06-17-2014, 03:09 PM | #23 |
Rep 1,762
Drives: Porsche Panamera
I wouldn't recommend going with more than 1 tb for external hard drive. It's a hard drive and they do fail. You don't want 3 TB of data loss. But if you buy for intensive archiving, size matters.
06-17-2014, 03:11 PM | #24 | |
Rep 510
06-17-2014, 03:17 PM | #25 | ||
Rep 1,762
and honestly, if you are only scanning bills to share with CPA, large storage flash drive is safer and easier to carry with just enough storage size for your use. I think even 64gb flash can go long way for plain images. |
06-17-2014, 03:27 PM | #26 | |||
Rep 510
06-17-2014, 04:07 PM | #27 | |
Rep 646
06-17-2014, 04:19 PM | #28 |
Rep 1,762
06-17-2014, 05:01 PM | #29 |
Rep 3,357
Flash drives are not without issues either. Flash drives have a service life measured in the number of writes it can endure before you won't be able to save any more data to it. For most people it's not an issue as many people won't reach that point. But flash drives can fail for other reasons.
I have a Patriot 32MB SD card which has failed on me and I only used it for my digital camera. If you happen to have a hard drive fail, there are ways to recover the data depending on the failure. With a flash drive failure, your options are limited. |
06-17-2014, 05:03 PM | #30 | |
Rep 510
06-17-2014, 09:11 PM | #31 |
Rep 3,357
It's a pain, but that's why I suggested buying two external hard drives. But make sure each hard drive is from a different manufacturer. Buying from two manufacturers usually minimizes the risks of losing data due to a hard drive failure as it's unlikely you'll have a failure of both drives at the same time.
06-17-2014, 09:19 PM | #32 | |
Rep 1,762
Just save everything in your computer and transfer it to whichever drive you decide to use. |
06-17-2014, 09:20 PM | #33 | ||
Rep 510
06-17-2014, 09:37 PM | #34 |
Rep 4,245
Drives: BMW G80 M3
You'll be fine as long as you are keeping your data copied somewhere (2x copies).
I bought a Western Digital Passport 2TB earlier this year on sale; it's been reliable and trouble-free so far. That drive replaced a 500GB Western Digital Passport I had for almost four years prior - no issues. External hard drives are commodities, it's hard to go wrong as noted provided you buy a mainstream brand like Hitachi, WD, etc. Buy the base model drives; a lot of companies sell "deluxe" external hard drives which usually just include a bunch of software that they charge extra for.
2024 BMW M3 Sedan Frozen Pure Grey II/Fjord Blue, 6MT
Past: 2021 Z4 M40i Frozen Grey II/Black Alcantara | 2017 F30 340i Mineral Gray/Coral Red, 6MT | 2011 E92 335i Le Mans Blue/Black, 6MT |
06-17-2014, 09:54 PM | #35 |
Rep 926
For business I highly recommend a cloud service. Most of the hard drives mentioned in this thread all have a single point of failure. If you need redundancy then I would buy an external with dual drives set up with a mirror. This way if you have a failure (disk) you have some kind of redundancy. If the power/case fails then you can replace the case/pwr and get your data back. If you go with a single hard drive and you experience a disk failure getting the data recovered can be pricey.
Now if you go cloud...redundancy/ha is part of the service. IMO your data will be protected much better. If you need a certain retention period you can create folders to manage this. And if you decide in the future to spend the capex on proper storage you can always migrate the data back. |
