BMW X1 and X2 forums (U11/U10) General BMW X1 and X2 Discussion (U11 / U10) (2023+) does BMW sell just the wiper rubber strips for the X1 wiper blades?
      09-30-2024, 02:21 AM   #23
SnowCover
Drives: '23 330i, '23 X1, '25 X3
Originally Posted by FZI89 View Post
Now to add some confusion 🤣: aren’t they meant to be measured flat/straight? (E.g. pushed down against the window)
yes! of course I pulled out the wiper and pushed the rubber blade flat against the ruler. That's the only way to measure it properly.
I'm very OCD about such things. When I check my tire pressure, I use tire gauges, two electronic and two digital, from 4 different brands to make sure that they have the identical reading.(and check that against whatever the car's own TPMS is showing)
      09-30-2024, 02:25 AM   #24
FZI89
FZI89's Avatar
Austria
753
Drives: BMW iX1, U11
Ah good! From the photo I thought you measured it as it was.
that’s dedication! How long does it take you to measure all four tires? 🤣
      09-30-2024, 02:50 AM   #25
SnowCover
I only need to measure 1 tire with 4 gauges. If they all read 35psi, then I just measure the other 3 tires with any of the gauges. Maybe when my OCD gets worse with age, I'll have to measure each tire with 4 gauges?
      09-30-2024, 02:52 AM   #26
FZI89
FZI89's Avatar
Austria
753
Oh gotcha! At least you know for sure that they’re all equal!
      09-30-2024, 08:34 PM   #27
COOLGREANY
Riding BMWs since 1976
COOLGREANY's Avatar
179
Drives: 24 xDrive28i Space Silver
technically, it's not quite 12 inches.... 30cm is 11.81 inches.
If it's 30 cm don't you mean 11.811 inches?
2024 X1 xDrive28i (Space Silver), 2014 BMW X1 (E84) (sold), 2010 MINI Cooper S Clubman, 2011 BMW R1200GS Motorcycle and various BMW motorcycles since 1976
      09-30-2024, 09:57 PM   #28
SnowCover
11.811023622047 inches
https://www.rapidtables.com/convert/...inch.html?x=30
of course, I will need to get a more accurate ruler, just in case my ruler is off by 1mm or something.
