BMW X1 and X2 forums (U11/U10) General BMW X1 and X2 Discussion (U11 / U10) (2023+) Anyone actually put their x1 into 'deep sleep mode'
      06-11-2023, 06:48 PM   #23
WA
G42 B58 C56
WA's Avatar
Drives: 2024 M240i
I work from home and have a second car, so neither gets driven a lot. So I’ve started regularly using Deep Sleep (with alarm) on the X1 when parked at home to reduce battery drain.
So far it has behaved as expected, in that you need to unlock it with the hatch button because the other sensors are off. But no issues, normal behavior after that.
Update: I’ve noticed that when in Deep Sleep, it will actually unlock from the drivers door handle sensor as well. (Not having to use the hatch as doc says.) With maybe an additional fraction of a second delay, due to the sensors to detect my key fob perhaps waking up? Nice to not have to wake up the car with the hatch button when I don’t need to open it.
      04-19-2024, 04:16 PM   #24
hawaiiguy
Drives: '23 X1 MSport
Originally Posted by hawaiiguy View Post
After exactly two months of having my x1, I finally went in the system settings to see how long it can hibernate without having a dead battery:
As I get close to putting my car in deep sleep mode due to my cruise to another part of the world, I just went into the deep sleep mode to practice.
I did the OTA update to 11/2023.73 earlier this month.
Now on the screen the time has been reduced to 8 weeks with the security alarm on...
      04-19-2024, 04:54 PM   #25
Puffinrock
Drives: X1 30e MSport
You could also get a solar battery trickle charger if your just worried about the battery.
      04-19-2024, 06:33 PM   #26
hawaiiguy
I bought a Battery Tender weeks after receiving my car last April to go along with my power bank that I've had for a few years.
The point is that since my post of 6.11.2023 when it was showing up to 12 weeks, it has decreased after the software update to now say up to 8 weeks (with just the anti theft alarm activated).
      04-20-2024, 10:30 AM   #27
Zach12
Drives: BMW X1 30e xLine
Interesting, I’m not even seeing a “deep sleep” mode option? Can anyone in the U.K. confirm, or is it a non-phev config?
      04-21-2024, 08:05 PM   #28
Spdrush
Drives: 2024 X1 M35i
Went on vaca for 2 weeks and used deep sleep. It worked as expected.
Yes my M35i is electronically complex but I think this battery is very low capacity.
There is another thread on this site about the battery and charging. It is a calcium lithium battery and requires a high charging voltage to properly charge.
