07-11-2011, 12:19 PM | #23 |
Rep 7,389
Nice.
Yeah, mine's with the 70-200mm f/4L IS plus the 1.4x TC on a 7D.
07-11-2011, 12:21 PM | #24 |
Rep 7,561
So the IS version will work with the 1.4x TC, eh?
07-11-2011, 12:49 PM | #25 |
Rep 7,389
Oh yeah, the IS works great with and without the TC. I depend on the IS relatively often.
Here we are with the TC on the 70-200mm at ISO 6400 (pre dawn) at 1/125 second (slow for 280mm) handheld with the 5D MkII: Very handsome bull elk by dcstep, on Flickr
07-11-2011, 01:40 PM | #26 |
Rep 5,114
07-11-2011, 04:45 PM | #27 |
Rep 24,685
Drives: '04 330i ZHP
Yeah I figured if I'm gonna get the 2x converter for my 70-200 f4 is at home. But it would also be fun to have the 100-400 and be able to make it a 200-800. The 2x converter makes it an f/5.6 when used anyway. I would probably like to upgrade my 70-200 to the 2.8 IS first though. Such a baller lens, despite the weight.
07-11-2011, 05:44 PM | #28 | |
Rep 6,798
07-12-2011, 12:09 AM | #29 |
Rep 24,685
ah, ok. That makes a bit more sense. So I will need to at least swap f/4 for a 2.8 to get the f/5.6 with the 2x.
or i can just keep the f/4 and get the 100-400. thoughts? |
07-12-2011, 12:12 AM | #30 | |
Rep 5,114
the range of the 100-400 is nice to have. although the 70-200 really isn't far off with the 2x. it's really a matter of choice. I just recommend that if you do go for the 2.8 and a 2x, you'll have to stop down a few just to get the outside edges sharper, where the 100-400, the 5.6 is fairly sharp all the way across. which really is a downfall to the TCs. hope that made sense, it seems like i jumped around a bit to me. |
07-12-2011, 12:28 AM | #31 |
Rep 24,685
hahaha, yeah it makes sense. maybe the 2.8 is a better choice though since I could run it on my 40D and use the 1.6x crop to give me some more zoom on it.
Would that work with the 1.4x converter? Does it change the f stops like the 2x? |
07-12-2011, 12:37 AM | #32 | |
Rep 5,114
there is still some quality drop at the edges as a result of it, but not as bad as the 2x. so you might stop down a little just to tidy it up but not as much as you might with the 2x but also remember, a 200mm is still a 200 mm on a crop or a full frame, it's just the image is cropped. It's easy to forget i find. your F stop would be a 4 constant, which isn't bad to play with compared to a 5.6. but the other way to look at it is, even with the furthest reaches of the 100-400, you're still shooting a 5.6, but at least at 100, it's about an f4, and still able to do that full zoom range and still keep great sharpness. the big winner in my eyes though is the ability to shoot between 70-200 at f2.8. anything after that is just bonus that you want to play with. I find you have to work with the 70-200 F4 to get nice bukah, where the 2.8 will do it with almost any picture with minimal effort. I think that's where the money really is in the long run. Unless you get into wildlife. then i'd just say the 100-400, which you could put a 1.4 tc on and run on most cameras. the 100-400 is the cheapest super tele your next option is start buying primes which will get into the several thousand range. So, before buying with passion, assess what your uses for it will be and go by that. If all you're doing is portrait work and never venturing into the woods, forget about the 100-400, it will be useless for you. |
07-12-2011, 09:04 AM | #33 | ||
Rep 6,798
The 100-400mm is sharper at 400mm f/5.6 than the 70-200mm at 400mm with a 2.0x TC. That being said, unless you constantly shooting for wildlife (like Dave), I recommend the 70-200mm since it's much more versatile (especially on a full-frame). You can use it for portraits, etc. The only reason I didn't get the 70-200 f/2.8 IS II is because it's insanely pricey compared to the 70-200 f/4 IS, and has essentially the same sharpness. I also didn't need the extra stop for nearly twice the price and weight. Quote:
By the way, another important thing to note is that a 1.4x TC results in a 25% decrease in AF speed, and a 2.0x TC results in a 50% decrease in AF speed. Usually people don't realize that when buying TCs. Although that's true, you have to have a reference system, and that is the 35mm equivalent focal length. So, a 200mm lens on an APS-C is essentially 320mm equivalent. It's assumed to be cropped.
07-12-2011, 04:31 PM | #34 |
Rep 24,685
ah ok. well I guess my thoughts were with the 100-400 i could still get up to 800 if I wanted to for as little $ needed (with a 2xTC). I honestly don't know when I would shoot that length other than maybe a few sporting events a year. It would be fun to have but yes the 2.8 IS 70-200 would be the more logical choice because I could use it on a regular basis with the lower aperture.
eh, i'll give it some thought when I get back home from Hawaii. Sadly, I really only used my camera one day so far. I am having too much fun enjoying everything rather than shooting everything. Maybe I'll just have to come back again soon to shoot only (without the wife). |
07-12-2011, 05:16 PM | #35 |
Rep 6,798
well, if you decide on the 100-400mm f/4L IS, apparently Canon is shipping me one that I'll be returning to them... so, if you want one, it's yours.
07-12-2011, 05:33 PM | #36 |
Rep 24,685
oh nice, how much?
wait... they make a 100-400 F4 IS? or did you mean the 70-200? |
07-12-2011, 05:51 PM | #37 |
Rep 1,232
North shore does not break too epic in the summer especially Pipe line and Sunset. Try checking around the corners at Velzy or down southside at Haleiwa. Good thing is no traffic during the summer as big winter swells tend to have trafiic backing up for miles.
07-12-2011, 06:09 PM | #38 |
Rep 24,685
yeah already found that out. Pipe was at least breaking closer to shore so that helped but not epic by any means. I just turned in my rental car today so no more trips up
07-12-2011, 06:31 PM | #39 | ||
Rep 24,685
Does that math make sense or am I not multiplying correctly? |
07-12-2011, 07:19 PM | #40 | ||
Rep 6,798
The 70-200 f/2.8 on my 40D gives you 200*1.6 = 320mm equivalent at f/2.8. If you do the 1.4x TC, then on your 40D, you'll have 320*1.4 = 448mm equivalent at f/4. If you use the 2x TC on your 5DM2 with that lens, you'll get 400mm at f/5.6. Is that what you are trying to compare?
07-12-2011, 07:40 PM | #41 | |
Rep 5,114
it's a lot of zoom on a crop body. You will never really need any more then that unless you do 2-3 trecks into the woods a week like Dave does. |
07-12-2011, 08:59 PM | #42 | |
Rep 24,685
07-12-2011, 09:00 PM | #43 |
Rep 24,685
yeah like I said wouldn't need it that long for stuff other than a few trips to the ball park or if I ever get my wish granted of siting on the field at a bears game.
07-12-2011, 09:40 PM | #44 |
Rep 6,798
Badger, I think you have telephoto mixed up with macro, if you're planning on taking pics of your... self.
