High Engine Temp...cooling system
07-23-2007, 05:47 PM | #23 | |
Rep 134
Run 1 Conditions: Ambient temp: ~70 F Front/ Rear Tire Pressure: 38/40 psi cold Tires: Dunlop SP Supersport Race (R-Compound) The attached diagram highlights the course and my speeds around the track. Resulting oil temp after 1st 25 minute session: ~250F (slightly over) Run 2 Conditions: Ambient temp: ~74 F Front/ Rear Tire Pressure: 37/35 psi cold (to much understeer from previous set up) Tires: Dunlop SP Supersport Race (R-Compound) The attached diagram highlights the course and my speeds around the track. Resulting oil temp after 2nd 25 minute session: ~250F - 260F Run 3 Conditions: Ambient temp: ~77 F Front/ Rear Tire Pressure: 37/35 psi cold Tires: Dunlop SP Supersport Race (R-Compound) The attached diagram highlights the course and my speeds around the track. Resulting oil temp after 3rd 25 minute session: 260F In all cases I running the engine to 6500 RPMs and shifting around 6800. Prior to going to the track I had my coolant changed and added a mixture of 60/40 coolant/water. I also use CASTROL 10W-60 motorsport oil. Last edited by BMWdrmz; 08-04-2007 at 09:16 PM.. |
07-23-2007, 09:49 PM | #24 |
Rep 475
BMWdrmz - I think two things are at work here against my car. #1 the outside air temp was around 95 degrees and #2 I have the Steptronic with paddles. Living in the LA area I decided to try my first auto...please remind me to never pull that stunt again. The temp is self explanatory but unlike the 6MT I'm told the Step transmission is cooled by a jacket radiator piggybacked to the main radiator. It seems the Step, when worked hard in manual mode, is introducing more heat to the system than can be dissipated. The result is a coolant temp which spirals higher and higher until it hits the magic 242 degrees. In my case this sadly occured over and over again. But let's not forget, it's documented that this also happened to a 6MT car at the Streets of Willow.
I guess BMW missed the demographic for step buyers as is evidenced by the missing oil cooler in pre March production cars and now some cases of overheating coolant. But, it's not my fault the step cars can't take 95 degree heat and hard driving. I'll let you know how my story plays out if my car overheats again at my next school in Sept at Buttonwillow. I kind of doubt the outside air temp in Bakersfield in Sept will be any cooler so I'm anticipating more of the same problem. If so back to the dealer it will go and then they'll have only one more shot at fixing it. Last edited by RMRC; 07-23-2007 at 10:24 PM.. |
07-23-2007, 10:28 PM | #25 | |
Rep 1,349
Tom said they are working with BMW, but he didn't sound too optimistic.
Any man who can drive safely while kissing a pretty girl is simply not giving the kiss the attention it deserves. ~Albert Einstein
07-24-2007, 12:30 AM | #26 |
Rep 648
BMWdrmz, what were your hot pressures? You must have been near 50psi hot in the front with those cold temps. Try starting with 30F/32R and see how close you get to 40. Where did you find those SPSSR's?? I ran through my last set over a year ago. We bought 14 sets from Tirerack. Your production dates on the tire must be from 2002. How did they work? Mine lost there stick in the end as the compound deteriorated just sitting around for for four years in storage. Thanks for the info.
07-24-2007, 05:30 AM | #27 | |
Rep 134
Overall, I really like the tires. I purchased them from Tire Rack last year. They were on sale because they were being discontinued. They were so inexpensive, I thought why not give me a try, and If Ididn't like them no biggie (@~$/ tire 112). I'm kind of kicking myself now, thinking I should have purchased an extra set. I'll have to check the production date, but I haven't experienced any loss of grip yet. They also seem to hold up to heat and have a pretty good wear pattern. I probably have one driving school left in them, and I 'll have to find something else. |
07-24-2007, 11:19 AM | #28 |
Rep 475
So far it sounds like the overheating coolant issue is somewhat rare. In fact, I think I'm the only one on the board who has experienced it. Is this true? Given this, are you 6MT guys comfortable that your cars will hold up to driving schools in 95 degree heat? If my car is bought back or goes lemon law do I go with the 6MT (preferred anyway) or consider another car...perhaps going back to E46 M3? Any thoughts?
07-24-2007, 11:25 AM | #29 | |
Rep 633
07-24-2007, 11:56 AM | #30 |
Rep 475
There won't likely be time for that. If my car goes lemon law or is bought back I would expect it to happen by the end of summer. The cost is affordable but not palatable and the new M has grown to 3,700 lbs according to the latest Autoweek. And if I'm spending $70k with options I would have to consider the 997 which I believe to be in a different league. Though, it's not fair to compare the two. This plus I will never buy a 1st year run again.
