      06-10-2013, 03:33 PM   #23
Dackelone
European Editor
Dackelone's Avatar
Germany
10642
Drives: N54 e82
Originally Posted by LeifW View Post
Thanks Dackelone. Not sure if you'd know this, but does the tire come mounted?
Thanks,
Leif W.
Yes, I believe so. They come mounted and balanced by BMW AG.
      06-10-2013, 05:56 PM   #24
Em/1
Em/1's Avatar
Drives: 2011 1M VO
2019 VW GTI SE  [0.00]
2020 Tesla M3P  [0.00]
2011 BMW 1M  [0.00]
My spare is just a Michelin Pilot PA3 mounted to a Sport edition 18"--can go front or rear and just my winter set-up; $109 (Tire Rack) for the wheel, $232 for the tire (235-40) and they are quite decent on a dry road.
      06-10-2013, 07:03 PM   #25
LeifW
Drives: 1M AW
Thank so much.
Leif W.
      06-27-2013, 02:27 AM   #26
DrGadget
DrGadget's Avatar
Australia
46
Drives: M140i F20 LCI-2
2018 BMW M140i  [0.00]
That guy Rick is talking about was ME! And it sucked driving around on that skinny little donut. It does fit on both axles. But I had a flat tire on the rear... and being limited to only 80 kph(on the Autobahn!!!) was too much punishment for me. Plus the rear end of the car was wiggling around like crazy when you changed lanes the tinniest bit! It was very unstable with one 3.5 inch tire on one side and a 9 inch tire on the other side of the car.
Lucky for me, a local 1Addict, Swadeness lent me one of his 18 inch winter wheels, and I drove home on that. For me this exposed the problem with space saver tires. When you need to use one... you really just need a real full size tire. The next week I bought a steel 17" wheel and a 205/50HR17 tire. I also have the BMW jack kit that they sell.
Photos removed
I found my spare 18" wheel (shown in photo) so heavy and it takes up so much space that I finally have bitten the bullet and ordered an alloy space saver from e-Central Store. Freight costs a bomb, but its like buying an insurance policy.
Current: Alpine White M140i F20 LCI-2, 250kW/335hp, 2018.
Sold: Melbourne Red 340i F30 LCI Luxury Line MMPK - 265kW/355hp, 2016.
Sold: Alpine White 123d e82, 2010, 150kW/204hp.
      07-05-2013, 02:42 PM   #27
buckeyegirl
Drives: BSM 1M Coupe:) Jeep for Winter
silly girl question
Is there any chance that running one of these tires will ruin the differential?
      07-05-2013, 09:45 PM   #28
LeifW
Drives: 1M AW
Alright, I put together a spare tire kit on tire rack (see attachment). I was looking at getting a BMW style 270 wheel, but it's a fair amount of money. I'm thinking of going with the below setup and I was curious to get feedback. Specifically, does anyone have knowledge of this sort of wheel. I assume it would fit.
So what do people think?
Leif W
      07-05-2013, 10:54 PM   #29
CarJunkie
CarJunkie's Avatar
Drives: e82 1M, f87 M2cs
2020 M2cs  [0.00]
2011 BMW 1M  [0.00]
As long as the spare matches the rear diameter and speeds/inputs are kept within reason, the diff should be OK. I would drive on it like it was a donut tire, no more than 55mph, and no hard acceleration that might cause the diff to lock up or produce wheelspin. If the tire is narrow enough, there shouldn't be too much rubbing if it is needed up front. Full steering lock may be a issue.
Since I would be driving as described above, I'd save a few bucks and get a cheaper tire. Why buy a PSS for a spare?
      07-23-2013, 11:45 AM   #30
buckeyegirl
Agreed, I was thinking about buying the cheapest possible skinniest possible spare that would fit the brakes.
      05-06-2018, 07:33 PM   #31
Em/1
Em/1's Avatar
Drives: 2011 1M VO
2011 BMW 1M  [0.00]
Yes Leif, the second part number is for a alloy wheel AND tire. BMW sells their wheels with and without tires.
Dack: Does the Jack set you use for sure "fit" the 1M? Seems to be in short supply and the only place I found it (71106773536) could "not be sure it fits" my car...
      05-10-2018, 01:40 PM   #32
Rikx1M
MSgt (ret)
Rikx1M's Avatar
Germany
568
Drives: VO 1M #739/740
Dackelone was this ever confirmed?
But just had a thought...I should see if your tire/wheel fits my M for the roadtrip in June...
      05-10-2018, 03:41 PM   #33
Dackelone
European Editor
Dackelone's Avatar
Germany
10642
Drives: N54 e82
Name:  spare tire 17 inch steel wheel from a 330i e46  MG_5306.jpg
The Jack kit, will work on any BMW.
The space saver wheel or full size wheel(the e46 steel wheel)that I have, will only will fit a 135i. Rick, remember when Florian(Blue car above) had a flat tire... I gave him my full size e46 spare steely to complete our tour and get back home. But when Rudi's 1M had a flat... he used one of your spare tires - bc the 1M has different offset wheels than a 135i has.
Dackel
      05-10-2018, 08:54 PM   #34
Em/1
Em/1's Avatar
Drives: 2011 1M VO
2011 BMW 1M  [0.00]
Funny, that's why I need the jack kit--road trip in June!
Dackelone10641.50
      06-05-2018, 05:54 AM   #35
Em/1
Em/1's Avatar
Drives: 2011 1M VO
2011 BMW 1M  [0.00]
Attachment 1822195
Attachment 1822196
Attachment 1822197
Dackel
Apparently this product has been discontinued; anyone know of another option for a compact jack et al that will work on our cars?
      06-05-2018, 04:16 PM   #36
Dackelone
European Editor
Dackelone's Avatar
Germany
10642
Drives: N54 e82
BMW also offered a jack kit for the X5 and 5 series as well. I would ask a dealer to look up one of those jack kits. Or go to a junkyard(or look on ebay!) and find a jack from any BMW built in the last ~25 years. Even my e39 jack works to lift up my 135i.
ayao646.00
      05-23-2019, 03:18 AM   #37
Boost3d_1M
South Africa
88
Drives: E82 1M
I have the same spare from the original post which i used on my e92 335, I was going to sell it and get the E9x m3 one...Need to double check for my own sanity that this will work on the front and rear of my car!
      06-10-2019, 06:16 AM   #38
Boost3d_1M
South Africa
88
Drives: E82 1M
Can confirm, that the 17" spare doesnt fit on the front of the car. I tried with a 10mm spacer but i think the bolt itself may be an issue itself, because the wheel couldnt spin with the "extended bolts" , i suspect it may work with a 15 or 20mm spacer...
ayao646.00
1addicts
