao, Msport, Premium 2003 330i Imola Red ZHP 6 Speed |
evad3.00 SeaSkiAndMe29.50 |
11-30-2023, 10:22 AM | #24 |
Rep 582
Agreed, I always set up my car system with a reasonable forward fade and both bass and treble nudged up. At the end of the day we all have different hearing so playing with the settings to suit you and your music preference is advised. I think the HK system is 3/5, but is way better than the awful basic system and therefor worth £600. I do think there should be a better option in the £1500 range though.
11-30-2023, 12:21 PM | #25 | |
world's slowest BMW driver
1569
Rep 1,001
Drives: U11, G60, W211, AZ20
https://music.youtube.com/watch?v=pS...AQB0Exqq9zN1cM https://open.spotify.com/track/6YzWc...3e631f680b4d0e |
11-30-2023, 05:16 PM | #26 |
Rep 2,025
I think the X1 HK is pretty good but certainly not outstanding better than a 2/5 I think a 3.5/5 for me. Each to their own it sounds crisp and better the higher it goes it does seem to have loosened up a bit. Adding more bass is definitely the way to go for me it doesn’t need any more treble it would me tinnitus.
The X3 setup is very similar needs to be turned up to high for me before it really gets going and it should be better but as stated above the standard setup is very poor so if you like music and like a more premium sound it’s a no brainer albeit not cheap. |
11-30-2023, 10:23 PM | #27 |
Rep 197
Sadly the X1 I'm getting has the base audio but everything else we wanted .... So we took it.
Probably 2 weeks out. I listen to a lot of music and hearing about how lousy the base unit is has me kinda nervous. I'd thought the system in our first Gen X1 was a base system and sounded pretty good. But looking at it tonight I realize it has tweeters in the door pillars and is probably much better than the New X1. Anyone have any ideas about what I can do to fix it? Seems like there are some door kits but it's impossible to evaluate them or find any reviews |
12-01-2023, 09:35 AM | #28 | |
Rep 118
12-01-2023, 12:32 PM | #29 | |
Rep 197
With the lack of tweeters and maybe the dash speakers I'm pretty sure it'll be making me wish for better. Back in the day I installed some pretty nice systems in my cars myself. I didn't think that with everything as integrated as it is today I'd be able to do more than me speakers. But with the absence of mounts in places, combined with the lack of cabling to get the signal to new speakers I'm wondering if I messed up. I had thought throwing 1500 into modifying the base system would let me make it better than the HK. Now I'm pretty sure that's not going to be possible. There's a real lack of options and information on this new X1 As an aside, I have a great system at home (not expensive but amazing none the less) and I really can't tell the difference between FLAC recordings and hi bit rate mp3s. If the recording is good, the music sounds great to me |
12-02-2023, 04:22 PM | #30 | |
Rep 99
X1 base model stereo - meh
If I crank the volume too high, a lot of distortion on the speakers. As others have noted, only a very basic bass and treble slider function, no true equalizer. I've looked at aftermarket products already, but from what I can tell, only replacement subwoofers and a new amp are what I can install? Oof, this is a problem I have to live with, I guess, until more aftermarket products become available. And I agree with others that the cabin is pretty quiet, so at least the droopy speakers aren't fighting against road noise. I was toying with the idea of keeping some Bose bluetooth speakers in the car at least for jamming tunes on longer drives. I'm visiting my dealer in a few days for some services I'm having done, and my salesperson offered to look at it for me, but after pretty extensive research on my part, I think it's a lost cause. Last edited by SeaSkiAndMe; 12-02-2023 at 04:44 PM.. |
12-02-2023, 04:48 PM | #31 | |
1569
Rep 1,001
I play music files(or streaming music) that sound good in the HK system. I know what its limitations are and adjust my taste accordingly. It's the same way I deal with the quirky DCT transmission. Many people find it lagging and slow. However, I've learned to drive based on how I know it's going to behave. Is it the ideal solution? maybe not..... but I've been a cat owner all my life, so it's probably easier to adapt to the cat's wishes and enjoy their company. (otherwise, I would have been a dog owners because most dogs can be easily trained) |
12-02-2023, 05:12 PM | #32 |
Rep 99
SpaceSilver.X1
Yes, not going to dump the vehicle bc I'm disappointed in the stereo. Background: I ended up buying this X1 to replace a Buick SUV with three cracked engine components from Aug-Nov this year, so all in all, I'd rather have a solid drive train! I do listen to a terrific jazz radio station, so newer recordings of certain types of instruments I notice a difference from my previous vehicle, which had a pretty decent Bose sound system. |
12-03-2023, 06:40 PM | #33 |
Rep 99
I was thinking about all the comments on this thread when I took the car out this evening. I had messed around w the bass and treble but this time nudged the fade up front a bit more and I preferred that. Thanks for sharing that idea!
