02-20-2024, 04:59 PM | #23 | |
Rep 2,083
Now if you don't haul any of that and just pickup the odd piece of lumber every few months then yeah, take the time to gently shove it into your minivan or whatever you got or rent a truck from home depot. But buying a minivan instead of a truck to do truck things.... nah. Last edited by dreamingat30fps; 02-20-2024 at 05:06 PM.. |
02-20-2024, 05:15 PM | #24 |
Rep 3,326
Yeah this situation calls for a truck, there's carrying "stuff" and carrying "truck stuff". For home depot runs, there's a reason so many contractors use a minivan but landscapers use a truck right.
dreamingat30fps6071.00 |
02-20-2024, 08:09 PM | #25 |
Rep 11,195
I've had three truck, still own two. My advice is do it right and get a 3/4 ton with a diesel engine. I had a 2004 Dodge Ram and it was amazing. Had it up to 100,000 and the only thing that ever required repair was a steering pump. I have a 2004 Duramax now and it's inferior to the Dodge.
My advice? 3/4 ton Dodge Crew Cab Sport with the Cummins. |
02-20-2024, 08:20 PM | #26 | |
6MT FTMFW
71
Rep 235
Drives: 11 E90 335xi E91 6MT 12 X5 35i
Garage List 2005 330ci Vert ZHP [0.00]
2011 335xi Sedan M- ... [0.00] 2011 328xi Wagon M- ... [0.00] 2012 X5 35i M-Sport [0.00] |
2011 LMB E90 335xi 6MT: Wagner EvoII FMIC, Catless DP, PE Mod, Cobb CP, BMC Filter, ST Coilovers, Strongflex TSB's, Whiteline RSFB Inserts, CDV Delete, Hawk Talon Rotors & PC Pads
2011 SGM E91 328xi 6MT: 3-Stage Intake Manifold, ST coilovers, 335i brake kit, drilled/slotted rotors, CDV Delete, Charcoal Filter Delete |
02-21-2024, 09:51 AM | #29 |
Rep 19,994
02-21-2024, 10:08 AM | #30 | |
Rep 11,195
The Cummins diesel will go down in history as one of the best diesel engines ever built. It's for that reason I'll never get anything but a Dodge. I only have the Duramax currently because my father-in-law bought it new and wasn't driving it anymore. It's the pre-emissions LB7 which is a no-nonsense 6.6L V8. I have close to 200K on her and apart from injectors and glow plugs, it's 100% original. |
02-21-2024, 10:43 AM | #31 |
Rep 384
If you're buying new, the truth is any option from the Big 3 (and Toyota) will be fine. They are all around the same reliability, even RAM. It really comes down to styling preference and dealer incentives.
I have mostly owned Ford trucks, but had an old GMT-800 and a new rental Silverado that was great. Cross shopped Tundras with my current truck. Currently have a 2016 F-150 5.0l nearing 200k miles. Probably will be looking to upgrade to a F-250 7.3 gasser in the near future for the towing and payload increase. Towing with a half ton through the TN/Carolina mountains has been sketchy at times. |
02-21-2024, 10:45 AM | #32 | |
6MT FTMFW
71
Rep 235
P111765.00 |
02-21-2024, 12:50 PM | #33 |
Rep 2,990
What's your budget, use case, and weight you wanna tow. There's a big difference between a "truck for hauling some crap for the yard" and "a truck that's my daily that needs to be luxurious and also tow a 8000lb trailer and haul bricks"
02-21-2024, 01:23 PM | #34 | |
You got my money?
4261
Rep 5,167
Drives: Ice Cream Truck
I do wish it got better MPG though. I cant seem to get past 15MPG on highway in mine.
2025 G82 M2 /// 2025 X5 40i X
02-21-2024, 01:40 PM | #35 | |
Rep 19,994
02-21-2024, 01:45 PM | #36 |
You got my money?
4261
Rep 5,167
Im not going to lie. Thats half the reason we got it. Big enough to hold our shit and get us the hell out of town by any means neccessary. I will run a MF'er over and blast into the desert, hills or forest with ease in that thing.
02-22-2024, 04:38 PM | #40 |
Rep 11,195
3/4 ton or 1 ton trucks hold their value much better than a half ton. I'll never buy a half ton. If you're going to get a truck, do it properly.
02-22-2024, 04:39 PM | #41 | |
Rep 384
If you're towing >6000lb regularly, definitely recommend upping to a 3/4 ton. Despite marketing crap about half tons with 10k tow ratings, the reality is that even max tow/payload spec are usually sub-7k and don't do great in the hills with that much behind them. |
02-26-2024, 03:16 PM | #43 | |
Rep 680
For pickups, the Hemi 5.7L V8 is a solid engine, especially with their version of the ZF8, but they're definitely known for low-mileage lifter failure which can also take out the camshaft. Have seen some teardowns of this. If you're religious about oil changes and avoid long idle periods, it can reduce the issue. The Chevy's are also known for lifter failures due to the variable displacement stuff, but is completely random. Some will go for 200k miles, others fail at 30k. Not sure about the Fords.
2022 G07 X7 Tanzanite Blue / Ivory White | 2022 G05 X5 40i Phytonic Blue / Ivory | 2011 E93 335i Deep Sea Blue / Oyster
2018 Chevy Suburban (ret) | 2012 E70 X5d Deep Sea Blue / Sand Beige (ret) |
