08-08-2023, 08:19 PM | #23 |
![]() 76
Rep 49
If they keep putting the same parts in and that does not help it leads me to believe the problem is something else. Maybe? Anyway good luck getting some resolution!
08-09-2023, 03:34 PM | #25 |
![]() ![]() 103
Rep 159
Complaining every day is the least to be done in your situation
My comment (and Albert) just applies to the advanced BMW diagnosis consisting of changing same parts over and over!
Ex320i, ex325ix, ex850i, ex530dTouring
Mini Mize179.50 |
08-09-2023, 04:07 PM | #26 |
![]() 152
Rep 207
I work in the controls and automation department for an engineering company and we have name for techs who simply keep changing parts until something works again: 'swapnostics'.
I'm an old fart and originate from the days of properly tracing and diagnosing faults, and repairing circuit boards and devices at component level and yes, yes, I know with a lot of equipment nowadays this is no longer possible. But still, my younger colleagues do not seem to have the ability to think critically and actually diagnose problems and these are people who on paper at least, are far better qualified than myself. I'm guessing the techs at BMW use the 'swapnostics' principle too... |
U11sirgawain103.00 |
08-09-2023, 04:15 PM | #27 |
![]() ![]() 103
Rep 159
Swapnostics do work, and with modern equipment, some are designed with swapnostic as main troubleshooting procedure.
But changing once and again same items.....is insane, unless you don't trust the spare modules being used.
08-09-2023, 04:31 PM | #28 |
![]() 152
Rep 207
I agree with you to a point. Yes, swapnostics does have a place with modern tech; however, the downside of relying too much on swapnostics is that having a guess at what might be wrong, and plugging in a perfectly healthy, brand new part/module/circuit board can lead to that part being damaged by the part/module/circuit board that is actually faulty - so then you not only have the original fault to still deal with, but you also have a useless brand new part on your hands that may be very expensive.
08-09-2023, 07:23 PM | #30 |
![]() ![]() 1930
Rep 5,115
This is def weird...some similarities here when compared to my wife's issue(s) recently. Solution was threefold:
1. New battery 2. New BDC 3. New software level not yet released to the GP (03.2023.75)
'11 Z4 30i (retired);'11 X3 28i (retired); '15 M235i Stage 1 Dinan (recalled & crushed); '16 M235i Stage 3 Dinan (retired); '15 X3 28i (retired); '14 328i (retired), 2019 X3M40i (retired); Loaded '18 X1 (retired); Loaded '20 X3MC DG, Black/Tan Merino (retired); Loaded '23 X1 Cape York green and Red/Black interior; '23 Audi A4 Allroad Progressiv
08-09-2023, 11:22 PM | #31 | |
slowest X1 driver ever
529
Rep 955
Drives: '23 X1 M Sport, '24 530i(soon)
picked up the X1 this afternoon... everything works fine... but there seems to be a common theme here. the last time they replaced it, the low windshield washer fluid warning came on and would not go away. today, the "window open" warning came on as soon a few minutes after I got home... several hours later, it still showing "window open" on the BMW app. I went to the garage and all windows and sunroof were tightly closed... but just to be sure, I opened/closed each one a couple of times. the warning message on the app continues to show window open(front passenger side).... |
08-10-2023, 05:06 AM | #32 | |
![]() 29
Rep 92
then after a couple of weeks it sorted itself out ![]() |
08-10-2023, 06:21 AM | #33 |
![]() ![]() ![]() ![]() 165
Rep 459
I have a UK 2 Series Active Tourer (2022) version U06 purchased new March 2022 after having a 2018 X1 (F48) from 2/2018. The 2 A/T U06 is basically pretty much the same as the new U11 X1.
Almost from the outset I was receiving spurious on-screen messages telling me such faults as Cornering Light Failure, Braking issues etc and that I should get the car to my nearest dealership. I did so, but they were unable to resolve the problems. I was also receiving numerous fault/error notifications via the MyBMW App on my iPhone. A short time afterwards the screen went into the same 'mode' as described in these posts from USA owners. I called BMW UK Assistance and when the technician arrived next day he immediately said the head unit had failed. Car went into dealership and I had a courtesy cay for around a month waiting for the new unit to arrive - apparently at that time there weren't even any new head units in Germany! When it did arrive, late 10/22 it took the dealer a couple of hours to fit the replacement. I asked what the unit factory cost was and he said it was around UK Stg£2300 (equivalent around US $2800). Has been OK since except one occasion when the SatNav wouldn't go beyond the startup screen. Called BMW UK Assistance again and was contacted by their technician who was able to reset and fix the issue online direct to the car from around 160 miles away. Last edited by oakey46; 08-10-2023 at 06:39 AM.. |
08-10-2023, 07:34 AM | #34 |
![]() ![]() ![]() ![]() ![]() 375
Rep 638
08-10-2023, 11:10 AM | #35 |
![]() ![]() 103
Rep 159
[QUOTE=MAPMAN48;30387386]If there are any quality control issues in soldering the chips to the MB or it is subject to large temperature differences then there is a problem.