12-03-2023, 09:06 PM | #34 |
Rep 197
I've yet to hear a new X1 radio but I've read a few comments suggesting to turn off the spatial processing.
12-03-2023, 09:18 PM | #35 | |
1569
Rep 1,001
I used CarPlay and for some strange reason, the music sounds noticeably better via YouTube Music. When I play the same exact piece of music via Apple Music, it seems flatter somehow. Of course, the best sound quality is achieved when I play lossless music using USB sticks. |
12-05-2023, 09:41 PM | #36 |
Rep 99
After further review, someone helped me determine it's not just meh speakers; the stock amp is too low wattage to deliver much without distortion at higher volume. A specific aftermarket (not OEM) amp and speaker package was recommended to me yesterday by someone knowledgeable about the model. However the package for my model isn't available yet. It will be pricey (>$3k) so just as well - I'll treat myself for my May birthday
After thinking about it, I've put aftermarket sound systems (or at least, new speakers) in quite a few of my vehicles over the years, so I'm at peace with it. |
12-06-2023, 09:10 AM | #37 |
Rep 18
FYI the 674 HK system found in the X1 and X4 is based off of just a RAM module. Needless to say it will be underpowered, just like the current 676 hifi cars.
There is no separate "booster" (2ch amp for the under seat woofers) as found in the 688 HK systems known from the G20 3-Series, G05 X5 or even G29 Z4. |
U11sirgawain103.00 SeaSkiAndMe29.50 |
12-06-2023, 11:20 AM | #38 |
Rep 197
I'm not looking for ground thumping volume, just fidelity. A while ago I switched out my old Sony ESS class A integrated amp, for a tiny new Class D amp.
At similar volumes driving the same speakers, the Sony Drew 80 Watts while the SMSL was drawing about 4 Watts. I was really surprised. I'm certain that the amps in new cars are certainly Class D. What I'm getting at, is that it really takes very little power to drive efficient speakers at reasonable volumes. |
12-06-2023, 03:02 PM | #39 | |
1569
Rep 1,001
12-07-2023, 03:16 PM | #41 |
1569
Rep 1,001
found a thread about a BMW M2 owner using the same Morel speakers and more.
https://f87.bimmerpost.com/forums/sh....php?t=2034121 although...if I were to do it, I probably would go with a kit like this one. (which I was planning to do on my X1, until I decided to trade my 2nd car for a 530i, so I'm saving the money for that one) https://www.bimmer-tech.net/speakers...lifier-for-bmw Last edited by SpaceSilver.X1; 12-07-2023 at 03:25 PM.. |
12-08-2023, 06:01 PM | #42 |
Rep 99
I had been looking at that kit, also! But, let's just say the very informed individual who recommended a kit to me - it was a different brand that now I cannot recall the brand name.
IF that brand doesn't come up with an amp & speaker kit to fit my car by the Spring, I will likely go with the Bimmertech one you linked to. |
12-08-2023, 09:17 PM | #43 | |
1569
Rep 1,001
$3700 on Amazon https://www.amazon.com/Sennheiser-Op...dp/B0CFZKLNZ1/ |
U11sirgawain103.00 |
12-09-2023, 05:06 AM | #44 |
Rep 582
Agreed, but i guess it depends how much time you spend in your car. If i was doing 30,000 miles a year instead of 7000 then i may be willng to spend some serious money on my ICE due to the hours spent listening to music on the move. However as it is I would rather put more money into some NAIM separates for the home 🤓
