05-31-2023, 08:56 PM | #23 | |
Not great. Not terrible
7453
Rep 2,700
I'm likely sticking with OEM. The PS4S looks better on 11" wheel than the Pzeros.
Current: 2024 BMW X3 M40i.
Squidget3538.00 |
05-31-2023, 09:45 PM | #24 |
Rep 1,846
The Porsche is a rear engine car with a 37/63 weight distribution. This is like comparing apples to bowling balls. Jesus...
05-31-2023, 11:23 PM | #25 | |
Rep 63
The engine at the rear puts a lot of weight on the rear tires increasing their grip (F = u N as a crude friction model) hence why they have a lot of static understeer. It reduces the chance of losing the back because when you lose it on a rear or mid engine car, it's really hard to catch the spin (due to the pendulum effect and leverage it entails). And with the historical "widow maker" reputation the car garnered, Porsche saw the liability angle and acted accordingly. All car manufacturers setup their car for understeer for safety/liability reasons but for mid engine and, god forbid, rear engine cars, it's an even bigger issue. Anyway, applying that setup on a car like the G87 M2, you will get the benefit of increased rear grip with less static understeer (by static, I mean at rest) due to the more balanced weight distribution. The Camaro ZL1 1LE kind of did it with their 325 rear and 305 front. |
06-02-2023, 04:23 AM | #26 |
Rep 284
I’m running a 285/30r20 up front and a 305/30r20 rear all on 20x10.5 wheels. Added a 10 mm rear spacer. No rubbing, drives great. It’s def a bit more sensitive to steering inputs, but on a warm day it’s very planted and precise. I do have a Nitto NT05 on the rear ……
JustinHEMI7453.00 lithe31.00 |
06-03-2023, 08:00 AM | #27 | |
Rep 636
Assume you're trying to get more launch from the rears rubber? The difference would be so minimal and potential ratio issues would probably make it more trouble then it's worth. Simply switching to stickier rubber on factory sizes would be the best bang for buck. |
06-04-2023, 12:02 AM | #28 | |
7453
Rep 2,700
I DID change rim sizes hence the question. I'm at 19x10 front and 20x11 rear. The fronts are fine from a "stretch" perspective, but the stock Pzeros look like ass on the 11" rears. If I bump the fronts to 285/35/19 and the rear to 295/30/20, they're both increasing the same percentage according to the screenshots I posted early in the thread. The speedo is pretty close too, reading about 1mph low according to those calculators. I am really only trying to solve a cosmetic issue, but trying to keep the balance of the car. I think these sizes on these wheels will be fine based on all the calculators. Now, I've also read that the PS4S in OEM size may not be stretched as bad as the Pzeros on an 11" wheel, but I don't know for sure. Here's the rear stretched, Here's the front. Baby Gem seems to think keeping the OEM front size and going to the 295 in the rear would be OK too. Probably would be.
MASHCT698.00 |
06-04-2023, 05:44 PM | #29 |
Rep 265
Keeping the OEM front with wider rear would have a tendency to increase understear. On a rear drive car I don’t see that as a huge issue and if you know it going in then you know what to expect. I’d probably go up one size on the front.
From an electronics/traction control perspective you want to keep front and rear rolling diameter difference about the same as stock. Diameter difference is especially a concern on xdrive cars so watch who you get advice from and what their perspective is.
2023 M2
2014 Triumph Trophy |
06-04-2023, 05:47 PM | #30 | |
7453
Rep 2,700
PS4S are available in those sized, though not BMW* variety. I doubt I'd ever notice that difference.
06-05-2023, 09:32 AM | #31 | |
Rep 636
https://youtu.be/COA630Juf_U |
hooked191.00 |
06-05-2023, 09:39 AM | #32 |
this is the way
18453
Rep 8,588
JustinHEMI7453.00 |
06-05-2023, 09:40 AM | #33 | |
7453
Rep 2,700
No I know they're different, I'm saying I doubt *I* could feel the difference. That being said, I see Porsche also has a compound. I wonder how it compares to BMW.
06-05-2023, 09:44 AM | #34 |
Rep 636
I wouldn't be surprised if the Porsche compound is closer to the BMW but that's pure speculation. My 992 runs Bridgestones and they're actually fantastic, but it is a 4S so it has ridiculous grip in all conditions.
06-15-2023, 11:25 AM | #35 |
Rep 105
06-15-2023, 01:00 PM | #36 |
Rep 52
06-15-2023, 02:09 PM | #37 |
Rep 3,054
Drives: A Family Sedan
07-14-2023, 04:04 AM | #38 |
Rep 1,477
Drives: BMW M2
Sorry to chime in on this thread now that your car is injured, but I'm having the same dilemma.
I would like to put on the 10.5"/11" Edelweiss rims, but I would also like to keep the OEM tire sizes, and I'm afraid that the rear 285's will be too stretched out on the 11", compromising both aesthetics and performance. I will see what tires my car will come with, it seems that Michelin tires are a bit wider, although Michelin recommends 9.5-10.5 as the rim width range for 285/30. 285/35-19 and 295/30-20 would be the best route for 10.5/11 rims, but I don't want to put more rubber on the ground and the 285/35 seems too "fat." |