Makes fully sense. It's not an OR but an AND. Boards/components/soldering should be speced to withstand large temperature differences. If they don't,....BMW has a quality control issue! Large temperature differences should be not a problem to a well speced and built cars, but they are! My son PHEV (Jeep) has connectivity and infotainment issues that he relates to temperature. Cheers
08-10-2023, 11:26 AM | #36 | |
![]() ![]() 126
Rep 288
08-10-2023, 06:53 PM | #37 | |
529
Rep 955
According to my friend who has worked at a Mercedes dealership since 1998, current and future availability of the vital electronic parts are not guaranteed 5 or 7 years down the road. A 30 or even 40-year-old Mercedes can still be easily repaired using new, used or refurbished parts because they contain very few computer-controlled parts. What's even worrying is that he says the infotainment and other computer parts on the current Mercedes require VIN# matching done by Mercedes before and during installation. It means that 10 years from now, if someone needs a replacement part and Mercedes no longer produces it, the owner can't simply go to eBay or a junkyard and buy a random replacement because it will be rejected by the car. That sound very familiar to me... like what Apple has been doing with replacement iPhone parts... but iPhones are only $1000 to $1600 at most and phones are disposable anyway. I assume that BMW, Audi or other manufacturers are going down that road as well. Cars will become nearly obsolete after 7 to 10 years. The owner is expected to buy a new one, instead of trying to repair it. |
08-10-2023, 06:56 PM | #38 | |
529
Rep 955
![]() All of the tools in my tool chest in the garage are non-Metric, except a set of wrenches. My X1 feels as good as new, sort of... it just occurred to me why I'm not mad at BMW or making any real complaints. It is somewhat comforting to know that I'm covered by BMW until 100,000 miles... so I don't really feel the urgency to complain. ![]() Last edited by SpaceSilverX1; 08-10-2023 at 07:10 PM.. |
08-11-2023, 03:11 AM | #39 | |
![]() 29
Rep 92
![]() where things are not related ... ![]() where things are coherent m3 = almost 1000kg water, units are multiples of 10 etc. ![]() |
01-13-2024, 05:05 AM | #40 | |
![]() 0
Rep 5
Dealers still figuring out whats the problem. I think the whole part gonna be replaced. |
10-02-2024, 10:01 AM | #41 |
John27
![]() 63
Rep 155
I went to my X1 this morning and had the same problem as OP. I had two blank screens with the one in the middle of the car just showing BMW in white lettering. Tried all suggestions in this thread for hard reset - none worked. Not only were screens not working, nor were any buttons on the steering wheel or head-up display. Only controls on the doors, wipers and lights working as well as engine and transmission, of course. BMW assistance said car is not safe to drive.
Car currently in the dealership and I am awaiting their views. BMW assistance said problem is most likely the head unit or wiring loom but dealer has better software to diagnose the issue. Will report back once they have diagnosed the issue in case this affects others on here. |
10-08-2024, 08:04 AM | #42 |
John27
![]() 63
Rep 155
I said I would report back on my problem in my post above.
By the time the dealer got round to looking at the car, the screens and buttons etc were apparently working again. They said the car needed a software update (no update had been requested by the car so this was news to me and I can't help but think this is the excuse they roll out whenever there is no fix). When I went to collect it, found things were still not right. For instance, car wouldn't connect to wifi via my mobile, or indeed, the Android Auto app wasn't working (I suspect there were more problems, but I stopped at that point) and left the car with them. The solution was a complete factory reset. Everything is now working but it has been a pain to set everything up again - it's as though it is a new car. Whether this fixes the original problem, only time will tell but fingers crossed. |
markronnie206.50 |
10-18-2024, 11:33 AM | #43 | |
John27
![]() 63
Rep 155
Given all the grief with the beta testing of ID9 in the UK and the bugs, I am pretty much fed up with this car. My first BMW and so disappointed. Not even had it a year. Already looking for a new car (not interested in EV or PHEV). Had considered an X3 as my next car but worried I might end up with the same issues. Off the top of my head, in consideration are new Audi Q5, Porsche Mecan (basic spec), Lexus NX, and less seriously, but in contention, Mustang GT (V8 - always wanted one but not really practical). Maybe I will feel better in the morning when I have calmed down a bit. |
11-02-2024, 11:40 AM | #44 | |
John27
![]() 63
Rep 155
I was told by the floor service manager that their own car, an iX1, had similar problems but in their case, the car fixed itself after a few days, mine did not. I said it was unacceptable for a car with an OTR price north of £50k to have such problems. Apparently if the car goes wrong again, they will refer me back to sales. I know its too late to reject the car but there is a rule about how many attempts a dealer has to fix a car and they have now had three attempts. If it happens again and they offer me a decent price, I will sell the car. I like the car but this is not acceptable. |