07-24-2007, 06:09 PM | #31 | |
Rep 475
I've thought about trying the 10w60 we used in the M3s but the manual recommends either 5w30 or 5w40. Given that I'm having problems with my car and that they don't appear to be oil temp related I don't want to use a viscosity not found in the owners manual. I can see BMW denying warranty coverage due to incorrect oil. |
07-24-2007, 08:13 PM | #32 | |
Rep 1,349
07-24-2007, 09:08 PM | #33 |
Rep 475
Yes exactly. Maybe 90 degrees ambient is the limit for a Step because at 95 mine limped over and over again after just 15min each session. Should be interesting to compare it to another 6MT. Anyway my coolant overheats will be hard for BMW NA to dispute.
09-07-2007, 01:27 AM | #34 |
Rep 7
If the engine overheats and exceeds its normal operating range, the elevated temperatures can cause extreme stress in the cylinder head which may result in a head gasket failure. Coolant can boil out of the BMW 325es radiator and be lost. Pistons swell inside their cylinders and can scuff or seize. Valve stems can swell in their guides and also scuff or seize. This, in turn, may damage valve train components (broken rocker arms, bent pushrods, etc.) or possibly result in damaging contact between the valve head and piston if the valve sticks open. The thermostat should be check to0.
09-07-2007, 07:36 AM | #35 | |
Rep 1,137
I was looking over your graphs and had a question about how to read them. There are the vertical dotted lines...what do they represent?
2010 Evo X - silver with a big, stupid wing on the back
2009 VW CC - Black/Black - with a 2011 328i on order to replace it - ED 8/1/11 |
09-07-2007, 12:59 PM | #36 | |
Bootleggin' 'n Gunrunnin'
139
Rep 2,372
I personally think that a lot of Step's going into limp mode on the track have more to do with coolant temps than oil temps. But everybody just assumed it was oil temps because their gauges were near max, and the one noticeable difference is that 6MT cars had the additional oil cooler. This is fairly common, to mis-diagnose a problem. That isn't to say that high oil temps aren't a problem, but that the real culprit for many limp modes is more likely coolant temp issues than oil temp issues. This is especially true in high ambient conditions, where you are more likely to be running the A/C as well. The coolant system on the Step not only cools the engine, it also cools the transmission. So it is working harder in a Step car than a 6MT car. That is part of the reason you are seeing higher coolant temps with the Step than the 6MT. If I had a Step car, I'd be asking for an auxillary transmission cooler as well as the oil cooler. Maybe even an increased capacity pan for the transmission as well. That should take some load off the primary cooling system.
Scott
2024 G01 X3 M40i, Brooklyn Grey Metallic /// 2015 F15 X5 35i, Space Gray Metallic, 99K miles /// 2013 F30 320xi, Mojave Metallic, 112k miles 2019 Ford F450 STX, Oxford White 2013 Ducati Multistrada Touring S, Red |
09-07-2007, 01:16 PM | #37 | |
Rep 475
BTW, the step is gone and I now have a 6MT. After so many MTs I don't know why I decided to try the auto but I quickly learned it's not for me. |
09-07-2007, 01:28 PM | #38 | |
Thats all you need to know.
43
Rep 1,188
I dont agree the temps are on the high side. The 335 has been in several endurance races and not suffered from heat related failures.
- M2 2018 LBB / Black
- X5 F15 2016 Mineral White / Black 1981 Delorean number 6489 |
09-07-2007, 02:40 PM | #39 |
Rep 1,714
09-07-2007, 06:13 PM | #40 | |
Rep 1,137
I saw the legend and understood, but was still having some trouble reading the graphs. Perhaps my small laptop monitor was making it harder.
09-07-2007, 06:54 PM | #42 |
Rep 475
09-09-2007, 10:34 PM | #43 |
Supreme Allied Commander
3890
Rep 54,597
Drives: F80 M3
Out on the track with Southern California Audi Club this weekend at Buttonwillow Raceway. Ambient temperature reached 97 F at times on the track and in the low 90's in the pits.
Armed with Redline 5W40 and Water Wetter. Pushing the car around 8/10th got the oil temp close to 270 F. No power losss at that temperature and the car was still pulling hard. Last time out at Willow Spring Raceway with ~80 F ambient temperature, driving the car at 8/10th as well, I believe I saw oil temp just under 250 F. Some of the Audi guys consistantly see oil temp near or above 300 F this past weekend. |
09-10-2007, 11:31 AM | #44 |
Rep 475
Have you done a Used Oil Analysis of the Redline 5w40? I'd be curious what the results are. It seems these direct injection engines suffer from pretty bad fuel dilution causing the oil to break down rapidly (<3,000 miles) and flashpoints to plummet. I learned of this problem over at www.bobistheoilguy.com.
