08-22-2011, 11:36 PM | #23 | |
Rep 6,798
If you need the 2.8 aperture, go for the 24-70mm, otherwise the 24-105mm might be the better overall choice.
08-22-2011, 11:58 PM | #24 |
Rep 7,561
I have the 24-105 and the IS is very nice to have. This was shot just now at 80mm, F4, 1/13th sec handheld.
08-23-2011, 04:40 AM | #25 |
Weebl wobbles but eats Pie
97
Rep 1,794
Joe, the two lenses as you know are at different price points and both are excellent lenses. The 24-70 with the 2.8 will give you a nice and short DOF for your portraits (which take time to compose and shoot) but the IS on the 24-105 helps for those quick snaps. You may also throw in the EF-S 17-55 F2.8IS which is a very high quality lens also. The two L lenses you have to multiply for the crop of 1.6 on the 7D but the EF-S lenses you do not.
You have a very smart wife, she steered you away from the dark side ;-)
Kevin Goto
2000 740i-Annalisa (sold 2018) 2008 335i-Weebl. Weebl may wobble but has DTC 2012 X5d in Sparkling Bronze ( The Ultimate Cat Carrying Machine)-RIP BMW buyback 2019:2017 A3, 2018 Audi SQ5 |
08-23-2011, 06:36 AM | #26 | |
Rep 5,114
to me, the F4 isn't wide enough, but the image stabilizer makes me always want that lens. I'm very happy with my 24-70, just not in super super low light, or trying to make water move. But for the low light, at least i can crank the ISO up to compensate. the 24-105 is also tack sharp. I've heard some mixed reviews on the sharpness of the 24-70. They've been hit and miss for people, but funny enough, i haven't met or talked to anyone personally who has had one of these "bad" ones. |
08-23-2011, 08:58 AM | #27 |
Rep 6,798
That's because they've been returning 'em... duh
08-23-2011, 09:26 AM | #28 | |
Rep 7,389
I understand that Lightroom and ACR do similar correction. Most of the reviews compare lenses on a uncorrected basis. Unfortunately, that's not how we use lenses these days. Of course, IQ might be better in LR than DxO, etc., so the reviewers just avoid that issue by not even mentioning it. However, us end users need to consider it before we send a lens back. Here's one with the 24-105mm wide open at f/4, ISO 100, +1EV resulting in 1/800th second. I intend for the flags to lean in so I didn't correct that, but DxO did correct some relatively heavy CA and curves in the pools at the edges: Rockefeller Center by dcstep, on Flickr
08-23-2011, 01:50 PM | #29 |
Aberry is a scammer
591
Rep 5,507
Drives: SGM E92 335i, AM E90 335i
17-40L is the thing I miss most about my cannon.
08-23-2011, 02:24 PM | #30 |
Rep 24,685
Drives: '04 330i ZHP
holy crap I totally forgot about that. Good thing you mentioned it, I'm helping a buddy put together a body/lens combo on an XSi. That might be a bit wide for him now.
08-23-2011, 02:30 PM | #31 |
Rep 5,114
the 17-55mm F2.8 might be the first one i go for, it's probably one of the best lenses for the money out there. It's as fast a zoom as you can get on an EF-S mount lens.
and since you are used to that 50mm mark, it will be decent for you. And it will cover a wider range then the bottom end of your kit lens. over all, if you can find a zoom lens that has a constant F stop, it will be your best friend because it will be better for controlling exposures. |
08-23-2011, 04:24 PM | #32 | ||
Rep 7,561
From The-Digital-Picture: Quote:
It's simple physics. A 70mm focal length will produce an image of an object on a sensor that is x-mm by y-mm regardless of the sensor or the lens type. So your FOV on a 1.6 crop sensor is the same at 70mm whether it's from an EF lens or an EF-S lens.
08-23-2011, 04:27 PM | #33 | |
Rep 7,561
08-24-2011, 07:17 AM | #34 | |
Rep 29,217
F10 520d M-Sport Alpine White | HRE P43SC 20x9+20x11 | Michelin PSS 255/35+295/30 | KW V3 Coilover | M5 Front Sway Bar + M550d Rear Sway Bar | 3DDesign Front Lip | BMW M Performance CF Spoiler | BMW M Performance Diffuser | BMW M Performance Black Grills | BMW M Performance Pedals | |
08-24-2011, 09:34 AM | #35 |
Rep 7,389
It won't cover the sensor on a FF body. Even if it did, it'd still be 17-55mm.
Lens FL is stated in reference to 35mm dimensions. Hence, FF is pretty much a 1-to-1 vs. 35mm film. With a 1D the field of view is constrained and you multiply by 1.3 to get the equivalent field of view. It's still a 17-55mm lens, with the same reach (multiplication) of a 17-55mm, but with the field of view narrowed (cropped). For Rebels and the 7D the factor is 1.6, but the reach is still unchanged, just the field of view is reduced. If I take my FF 5D MkII and take a picture at 24mm and take the same scene at 24mm with my 7D, if I crop the 5D2 image (maintaining the aspect ratio) around 40% the subject will be the same size in both the uncropped 7D image and the 5D2 cropped image. All that's changing is the field of view, not reach or focal length. P&S makers have further confused the issue by making up terms such as "digital zoom", which is merely in-camera cropping. With a tiny sensor the IQ quickly goes to hell in a hand basket. Dave
08-24-2011, 09:40 AM | #36 |
Rep 5,114
basically, you're just getting a "theoretical" number, where the actual number really doesn't change at all.
Interestingly however, with the megapixel size of these crop bodies out there, they have more pixels in their crop then the 21 megapixel 5DmkII. if you were to turn the crop sensor cameras into full frame, they would be pushing about 25mp. |
08-24-2011, 09:50 AM | #37 |
Rep 24,685
Gonna trade my back up 40D+grip for a T2i.
yay or ney? |
08-24-2011, 10:29 AM | #38 | |
Rep 7,389
IQ includes several things, such as detail resolution and noise production. Some people only focus on noise, which I think is a mistake. Anyway, I suspect that the 5DIII will meet or exceed 25-mp. That'll put some of the file sizes up over 30MB. I'm already operating in 64-bits, but may need to invest in more RAM soon, going from 6GB to 10GB to speed up RAW conversion and processing. Onward and upward...
08-24-2011, 10:31 AM | #39 |
Rep 7,389
Yay.
The T2i has the same sensor as my 7D, which is wonderful in rendition of detail. Sounds like a great trade to me. Dave
08-24-2011, 10:47 AM | #40 | |
Rep 816
The T2i is indeed a nice little camera and produced noticeably better results than the XSi I had previously (which, in turn, already had better resolution than the 40D). ...and the HD video was nice too. I dragged the T2i around in the Australian outback for a month and in the Central American jungle for a couple of weeks and it came up smiling - the little Rebels are plenty rugged (even if they are not of the main battle tank quality of the 1 series). That said, the big improvement going from the T2i to the 7D was in responsiveness (instantaneous shutter response, quicker AF, much faster burst rate). I'm not sure how these parameters fare on the 40D, but some of them might be worse on the T2i. Worth checking before making the switch if this will be your only/primary camera body. |
08-24-2011, 10:56 AM | #41 | |
Rep 7,389
Love my 7D. Dave
08-24-2011, 12:11 PM | #42 | |
Rep 5,114
Each camera covers the others weaknesses. Controls are similar, making the switch from one to the other easier then it would be with a T2i. That being said, I respect the T2i a lot, but if you're going rebel, why not get all the bells and whistles of a T3i? |
08-24-2011, 01:11 PM | #43 |
Rep 7,561
Was wondering the same thing, but I thought maybe he had a one-time deal to trade straight up for a T2i.
08-24-2011, 07:06 PM | #44 |
Rep 8,800
u can also rent a few lens if ur still un-sure which one to get.
borrowlens.com
FrankiE90 AKA:.[The TANK] *CLICK THE SIG
E90s (been gone but not forgotten) • KW clubsports • • • • • • • • • • 18" BBS GT4 // Build E30 (pending) + E46 M3 Wagon ESTORIL Blue |
